USB Host to 5pin MIDI Converters
Started by Elantric, July 31, 2015, 09:23:28 AM
vtgearhead
Quote from: admsustainiac on October 14, 2017, 01:38:30 AM
Be sure to use the USB OTG Adapter that supports USB 2.0 high speed for your specific Android 6.01 (or higher) device.
The "OTG adapter" I purchased for my Galaxy A6 appears to be nothing more than a USB A female to Mini male adapter.  Is there supposed to be active circuitry involved, or am I misunderstanding something?
They are typically passive, but many Android devices have MHL micro USB connectors , others have USB -C ports , etc
RK-004 6CH FULL MIDI MERGER/SPLITTER/CLOCK PROCESSOR
https://www.retrokits.com/rk004/manual/20170710-RK-004-Manual.pdf
https://www.facebook.com/retrokitsDev/
The 6 channel MIDI Merger/Splitter, 8 channel Sync-hub and clock processor!
The RK-004 is not your 'ordinary 6 channel MIDI-merger or MIDI-splitter'. The 7 MIDI DIN5 sockets hide more than you would expect at first sight.
Here is a small demo video and below the RK-004s fundamental features:
MIDI thru
MIDI message arriving at an input will be casted-thru to all connected outputs. This makes the RK-004 behave like a MIDI-thru box, syncing up all your connected MIDI devices. The cool thing is that each connector can act as MIDI input ór MIDI-output. This means you can use the RK-004 to merge up to 6 MIDI-sources into one output, split one MIDI source  up to 6 outputs or just sync up 7 MIDI devices by using the RK-004's internal clock or (or slave all MIDI devices to an incoming sync pulse, see 'tempo manipulation') The direction of the ports is ad hoc, and the direction is detected automatically: this means that you just can "plug and play™", and use the connectors as you like.
MIDI merge Today you want to control your sound module with 2 controllers(='merge'): just connect and it will merge. Tomorrow you want to control 2 sound modules with 1 controller (='split'): just connect and it will split... any other combination is valid also! The good thing is that you don't have to reconfigure: the direction will be auto-detected. Note that the MIDI-in mode of the RK-004 is not opto-isolated like regular MIDI-in ports. Although this could sometimes lead to a 'ground loop' it is not more dangerous for your equipment than plugging a midi-out to a midi-out port.
Analog SYNC input In order to use your favorite analog sync source there is the sync-in connector which accepts good-old analog sync input. With this connection it is possible to use an analog sync generator as master clock to which the whole remaining system will lock. So yes: this will generate MIDI clocks from analog sync input !
Analog SYNC output
The other way around: if you want to slave-sync your analog equipment with a clock originating in the digital MIDI world there is the sync-out connector. On this connector you can connect analog equipment which will lock to the generated sync signal.
Ports can be defined as sync-only You can change the MIDI connector into sending out sync signals. With the use of a MIDI to Mini-jack converter (as provided with e.g. the Arturia Beatstep) in reverse to the RK-002, this enables you to use the MIDI-connectors as sync output. This way you can also use the RK-004 to drive a bunch of (example given) Pocket Operators.
Tempo manipulation Every port can be set to run relative to the midi or sync master clock (or discard the master clock alltogether). This way you can creatively use sequencer machines to run in different tempo's with each other.
Stand-alone tempo If you don't use any MIDI or analog sync-master gear on the RK-004 you can use it so generate it's own tempo just by tapping it.
Raspberry Pi USB Host
The basic RK-004 only has it's USB ports for power distribution but you can connect a RaspberryPi to the (PiZero)-layout-compatible connector, download our disk image and use the RK-004 to merge your USB-only midi devices into 'the real MIDI world'.
Not only for RPi projects by the way; By setting the 1st RK-004 port to Serial mode you are able to connect the RK-004 via serial port on a regular baud rate, easily integrating other hardware projects into your music.
You can download a RPi disk image from Google Drive
Configurable with Audio only
It is not necessary to have another MIDI interface at hand to set the clock divisons, force port directions or set sync properties. Just a phone or tablet with audio out can be used to configure the RK-004.
You can use this link to open the RK-004 settings page on a new tab so you can bookmark it on your home screen as a web app.
