Gr55 + fcb1010 + iPad = problem
Started by looper, January 28, 2015, 04:52:27 AM
looper
Hello everyone,
I'm midi communication problem between the FCB1010 and the iPad mini retina when I turn simultaneously the GR55. in USB hub are the two midi interfaces for both pedals and the UCA222 to GR55 audio shipment to the iPad via the lightning adapter. Interestingly, the interfaces work well separately, but when linked together FCB1010 no longer responds.
The USB hub is not powered. suspect of a power outage for 3 connections or some internal midi conflict. what do you think?
looper
Quote from: Elantric on January 28, 2015, 07:21:50 AM
Use a powered USB Hub
ok, but I have doubts about the voltage and amperage to avoid damaging the equipment. I have at home a powered source of 4.5V and 600mA and other 5V and 350mA. Which one is most appropriate in this case?
You will need an official Powered USB Hub, most come with a 5VDC @2.5Amp supply
Many are listed here
https://www.vguitarforums.com/smf/index.php?topic=10326.0
This one works well
Pluggable 4 port powered hub $20
  http://www.amazon.com/gp/product/B005P2BY5I/ref=oh_details_o09_s01_i00?ie=UTF8&psc=1
Features
USB 2.0 4-Port High Speed Hub. Includes a robust 12.5W 5V 2.5A power adapter. (US AC Wall Outlet Plug, 100-240V 50/60Hz)
Hub enables connecting 4 additional USB devices. Forwards and backwards compatible with all USB 3.0, 2.0, or 1.1 host controllers and devices on Windows, Mac, and Linux/Unix computers at USB 2.0 speeds up to 480 Mbps. Transfer rates are device and USB host controller dependent. Fully plug and play, devices can be hot-swapped, supports USB over-current protection. Requires no driver installation (although individual devices may require drivers).
Apple notes: Note that some devices such as the Apple SuperDrive look for Apple-specific signaling and will not work when connected through any USB hub.
Hub supports the USB Battery Charging 1.2 Standard (BC 1.2) for unique charge and data sync functionality that most hubs do not have. Charge and sync only works with BC 1.2 compatible devices such as the Apple iPhone 5s, 5c, 5, iPad Retina, Air, Mini, (Apple 30 pin dock connector iPads will not charge), plus various Android and Windows devices are also supported. Because only some devices support BC 1.2, check compatibility list below before purchase.
Master blue power LED. Sleek piano black glossy finish. Compact and portable design.
Product Details
Manufacturer: Plugable Technologies
Manufacturer reference: USB2-HUB4BC
Product Dimensions: 2.5 x 1 x 1.5 inches; 1.1 ounces
Shipping Weight: 7.2 ounces
ASIN: B005P2BY5I
looper
Quote from: Elantric on January 28, 2015, 08:43:55 AM
This one works well
Ok, but the problem is that I am a small town in Brazil and the best USB hub that I found here, has an input for external power supply, so the question. I have several power supply stored in the drawers of other equipment and old cell phones, perhaps some work. Now found a 5,7V and Nokia 800mA.
USB is very specific
Must use a power supply with exactly
+5VDC and at least 1Amp (1000mA)  current rating
looper
Quote from: Elantric on January 28, 2015, 09:24:52 AM
Ok, thanks
