Answered: Can I replace RMC saddles with Graphtec saddles.
Started by gibvictory, August 29, 2017, 06:40:10 PM
gibvictory
I can't find the post I made some time ago and in fact it was unearthed by someone else wanting to know the same thing. I originally asked if they were interchangeable. Well, I went ahead and had someone swap them out for me and sonically it all worked out pretty well. I'm using a GR55 and forget at the moment what the system setting is but you can choose your setting based on the kind of pickup you're using, GK, RMC or Graphtec. Going back and forth between the Graphtec and RMC setting there seemed to be no difference between the two. I guess because I now have a hybrid of the Ghost saddles and the RMC preamp. I just adjusted a few things and don't notice any difference from the removed RMC saddles to the Ghost saddles. I'm still curious if anyone else has done this.
Quotecan't find the post I made some time ago and in fact it was unearthed by someone else wanting to know the same thing.
Check your profile page
Here is a link to ALL your posts
https://www.vguitarforums.com/smf/index.php?action=profile;area=showposts;u=13318
This was your prior post
https://www.vguitarforums.com/smf/index.php?topic=21159.msg152360#msg152360
Test your GR-55 DSP created alternate tuning performance
Compared to RMC Piezos , I get more warbles with graphtech and more palm muting noise because the graphtech saddles respond to the entire surface area of the saddle and more prone to suffer adjacent string crosstalk and errant mistracking GTR to MIDI ghost notes on D & G strings
