GR-55- Any way to get patches without downloading?
Started by Spatzi, June 22, 2017, 06:34:53 AM
Spatzi
Has anyone written out any of their patch settings so I can try them wothout using pc or software?
Jim Wintringham
An idea for you.... look at the 'built in' patches that are close to sounds you want. Then, play with the settings through the edit mode. If you get something you like, then save it to the user patch area.
Roland GR-55
Wechter Pathmaker PM 7354
Brian Moore i91.13 (China)
Zoom G2
Ventris Dual Reverb
Roland kc-300
Quote from: Spatzi on June 22, 2017, 06:34:53 AM
Yes on a chalkboard after I misbehaved in GR-55 Programming class ;)
If you have access to a PC or a Mac or a Linux box you can use gumtowns GR-55 floorboard editor download all patches from here , load them into the editor without the GR 55 present
Gumtown has included a utility in the GR-55 Floorboard Editor that can make a text file patch listing dump with all parameter settings
then you could Print that list out and hand enter each GR-56 setting when you get access to your GR 55
but it'll be much simpler if you can find a cheap laptop and use it with your GR 55 with Guntowns GR-55 floorboard editor
More details
https://www.vguitarforums.com/smf/index.php?topic=2951.0
And download all GR 55 help files here
https://www.vguitarforums.com/smf/index.php?action=downloads;sa=downfile&id=86