The RK-004 comes with the RK-USB cable
Also take a look at it's settings page
Related Pro[/img]
Introducing you to the Retrokits RK-004 MIDI/Sync hub and the MyVolts 5-way Roland Boutique USB power cable (man that's a really long name). However in this video we are focusing on the RK-004. This neat little device allows for some seriously complex MIDI splitting, merging and syncing setups. In this video I am demoing the MIDI clock rate functionality inside the RK-004. It allows the user to set different clock speeds for individually for each output.
Other featured gear: Novation MiniNova and teenage engineering PO-12 Rythm
RETROKITS ► https://www.retrokits.com/
https://www.excelvalley.com/product/usb-midi-host-module/
USB MIDI Host module
Create a real MIDI OUT port for your pure USB MIDI controllers and keyboards, without a PC.
The USB MIDI Host module is available as separate PCB and as Module (PCB + Enclosure)
Specifications
'Classic' DIN MIDI Out port
USB Host port, provides power to your USB MIDI device and receives MIDI information
Mini USB port (for 5V power supply)
Dimensions
PCB with Enclosure Kit: 90 x 50 x 30 mm
PCB without Enclosure Kit: 90 x 50 x 20 mm
Demonstration
Example setup with Akai LPD8:
USB MIDI Host Module – LPD8
Compatibility
Standard MIDI compliant devices are supported.Some Complex MIDI devices use a built-in USB Hub. These MIDI devices are not supported and will NOT work with our USB HOST Module. You can determine if your device has a built-in hub by running the free Windows program USB Tree Viewer.
http://www.uwe-sieber.de/usbtreeview_e.html
If, when you plug in your MIDI device, it appears as a new hub plus one or more devices then it will not work with our USB Host Module.
List of known Supported & Unsupported devices
Known Supported Devices                    Unsupported Devices
AKAI professinoal LPK25 keyboard       Novation Launccontrol
AKAI professinoal LPD8 keyboard       Alesis V49
Akai MPK Mini mkII
Arturia Beatstep
Behringer X32
Behringer XR18
KAWAI MP6
KORG nanoPAD2
Numark Orbit
Yamaha P105
Information
Wikipedia: MIDI – Musical Instrument Digital Interface
https://en.wikipedia.org/wiki/MIDI
Wikipedia: General MIDI
https://en.wikipedia.org/wiki/General_MIDI
SKU: AUHM00 Categories: Audio, MIDI Tags: Game Port, Joystick Port, MIDI
RetroKits RK-005: USB MIDI Hub that hosts, merges and interconnects everything
RetroKits RK-005
RetroKits RK-005  ·  Source: RetroKits
We first saw the RK-005 back at Superbooth and it had us scratching our heads a little bit while pondering the possibilities of all this interconnectivity. But now it's available for pre-order in limited numbers and I think we can get a handle on what it's all about.
RK-005
It's a compact little box that can integrate all your USB MIDI controllers and devices into a single MIDI stream. It allows you to bring those controllers together and use them without a computer, or it can become a USB device in your DAW. It will both host other devices and become a device itself. It handles USB connections directly or through a USB hub and will send out over 5pin MIDI or USB to host. It's completely flexible.
It also has a handle MIDI Clock to Gate converter built in so you can sync up your modular or analog gear to your MIDI-equipped groove box, drum machine or DAW. You could use it to sync up Pocket Operators, Elektron boxes and Volcas with your Eurorack. You could drop in your phone or iPad – anything that moves MIDI about could join the RK-005 club.
RetroKits RK-005 connection example
It's a phenomenally useful piece of equipment that could save your sanity once the amount of boxes you have on your desktop gets beyond a sensible number. Got to be a great thing to have at a Synth Meet in order to keep everyone together.
The RK-005 is not cheap at €146 but you'll know if you need one of these things or not.
More information
RetroKits website.
More from RetroKits.
https://www.gearnews.com/manufacturer/retrokits/
http://www.hobbytronics.co.uk/usb-midi-converter
MIDI USB to DIN Converter
The MIDI USB to DIN Converter allows you to connect a USB midi device to standard MIDI equipment that uses 5-pin DIN connectors. Many MIDI devices now connect via USB, but if you don't have the facility to accept USB devices in your equipment, then this adapter will convert the USB device to standard MIDI DIN connectors. So you can connect a USB peripheral (such as a keyboard or synthesizer) to older equipment that only has a 5-pin DIN connector (such as an amplifier).
It translates the USB MIDI data packets to/from MIDI Din at the MIDI baud rate of 31250.
