Roland vg 8... help im new!
Started by fendrix_81, June 28, 2011, 05:25:27 PM
fendrix_81
hi friends,
i dont know if i can write here but i will try..
im buing an old roland vg 8, with the vg8s-1 expansion..
well my question is:
the roland vg8, has problems with the synth sound like roland gr, axon?
can the roland vg8 work rith with roland gk3?
another question: wich other expansion there are for roland vg8?
thx!
The VG-8 is now 16 years old. Actually it should work very well with all hex pickup types, once the strings sensitivity is set.
It is not a "Guitar Synth" nor a Guitar to MIDi converter, thus it has much less headaches and zero problems with "tracking" and no latency when processing and generating some very amazing sounds.
In the Roland VG-8, VG-88, VG-99 - the actual guitar string is the "Tone generator" signal source for all processing - and (unlike Guitar to MIDI rigs) the processed sound output is instantaneous for all strings.
Yes you may use a GK-3 with the VG-8, select the "GK-2A" as pickup type, and adjust the strings sensitivity as stated in the VG-8 manual.
As far as i know the S1 update is the only  upgrade for the original VG-8
Guitarbot
Voice Crystal also released some sound cards for the vg-8.  I don't use it anymore, but still have the sound cards.  Let me know if you are interested in buying them.  Info is here:
http://www.voicecrystal.com/rolvg8.htm
http://www.voicecrystal.com/catalog.htm
fendrix_81
Guitarbot
i wroted you an email
please answer me,
thx!
Guitarbot
