No output on one string - Help!
Started by coldsummer, October 27, 2012, 08:17:59 AM
coldsummer
Hi everyone, first post and I'm asking for help, sorry. But by way of a short introduction, I've had a VG99 for several years and recently acquired a GR-55, both incredible units. I have been using my Brian Moore C90P.13 RMC guitar but wanted to try a GK equipped guitar to see if it sounded any better and to prevent any accidental damage to the BM.
Well, I recently bought a used Fender mex Roland ready strat with the built in gk pickup from fleabay. I finally got round to trying it out with my GR55 and found that the low E string has no output. I'm presuming the gk is fritzed but does anyone have any suggestions, or things I could check or try out? Any help/advice gratefully received.
Of course I already left good feedback for the seller :: ::)
papabuss
Hi coldsummer
when I sometimes have the same problem I just disconnect and connect the GK3 cable . Turn the volume GK3 knob to zero before.
If this does not help look here:
https://www.vguitarforums.com/smf/index.php?topic=7005.msg48866#msg48866
coldsummer
Thanks Papabuss, I'll give that a try.
coldsummer
Well that seemed to do the trick :)
If only everything was that simple!
Thanks again papabuss.
ishfar
hello friends,
i've just bought the gc-1 and tested with gr-55. everything is ok but on the high e string, there is no voice and no signal. i am so sad, how can i fix the problem? thanks
Please post once
Common problem
Clean the 13pin cable contacts or replace the 13 pin cable
details here:
Roland GK 13 pin Cable Maintenance Tips.
If above steps fail -  contact Roland Support for Warranty
ishfar
yes i read this post but i've got another guitar with external gk pickup, it works great and doesn't any problem, i checked the cables but i didn't see anything
ishfar
well i clean the 13pin cable with deoxit and there is nothing changed :'( i will send the guitar to the manufacturer
