Positive Grid BIAS Head
Started by Elantric, September 15, 2015, 12:35:42 PM
Introducing BIAS Head - Amp Match Cranked Up
We are proud to introduce BIAS Head, a 600-watt powered guitar amplifier that will give you the world's finest amps. Amp match your tube amps, virtually swap tubes, share and download thousands professional Amp Match profiles.
http://www.positivegrid.com/bias-head/
They have added features I suggested to Calvin 18 months ago
Its MIDi over USB ( no Audio ) , for use with a Librarian app
The "Wireless" switch on rear is for the BT-4
But I suspect if they ship 100's of units, they will be in for a new level of awakening sleeping giants
FCC / CE Standards have teeth
https://www.vguitarforums.com/smf/index.php?topic=11234.0
mbenigni
Do you have any sense of pricing?  Even ballpark?  It looks like a deeper version of the THR100 concept - plus presets and MIDI control.  I like it!
It will be up there  - slightly below Kemper   - I estimate over $1000  to- $1200 street
they need a better profit center than selling IOS apps at $20 each
and the $200 Win/OSX Desktop apps are not selling as fast
(I cant say anymore)
FYI here's what I could make out I/O and control wise from that video:
front panel:
1/4" input jack
jewel light
top row
Type Knob (CLASSY, CLEAN, METAL, CRUNCH, BLUES)
save PB switch
Model Knob (1 - 5)
Tube Stages knob (1 - 5)
Bright toggle switch
Distortion knob
Topology Knob (Single Ended, Split Load, Push Pull, Solid state)
Rectifier toggle switch
Power Amp Knob
Bias knob (COLD @ 4, HOT @ 6)
gain knob
bass knob
middle knob
treble knob
presence
vintage toggle switch
master
output level
back panel:
power switch
F1 custom function switch
F2 custom function switch
1/4" effects loop send
1/4" effects loop return
pb switch effect loop ground lift
headphone 1/4" output
XLR balanced line out
1/4" unbalanced line out
pb switch line out ground lift
AC in
wireless PB
USB
EXT Pedal 1/4" jack
MIDI IN/OUT/THRU
QuoteAnd no "EFFECTS"  ???
That will arrive as the  BIAS FX expander Hardware Box (sold separately @ same price)
Quote from: Elantric on September 15, 2015, 01:21:30 PM
That will arrive as the separate BIAS FX expander Hardware Box (same price)
SO VERY TRUE ;D
vanceg
Looks interesting.  The Effects would be more interesting to me personally, but I know I'm in the minority of guitarists who don't really care for guitar amp sounds.....
yuri
Yes , very interesting !It can replace an Kemper ?
yuri
Function -Match amp , is what interests me the most  of all !!!!I do not know if this can work well with Positive Grid AMP MATCH  ?To specify, for create or profiling an old guitar isolated CD track sound (without mic and amp) . Kemper is good for profiling an real amp but an old isolated guitar track sound - have problem, not work !.   as real audio sampler .
The biggest hurdle is the Bias Head will be from the same hardware team that executed the BT-4, and Jamup Up Audio Interfaces
Positive Grid Hardware has a poor track record IMHO.
GuitarBuilder
Judging by the BT-4 it is shaky at best.  And their tech support goes silent at the most inopportune moments.
QuoteJudging by the BT-4 it is shaky at best.  And their tech support goes silent at the most inopportune moments.
Agreed
At least they finally have "MIDI" as a help topic here
http://help.positivegrid.com/hc/en-us/search?utf8=%E2%9C%93&query=midi&commit=Search
QuoteBIAS FX IOS HELP
Live View
Control Pad
We separate control pad into several parts, the first 4 block in first row is preset part, you can switch on each preset very easily. the first 4 block in second row is control part, long press on the block allows user to choose its control function:
MIDI Learn : Set MIDI to this block
Toggle Pedal : Turn on/off for specific pedal
Toggle Fx Category : Toggle on/off status on specific category
Tap Tempo : Set the bpm by tapping on the block
Splitter Channel Select : Select channel on dual path
Stick on board : Turn on if you want to keep the assigned switch alway on the board
Signal Path
Pedals is not allowed to change its sequence in Live View , but you can tap on it to turn on/off effects.
GovernorSilver
#15
This is not an app/software-only product.  It's a physical object you can carry around as well as plug your guitar directly into.  They also claim it will work with bass.
http://www.positivegrid.com/index.html%3Fp=9093.html
TECHNICAL DETAILS
Power Amplifier
600 Watts RMS @ 8 Ohms, 300 Watts @ 16 Ohms
Voltage and Frequency
100-240V AC, 50-60 Hz
Dimension (H x W x D)
7.5 x 12 x 6 in. (314 x 190 x 153 mm)
Weight
17 lbs. (7.7kg)
Instrument input
1/4 inch, Hi-Z impedance
Effect loop
1/4 inch, send and return
Headphone output
1/4 inch TRS
Direct output
XLR balanced and 1/4 inch unbalanced
External Pedal
1/4 inch TRS
MIDI
5-pin connectors for In/Out/Thru
USB
Connect with BIAS Mac and Windows
Bluetooth
Connect with BIAS iPad and BIAS iPhone
I saw that didn't like that it did not come with any effects at all ???
Merged with existing thread
GovernorSilver
I swear on my mum's grave I did a search with "positive grid bias head" before creating my post.  Got no results.
Main piece of info to convey is Search here wont work well unless you start from the homepage here
And links were posted to help the other 2,000+  folks who also view this thread
GovernorSilver
The keywords I may have actually used was "bias head".  Got no results.
Today I get results with those keywords.
But since I can't seem to remember the exact keywords, there's no point in further discussion of the forum search functions.
