Author Topic: VGuitarForums Glossary of Terms  (Read 945 times)
Offline Elantric
« on: February 26, 2015, 07:34:04 AM »
Just a mention to folks who are new to VGuitarForums
In thousands of posts All over the site, we mention several acronyms which can be confusing to Guitarists new to the DSP Modeling/ Synth scene : "FTP", "RPI", "COSM" , etc
I'm posting this because I recently had a conversation with another guitarist who had once stumbled upon our site while doing a web search , and he told me:
"You guys at VGuitarForums are too high tech, with all your talk of moving files using FTP ("File Transfer Protocol"),  in and out of your internet guitars!, Id rather just play my real guitar"
so here is the
DIN Connector
https://en.wikipedia.org/wiki/DIN_connector
A DIN connector is an electrical connector that was originally standardized by the Deutsches Institut für Normung (DIN), the German national standards organization. There are DIN standards for a large number of different connectors, therefore the term "DIN connector" alone does not unambiguously identify any particular type of connector unless the document number of the relevant DIN standard is added (e.g., "DIN 41524 connector"). Some DIN connector standards are:
DIN 41524, for circular connectors often used for audio signals
FTP = Fishman TriplePlay Wireless MIDI guitar System
http://www.vguitarforums.com/smf/index.php?topic=8427.0
RPI = Raspberry Pi $35 small single board computer from UK, that member LouLea discovered actually works as a USB Host to 5 pin MIDI converter for many recent Roland /Boss products with no 5 pin MIDI
http://www.vguitarforums.com/smf/index.php?topic=11998.0
GK , GK-13 = The Roland 13 pin guitar interface that transports separate analog signals ( one per string) and some Variable DC Voltage Controls ( GK-VOL, Guitar/Mix/Synth Status, and remote Switches ( S1, S2) and +7V,-7V DC power
http://www.sweetwater.com/insync/gk-ready/
http://www.sweetwater.com/insync/13-pin/
GK-3 - Roland Guitar pickup for mounting on Steel string guitars
http://www.roland.com/products/gk-3/
GK-3B - Roland Bass pickup for mounting on Steel string Bass guitars
http://www.roland.com/products/gk-3b/
S1 = GK-3 Momentary Switch  #1
S2 = GK-3 Momentary Switch  #2
US-20 = Roland Unit Selector A/B/Y Selector switch for feeding two separate GK-13 Synth/ Modeling Processors
http://www.roland.com/products/us-20/
GP-10 = Boss GP-10 VGuitar System in a small footprint released summer 2014
http://www.vguitarforums.com/smf/index.php?topic=11796.msg85343#msg85343
GPI,GPIO = General Purpose Input Output, typical term used in robot control systems to describe an array of remote switch inputs and Open collector transistor controlled outputs
http://en.wikipedia.org/wiki/General-purpose_input/output
http://www.sweetwater.com/insync/gpi/
COSM = Roland DSP Composite Object Sound Modeling
http://www.vguitarforums.com/smf/index.php?topic=88.0
http://www.sweetwater.com/insync/cosm/
RMC  = RMC PIEZO PICKUPS - high quality Piezo pickups for guitars
http://www.rmcpickup.com/
GHOST  = GraphTech Ghost Piezo PICKUPS - Piezo pickups developed my Mike Christian (Black Ice passive distortion)  for guitars
https://www.linkedin.com/pub/mike-christian/10/31/9b0
http://www.graphtech.com/products/brands/ghost
VDI = Line-6 Variax Digital Interface is the RJ-45 Ethercon cable used to connect Variax to Line 6 Gear ( Vetta Amp, POD XT Live, POD Pro, HD500X, FireHawk)
TVF = Time Varient Filter used on many Roland Synths
http://www.sweetwater.com/insync/tvf/
TVA = Time Varient Amplifier used on many Roland Synths
http://www.sweetwater.com/insync/tva/
DI Box  = "Direct Inject Box" Device used to connect a high-impedance, line level, or unbalanced signal to a low-impedance microphone level balanced input. Commonly used to connect a electric guitar or bass directly to a microphone preamplifier input.
