GR-55 Patch Loader - a real-time live midi patch file loading software
Started by gumtown, March 16, 2017, 07:04:24 PM
Been tinkering with the GR-55 and trying to devise a way to have less tone dropout on patch change.
A better way, rather than patch changing, is to have the GR-55 remain itself on the same patch, and have
new patch data loaded into the GR-55.
This method has an almost seamless change.
So I present
"GR-55 PATCH LOADER" software,
a midi controlled patch file backup/bundle loader.
Where you plug in an external midi foot controller (or any midi patch change device),
make a patch backup file of your GR-55 (only the first 128 patches are accessed), and load the file into the software,
select your midi input and output devices, and away you go....
https://sourceforge.net/projects/grfloorboard/files/GR-55%20Patch%20Loader/
there is one for windows, one for mac Sierra, and one for Linux Ubuntu 64.
vtgearhead
Is this strictly a GUI application?  Would be great to run it headless in the background on RaspberryPi or Beaglebone.
Should be able to run it headless once you have initially used a monitor to setup the patch file bundle and the midi I/O ports settings.
These are saved to a preferences file and when the software is run next time, the patch file and midi settings are restored on start up.
Nicolher
Thanks !
Still have to find the perfect midi control pedal for me but will try this for sure
8)
Ps : Shouldn't this be pinned ?
