VG 99 sends doubled Midi Signal into Logic Pro 9
Started by tbuechse, September 07, 2010, 05:00:45 PM
tbuechse
HI,
after some testing I now found that the VG 99 sends a doubled MIDI SIgnal (Score editor in Logic Pro 9 shows two overlayed notes in the Score Editor). I then disconnected the MIDI routings in the system settings (VG99) as well as the VG-99 Main Block which connects graphically to USB. So Logic now receives only the one desired single MIDI Signal. Allright, But...
My questions:
Although disconnecting any possible connection inside the VG System settings, I have a MIDI and Audio SIgnal into Logic Pro via USB
What are the System MIDI/Routing Settings (Page 2 System Menu) then exactly for? Seems I don´t´t quite understand the signal flow, I guess...
Thanks very much for your help
Best regards
Tim
