GR55 Midi Offline error message. One reason you might see it.
Started by philjynx, October 10, 2016, 03:33:57 AM
philjynx
QuoteMidi through is ON by default. I didn't even know the MIDI library had through functionality.
Yes. That "feature" also has taken me weeks before I figured it out and disabled it. Most people will never notice because they build an Arduino/Teensy controller with just midi out. But as soon as you go bi-directional, this one will get you...
If midi thru is enabled on your device, and the GR-55 has PC RX and PC TX enabled, this will cause the GR-55 to lock up when sending program change, or changing patch directly with the GR-55.
The PC (program change) message ends up in a continual loopback.
Disable PC OUT on the GR-55, or even better, disable the midi thru on your device.
It makes no difference if it is 5 pin DIN or USB.
