Godin style Spring loaded Momentary toggle Switch replacement for S1/S2
Started by Elantric, April 10, 2008, 12:04:04 PM
Re: Momentary toggle replacement for S1/S2
I use these:
http://www.itcelectronics.com/product_info.php?cPath=1170_1388_1465&products_id=3493
Philmore Miniature Toggle Switch SPDT (ON)-OFF-(ON) 5A @ 120V AC
Part No.: 30-10008
Part No.: 30-10008
$2.59
Red switch cap is removable.
telengard
Quote from: sustainiac on April 10, 2008, 12:04:04 PM
I use these:
Part No.: 30-10008
Hehe, I bought one yesterday.  Looking forward to re-doing my pickguard.  Thanks for the info!
Did you happen to see my question about the volume pot?  I'm gonna fiddle around but wasn't sure if you had possibly tried it.  I'll start a different thread if that's more appropriate.   :)
~telengard
Still stuck in the 1980s.  My mame cabinet, mini home studio, and 8 bit game room:
www.briansturk.com
chipstar
Has anyone found this part in solid black? I've found one that is a different voltage but it is critical that I find this part in black in the next week or so. If not, the S1/S2 buttons get installed which would be unfortunate.
later,
Chipstar
I use a Sharpie Marker to make chrome switches black - Automotive  touch up  paint works too. Use a Q tip and dont get the inner workings jammed up with paint.
Once you have a momentary toggle switch for the S1 S2 function - You'll be spoiled and never want to use those ugly HUGE Roland GK Kit momentary switches ever again. They seem more suitable as Flipper switches for  an Arcade Pinball Machine and way too large and ugly IMHO.
chipstar
Steve Moser, at Moses Graphite, suggested using black nail polish since it comes with a small applicator brush. I can just see myself at the cosmetics counter looking at different shades of black polish. What fun!
Here's the deal, guys. I've found a few sites that may have it and I've even contact Ibanez. As soon as I find a vendor for this part, I am going to post the link so that no one else has to search for this part in the future.
later,
Chipstar
philflood
You might want to check with Godin for a source. My LGX-SA has a black momentary for the S1/S2 function.
chipstar
Dude,
Thanks for this. I'll check with them too.
later,
Chipstar
telengard
Quote from: sustainiac on May 01, 2008, 07:17:08 AM
Once you have a momentary toggle switch for the S1 S2 function - You'll be spoiled and never want to use those ugly HUGE Roland GK Kit momentary switches ever again. They seem more suitable as Flipper switches for  a Pinball Machine.
So true.  I finally have my guitar back together and I like this MUCH better than the 2 separate buttons.
I also managed to utilize the same volume pot for on my strat for the GK-3 (push pull w/ some resistors).
~telengard
www.briansturk.com
chipstar
Hey Guys,
No luck so far. Neither Ibanez nor Godin carry that part in black any longer. I was told that Digikey may have it but I have yet to confirm this. Any ideas would be appreciated.
later,
Chipstar
chipstar
I just ordered a couple of these switches from Parts Express. They are being shipped to Lay's Guitar to have them installed. Man, I can't wait. This guitar is going to be hot. Sustainiac, I am so grateful for the insight.
thanks,
Chipstar
MCK
Anyone seen these on/off/on momentary switches in gold? Thanks
MCK
Can't see the photo on the first one but both should work by definition. You do not need DPDT. SPDT will do.
But be sure its momentary  - look for (on)-off-(on) in the description
dayn
MCK,
Does it matter how many amps they are? Some are 20A, some 6A, some 5A, etc.
Meltdown
Visit my website!
http://www.tachyonmusic.com
embers
I fitted white covers from http://www.aircraftspruce.com/catalog/elpages/toggleswitchcvr.php to the momentary and three way switches. I am about to change the volume to a stacked concentric pot so that I can reintroduce my mid boost circuit for my mag pickups. That way I will have both volumes in the normal top position, mid boost then tone. I think this gives a much cleaner and very functional look than using the buttons.
I used a momentary switch for patch selection that is the same size as the mag/hex switch.
When I do a GK-3 Internal install first thing i do is throw away the LED and and the S1 / S2 switches ( Better suited for a Pinball  arcade game Flippers IMHO)
For S1 / S2, I use a small Spring loaded Center off Momentary Toggle Switch known as "(on)-off-(on)" type.
https://www.vguitarforums.com/smf/index.php?topic=654.0
Same type switch is used on the Godin LGX-SA
Hey, I like that idea of one switch. I used 2 little round momentary switches on my custom. They are small domes and are barely visable on my black guitar.
I should add that lately instead of using the one singular spring loaded "center-off" toggle switch to replace the GK-3's internal kit S1 and S2 momentary switches,  I'm preferring keeping S1 and S2 as independent separate momentary switches.
This is due to using the RackVax, which uses unique combinations of pressing BOTH the S1 and S2 for advanced remote control of the RackVax.
If S1 and S2 function used one singular spring loaded "center-off" toggle switch, it would be impossible to control the RackVax to full advantage.
Read the RackVax Manual for details.
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=3928.0;attach=3707
More about RackVax
https://www.vguitarforums.com/smf/index.php?topic=3928.msg26514#msg26514
datsunrobbie
How did your conversion to a concentric volume pot work out? I have been unable to locate a combination 50K/250K pot to use for the conversion. How did you get the values right? Or will the GK work with a 250K volume pot?
trev27
What switch do i need to replace the 2 big black buttons for the GK 3 Kit?? I am sure its a SPDT with either    off on off     or     on off on   but which one?
Also would it be a latching or non latching??
Cheers for any help
Takamine EG 530 electro Acoustic
Ibanez RG2610
Ibanez RG1570
Aria PE DLX
datsunrobbie
http://www.ebay.com/itm/10-BRAND-NEW-MINI-TOGGLE-SPDT-ON-OFF-ON-MOMENTARY-SWITCH-6A-6-A-AMP-/380401542325?pt=Guitar_Accessories&hash=item5891b2e4b5#ht_4074wt_1297
These are the switches I used in my last GK-KIT install to replace the S1/S2, from this seller. They sell smaller quantities, but given the option of 2 for $5 or 10 for $10 I went ahead and bought 10. MOMENTARY is critical, so it drops back to center after each click.
Just google search on "(on)-off-(on)"
The parenthesis denote the required momentary action
http://www.google.com/search?client=safari&rls=en&q=(on)-off-(on)&ie=UTF-8&oe=UTF-8
see the part # M123 here: ($1.05 + shipping)
http://www.led-switch.com/Miniature%20Toggle%20Switch.htm