Use your USB MIDI device without having to connect it to a computer.
Features
Converts USB MIDI device to MIDI Din
Operates at 31250 BAUD
Optional Configuration Settings
Filter out MIDI Realtime messages
Filter MIDI Channel data
Dimensions: 6.5cm x 6.5cm x 2.68cm (H)
Supported Devices
We have a list of known supported devices
http://www.hobbytronics.co.uk/midi-supported-devices
Un-Supported Devices
Some Complex MIDI devices use a built-in USB Hub. These MIDI devices are not supported and will NOT work with our MIDI USB - DIN Converter. You can determine if your device has a built-in hub by running the free Windows program USB Tree Viewer.
If, when you plug in your MIDI device it appears as a new Hub plus one or more devices then it will not work with our MIDI - USB Din Converter.
Connections
Power to the device is supplied via the mini-USB connector and supplied cable. A suitable 5V USB power source is needed which could be a computer or seperate mains adapter. Because mains adapters vary throughout the world we don't supply one, however a suitable mains adapter for use in the UK can be found here UK Mains Adapter
http://www.hobbytronics.co.uk/psu-5v-usb
If you want to make your own MIDI Din cables we have suitable MIDI DIN plugs and suitable 4-core cable
http://www.hobbytronics.co.uk/4-core-signal
Configuration
The following configuration options are available for the MIDI software
[NEW] - As of software V1.18 command mode is now inactive by default. The reason is that if you have the converter connected to MIDI IN and MIDI OUT but no USB MIDI device attached, then serial MIDI IN data received would be echoed back out on MIDI OUT.
So, in order to get into command mode you must do the following..
1. Boot up the converter without a USB MIDI device attached
2. Send two consecutive dollar characters "$$" in the first 10 bytes of serial data. If $$ is not received within the first 10 bytes, a reboot is needed to try command mode again.
Configuration is not necessary for normal operation, however the following Configuration commands are available. Connect the MIDI Converter to a computer using the supplied mini-USB cable and run a terminal program set to 31250 BAUD. The Help screen and configuration settings can only be made when there is no MIDI device attached.
FILTER <value>   Filter incoming MIDI Channel data  [0-OFF|1-16 Channel to be filtered]
REALTIME <value>   Turn ON/OFF MIDI REALTIME messages [0-OFF|1-ON] - Default is ON
HELP or ?   Display Help Screen
FILTER
The FILTER option allows you to block ALL incoming MIDI channel data received on the MIDI DIN IN connector EXCEPT for the MIDI channel selected.
This is useful for MIDI Effects devices which run in OMNI mode only (which means the effect would be applied to ALL channel data)
REALTIME
This option allows you to turn MIDI Realtime messages On or OFF. The default is Realtime messages ON
Documents
MIDI message format
http://www.hobbytronics.co.uk/datasheets/9_MIDI_code.pdf
Sparkfun MIDI Tutorial
https://learn.sparkfun.com/tutorials/midi-tutorial/hardware--electronic-implementation
Arduino Board as basic MIDI synthesizer - Create a basic MIDI Synth using an Arduino Board
https://github.com/dzlonline/the_synth
MIDI Player Tutorial using Teensy 3.1
http://www.hobbytronics.co.uk/midi-player-tutorial
USB Host Serial MIDI Connections - Connecting the Serial port to serial MIDI devices
http://www.hobbytronics.co.uk/datasheets/ht/USB_HOST_MIDI_Connections.pdf
MIDI Synth Project - See our project to make a MIDI Synthesizer
http://www.hobbytronics.co.uk/midi-synth
Program Updates
To upload the Software to the MIDI USB - DIN Converter you will need to use the ds30Loader program. See the USB Host Board product page for more information on this.
New software versions can be downloaded from the USB Host MIDI product page
http://www.hobbytronics.co.uk/usb-host-midi
http://compasflamenco.com/midi-c-3/midi-usbusb-p-4.html?zenid=vwNPo2-No-UmMiMPY2FS00
USB MIDI-USB is a device developed by Sevilla Sof", which allows for a quick and secure MIDI connection between two hosts. For example, connect an iPad to a Mac a Mac to a PC or any combination of these. MID USB-USB is a USB MIDI Class Compliant device at each end that runs on any operating system without installing drivers, plug and play: Windows, Mac OSX, Linux, iOS, Android, ...
It consists of 4 bidirectional MIDI ports that applications running simultaneously can connect with each playing each different port functions.
