GR-55 - Banjo PCM - Banjo COSM - Accoustic PU
Started by FrankG, March 10, 2011, 10:08:00 AM
FrankG
Attached is my kick at the "Banjo Patch"...
I started with the PCM Banjo Voice 328 , added the COSM Accousitic #14 Banjo Model, enabled 12 st... and finished with the Accoustic pickup as I spend a lot of time toning down the Banjo's harsher tones by lifting the "Dry Guitar" or trying to balance the two (on the GR-20).
The final stage EQ has a neat setting that I'm not quite sure about, but wanted to play with just the same as all of this is new territory to me... :) When I flick it on via FlrBrd55 (GT's app) it certainly brightens up the voicings, but can sound whiny past the 7th or 9th fret (to my ear).
Attached below are the GL5 and a series of screen caps (if these are NOT helpful, pls advise, as there is an element of redundancy given the settings are embedded in the GL5)...
the power to do nothing is tremendous, but it must not be abused...
paults
Thanks for posting! I don't think you need to post the screenshots along with the patch.  Including your description of the patch is is very helpful.
