FLUX:FX by Adrian Belew
Started by cell7, June 30, 2014, 03:56:40 PM
Quote from: Brak(E)man on September 04, 2017, 02:18:20 AM
So what happens if you change tempo randomly with midi ( midi clock or tap tempo )
I can't try since I don't have a midi for my iPad. ( half and double tempo works fine with rapid changes )
Is there anyone who'd like to give it a go ?
cell7
I've tried it - it DOES work but pushes the love a bit on the CPU (particularly on the 4 and earlier). Might work fine on the pros.
Quote from: cell7 on September 07, 2017, 10:33:21 AM
Is the result is that different from when you tried to implement randomized tempo ?
cell7
It was the same. We chose to not go further with the randomized tempo to remove the stress from the app.
Quote from: cell7 on September 07, 2017, 11:44:24 AM
Ok Thanx for the info, anyway it's a great app and I'll be spending some time with it
for a while making some noise. Next try out will be one my fretless guitars.
As said , I haven't been this inspired by new gear in years.
It highly recommend it to anyone who hasn't tried it.
Quote from: Brak(E)man on September 01, 2017, 03:31:46 PM
It's a bargain
The most fun I've had with
new gear in years.
Since I don't have a stereo sound interface for iPad I can't try myself and I can't find any reference in the manual or online.
So I'm asking , is the Flux:FX in true stereo ( all fx or some ) ?
QuoteSince I don't have a stereo sound interface for iPad
what is your current iPad Audio interface?
cell7
I believe we made every effect discrete stereo... but to be honest I never tested all of them with independent signals. I will try to do so when I'm back in the lab.
Btw - in case you didn't see it, we have updated FLUXFX to 64bit so the app will work on iOS11. Finally...
Rhcole
That's good news! I bought it 2 weeks ago hoping that it would be available for 11.
Given that Apple MAKES us upgrade...
cell7
One thing - some users have reported an issue with audiobus not functioning quite right so this is something we will look into. interapp audio (ie AUM and GarageBand etc) are fine.
Rhcole
I haven't upgraded yet- should I hold off? Don't really want 11 anyway, grumble grumble...
I'm not updating to IOS 11 - bulk of my music apps are not converted to 64 bit, and some may never get converted to work with IOS 11
Quote from: cell7 on September 22, 2017, 01:00:20 PM
Have you had a chance to try it ??
Any plans on a MacBook version standalone and Au ?
It should work with the track pad
cell7
 Unfortunately not at this stage. The programming language are too different :(
Quote from: cell7 on January 09, 2018, 04:32:42 AM
Someone should make an app for porting  ;D
It would be so nice not to have to use the iPad when recording straight into MacBook though.
BackDAWman
I would love a vst version ;D
Since my mail to info@noii.se is not getting through
I'll ask here what to do and if anyone else has this issue
After update to the latest version
Flux will not " wake " up when using it under Audiobus 2
(It's still working at times but not connecting to Audiobus
but still sounding in Audiobus)
Together with JamUp and loopy HD
and input from irig first version
iPad 9,7 iOS 10.3.3
The other apps works fine and it worked fine before updating flux
_________________________________________________
Please comment above this line.
The following information helps us help you.
Please do not remove it.
App Version: FLUX:FX 1.1 (1709113)
iOS Version: 10.3.3
Device Model: New iPad: iPad6,11
Latency: 128
I/O Route: Headset Microphone > < Headphones
Tested the same setup on a iPad 4 with the same result.
So the flux update must be the problem.
Is it working for anyone on ios 11 ?
To go back to the last flux version before the update, do I delete the app from the iPad
and sync with the backup on iTunes that I did before updating ??
Right or am I missing something obvious as usual :-?
Quote from: Brak(E)man on February 25, 2018, 03:19:15 AM
AFAIK there is no way back with IOS apps. Sometimes completely removing the app and reinstalling it fixes issues...
I did go back on an iPhone, but I'm not 100 how I did it but I think it was like I asked
Quote from: sixeight on February 25, 2018, 04:11:21 AM
You're correct that doesn't work anymore , it did on my iPhone 4 and OS X 10.6
I guess Apple doesn't want it to be easy nor flexible anymore.