To recreate a similar MIDI connection, we would need eight standard USB MIDI devices, four in each host connected together with eight wires and corresponding DIN adapters male-female and power supplies maybe ...  MID USBI-USB is that but 12 times more faster and the size of a flash drive.
Box Contents:
- MIDI USB-USB interface.
- USB extension cable 35 cm.
VERY FEW "USB Host to MIDI I/O" adapters support an External USB HUB
I only know of this brand from SPAIN that supports external USB HUBS
SevillaSoft UHMR
http://www.sevillasoft.com/news.php
UHMR is an interface that allows us to interconnect USB compliant and MIDI MIDI devices without the need to use a computer as a bridge between them. It consists of a USB B type connection for powering or programming the device, eight LEDs indicating the USB connections, two leds for the DIN MIDI input and output, two push buttons for various functions, a switch for programming, a USB HOST input and a DIN MIDI input and output.
The USB HOST input supports a USB HUB (or two in cascade) where we can connect up to eight USB compliant MIDI devices (controllers, keyboards, sound modules, MIDI interfaces, etc ...) and communicate them with each other or with the input and DIN MIDI output. In case of need, if we do not have a computer at any given time, the system can be configured with the two push buttons and the LED indicators following the instructions in the manual. Although it is much simpler and intuitive to program it with applications:
QuoteProvide MIDI in and MIDI out jack
USB MIDI Host is powered by 5V power supply
power adapter included
NOTE:Kindly refer to the user manual provided as a PDF manual in the product description section
https://www.amazon.com/Midiplus-USB-MIDI-Host-midiplus/dp/B074NGTGHN/ref=sr_1_4?keywords=USB+HOST&qid=1572112688&sr=8-4
Review from JiveTurkey
https://www.vguitarforums.com/smf/index.php?topic=17360.msg162394#msg162394
The MIDI PLUS USB-MIDI-Host box works exactly as I thought it would. The housing is solid but the front and back face where the ports are is a thinner material. Not a dealbreaker, but just know up front if you want to order one. Used it to drive my Roland synth without any real issue. Had to change a few settings in hardware mode on the FTP itself. Couple of playing technique adjustments to be made (aka not much legato) but overall pleased.
Quote from: yop44 on November 05, 2020, 11:09:41 AM
Has anyone tested this midi host with a Boss Katana?
I think this one is the same : https://www.thomann.de/fr/miditech_usb_midi_host.htm and is available in Europe.
Only one USB host to MIDI converter box works with Katana
Primovasound MIDX-20
https://www.vguitarforums.com/smf/index.php?topic=22630.0
yop44
Hi,
I'm confused. In your picture the midi controller is connected to the MIX-20 via USB.
What I'm trying to do is to use my FCB1010 with my Katana 100 MKII
Currently I use my computer as a Midi Bridge and it works great.
But my goal is to have this setup : FCB1010 -> midi -> Midi Host -> Usb -> Katana
I could also upgrade for a Katana Artist, but not for now...
Quote from: yop44 on November 05, 2020, 11:46:03 PM
Yes, the MIDX-20 will do that, it has 5 pin midi port and 2 x USB ports.
yop44
Thank you,
I guess I'll have to updgrade to Katana Artist  :)
Quote from: yop44 on November 05, 2020, 11:56:10 PM
Thank you,
Or Katana Head
But MIDX-20 is more versatile and deeper control options than either above
CAMOLA DOREMIDI High Speed USB MIDI Host Box MIDI Interface Converter (UMH-20)
1. This USB MIDI HOST Box has a standard high-speed USB2.0, which hasthe characteristics of strong compatibility, fast transmission rate and highstability.
2. The USB MIDI HOST Box has a firmware upgrade function and is perfectlycompatible with all devices with USB MIDI interfaces.
3. Update Key: Support firmware upgrade, compatibility upgrade for special MIDI devices.
Specifications:
Type: MIDI Box
Model: UMH-20
Material: Aluminum alloy
Colour: Black
Features & details
🕵️ USB-A Interface: Standard high-speed USB MIDI HOST interface (USB2.0), used to connect USB MIDI devices and supply power to the USB MIDI devices.
🕵️ USB-B Interface: used to power the product, the power source comes from an optional standard USB DC5V power adapter.
🕵️ MIDI 5-pin Interface: One-in and one-out 16-channel standard MIDI interface for high-performance FTP processing.
