GT-100 - How to connect external foot volume pedal FV 50L?
Started by marziali, April 05, 2017, 05:11:46 AM
marziali
Hi,
How do i have to connect foot pedal FV 50L to GT 100?
In which input of FV 50L do I have to plug the jack?
And which options of BOSS GT 100 do I have to set up?
Thanks in advance for your help.
Alex
https://www.boss.info/us/products/fv-50h_50l/
If you mean "How do I use the FV-50L as a Stereo Volume pedal on output of  GT-100 ?"
You can connect the FV-50L as a final stereo volume pedal for GT-100, by connecting the GT-100 Left / Right Outputs into the FV-50L , then output of FV-50L into your amplification system
If you mean "How do I use the FV-50L as an Expression Control pedal for GT-100 CTL Jack ?"
Not possible
Compatible Expression Pedals are listed here
https://www.vguitarforums.com/smf/index.php?topic=33.msg60#msg60
marziali
Thanks a lot for your answer. Obviously I want to use FV 50L as volume pedal but I thought that you have to use Sub Exp input.
Best Regards.
Alex.