http://www.sweetwater.com/insync/direct-inject/
JTV = Line-6 James Tyler Variax DSP Modeling Guitar
More Glossary of Terms
MIDI
http://www.2writers.com/eddie/MidiGlossary.htm
Sweetwater
http://www.sweetwater.com/insync/category/glossary/
Line-6 Live Sound Glossary of Terms
http://line6.com/support/page/kb/_/live-sound/stagesource-speaker/live-sound-glossary-of-terms-r97
and
http://www.vguitarforums.com/smf/index.php?topic=7524.msg52656#msg52656
« Last Edit: April 19, 2016, 11:56:07 PM by Elantric »
Offline Headless68
Re: VGuitarForums Glossary of Terms
« Reply #1 on: February 26, 2015, 01:26:27 PM »
I work in the IT industry - the world is full of them, they change daily and get added to daily and they do my head in - not so bothered here though, probably because its something I like :-)
Offline Elantric
« Last Edit: January 09, 2017, 01:19:43 PM by Elantric »
Offline Elantric
« Reply #3 on: April 27, 2017, 11:13:33 AM »
http://www.vguitarforums.com/smf/index.php?topic=20801.msg149719#msg149719
Which one do i need?
For those not familiar with the Roland VGuitar Syetems (VG-8, VG-8EX,VG88, VG-99, GP-10) you need to know this,
it is not a Guitar synthesizer.
It would more accurately be considered a SUPER DUPER effects processor.
A Guitar synthesizer (GR-20, GR-30, GR-33, GR-55 on PCM Tones) can produce more traditional sounds,
like trumpets, piano, drums, violins, organs etc.,
which the Roland VGuitar does not. (Well, it does a few nice ones, but not like a synth)
The Roland VGuitar on the other hand, is  a billion times more sensitive to play feel
and subtleties in your playing than a synthesizer.
Since it works on the sound of your strings, you can do things like
scratch your strings or bang your guitar and you will get sound,
with a synthesizer, the unit will just be confused.
Also, the Roland VGuitar doesn't "track" in the traditional sense of the word.
It is actually processing effects on your actual string sound,
not converting that sound into MIDI data.
Speed metal players have no problem fitting in all those random notes!
« Last Edit: April 27, 2017, 11:16:31 AM by Elantric »
Offline Elantric
« Reply #4 on: October 05, 2017, 01:39:29 PM »
https://www.diyrecordingequipment.com/blogs/news
https://www.diyrecordingequipment.com/pages/explain-like-im-5-audio-concepts-for-beginners?mc_cid=e73a4ddfde&mc_eid=5c40d49aef
"Explain Like I'm 5": Audio Concepts for Beginners
Balanced vs Unbalanced Connections
http://www.diyrecordingequipment.com/blogs/podcast/15851896-explain-like-im-5-balanced-vs-unbalanced-connections-podcast-8
What is the difference between balanced and unbalanced connections?
How does balancing work?
Why do we need balanced connections?
Impedance
http://www.diyrecordingequipment.com/blogs/podcast/15851900-explain-like-im-5-impedance-podcast-9
What is impedance?
How does it affect audio?
What do input/output impedance specs mean?
Audio Levels
http://www.diyrecordingequipment.com/blogs/podcast/16242896-explain-like-i-m-5-audio-levels-podcast-11
What's the difference between "pro" and "consumer" line levels?
Is it ok to plug an instrument into a line level input?
What's the difference between peak and RMS levels?
Audio Filters
http://www.diyrecordingequipment.com/blogs/podcast/16921792-explain-like-im-5-filters-podcast-12
How do filters work?
The (High) Cost of Pro-audio Gear
http://www.diyrecordingequipment.com/blogs/podcast/17515060-explain-like-im-5-why-is-pro-audio-gear-so-expensive-podcast-13
What are the factors that drive the price of professional recording gear?
Why does gear cost so much more than the sum of its components?
Are the prices justified, or is someone getting ripped off?
Opamps
http://www.diyrecordingequipment.com/blogs/news/36492996-explain-like-im-5-opamps
What are opamps?
How do they work?
Do different opamps sound different?
Reamping
http://www.diyrecordingequipment.com/blogs/news/86235652-explain-like-im-5-why-do-i-need-a-reamp-box
Do I really need a deciated box to reamp?
Can't I just connect a cable from my interface to an amp?
Can't I just use a DI in reverse?
Part Markings and Orientation
http://www.diyrecordingequipment.com/blogs/news/eli5-identifying-common-components
How can I tell the value of common parts?
How can I tell the orientation of common parts?
Printed Circuit Boards (PCBs)
What do PCBs do?
http://www.diyrecordingequipment.com/blogs/news/eli5-printed-circuit-boards
What are the layers of a PCB?
How can I make my own PCBs?
« Last Edit: October 05, 2017, 01:43:31 PM by Elantric »