🕵️ Indicator Light: product power indicator light, USB working indicator light, MIDI output/output indicator light.
🕵️ High Compatibility: USB Host Compatiblewith all USB MIDI devices USB2.0/USB1.0/USB1.1,MIDI DIN Compatiblewith all musical instruments with MIDI standard interface.
Product information
ASIN   B08R6XFJ2R
https://www.amazon.com/gp/aw/d/B08R6XFJ2R?ref=ppx_pt2_mob_b_prod_image
Quote from:  Bluesbird on February 15, 2021, 01:06:00 PM
Rio MIDI USB Host Interface
https://reverb.com/item/38837528-rio-midi-usb-host-interface-white
RIO USB to MIDI OUT is only one MIDI OUT jack and not bi-directional ( lacks a
5 pin MIDI Input)
JoBoss
Quote from: admin on February 15, 2021, 12:36:13 PM
Specifications:
Type: MIDI Box
Model: UMH-20
Colour: Black
Features & details
Product information
ASIN   B08R6XFJ2R
Can I use this to connect a Boss GP-10 with FCB1010 (and we all know, the GP-10 is not class compliant........).
Quote from: JoBoss on February 15, 2021, 10:10:33 PM
It does not state anything about Boss/Roland, so I would assume only USB Midi class compliant devices,
unless someone can claim to have used this successfully with a Boss USB device.
Recent trend on mini Looper pedals (Cuvave, MeloAudio, Lekoto, Playwell)
USB Host remote control pedal  -( also serves as Bluetooth Page turner pedal) but might point a path for control of other products via USB
https://www.amazon.com/gp/product/B085QHX6DX/ref=ox_sc_act_title_2?smid=A1NN3I1IXVNAXR&psc=1
above is designed to work with these mini looper/ tuner pedals (Cuvave is OEM)
Playwell Looper Pro Effect Pedal with Tuner - 9 Full Songs Storage for Memories and 40 Minutes Recording - WAV Hi-Res Music Export - Infinite Superposition
https://www.amazon.com/gp/product/B08PCK6QHY/ref=ewc_pr_img_1?smid=A1NN3I1IXVNAXR&psc=1
same pedal as above rebranded by others
https://www.amazon.com/LEKATO-Guitar-Looper-Station-Electric/dp/B083WGXCD4/ref=pd_sbs_2?pd_rd_w=smwc2&pf_rd_p=3ec6a47e-bf65-49f8-80f7-0d7c7c7ce2ca&pf_rd_r=AE7XWHWFYEXD00ZY34J5&pd_rd_r=26dbc3bb-ffe1-4728-b1de-8c168e02d97f&pd_rd_wg=49jpL&pd_rd_i=B083WGXCD4&psc=1
https://www.amazon.com/LEKATO-External-Switching-Function-Collection/dp/B08LY9LZBT/ref=pd_sbs_18?pd_rd_w=v45EC&pf_rd_p=3ec6a47e-bf65-49f8-80f7-0d7c7c7ce2ca&pf_rd_r=S3118M7GA0ADF2B41QEK&pd_rd_r=7c92762b-7be6-46b1-99b2-398f930d64ab&pd_rd_wg=5rMOr&pd_rd_i=B08LY9LZBT&psc=1
iConnectivity Interface with 4 in x 4 Out 5-pin DIN-MIDI Ports (mioXM)
Price:   $249.99  & FREE Returns
style: mioXM
4 in x 4 out 5-pin DIN-MIDI ports
4x USB-MIDI Host ports support multiple USB-MIDI CLASS COMPLIANT devices
Ethernet RTP-MIDI Network port - 12 virtual network ports can easily be assigned to onboard DIN and USB ports as well as any other connected computing devices. These make all MIDI devices accessible to Mac, PC, and mobile computing devices via a single cable.
Connect multiple computers via expandable virtual network ports
USB Computer port supporting Mac & Windows connectivity
Plug and Play - no drivers required thanks to class compliant connectivity
Capacitive touch control panel
Up to four user-definable presets can be stored and recalled from mioXM's control panel
iConnectivity's Auracle configuration software (downloadable for Mac & Windows) makes it simple to create and save filtering/routing/merging presets
Connect iOS devices via CCK to mioXM's USB device port or WiFi (using 3rd party Wi-Fi ethernet hub), or wired ethernet connections
