GK3 volume knob crackles
Started by together, December 16, 2017, 06:44:30 AM
together
GK3 volume knob crackles when changing volume,
Is there any possible fix?
thank you
Quote from: together on December 16, 2017, 06:44:30 AM
thank you
Thats often a result of poor 13 pin contacts
follow steps  in this thread
GK 13 pin Cable Maintenance Tips.
together
The sound crackles when moving the volume knob of the GK3,
Similar to a bad contact of guitar volume pot.
You only have two options:
1: Replace the noisy pot inside the GK, which may be viable if you are a DIY type.
2: Replace the GK-3 pickup
together
Where can we buy these gk volume pots?
Where are you located?
Start by contacting the  Roland Support telephone number in your country
Here is the GK-3 Service info
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=73.0;attach=6628
Roland states the GK-Vol pot is an Alpha P/N#  RV09A-40-15F-B50K
This is a compatible replacement
https://www.mouser.com/ProductDetail/Alpha-Taiwan/RV09AF-40-20K-B50K/?qs=GFacVd7qpzD6LCVA5CDOsA%3D%3D
rolandvg99
Does the GK-3 pot carry audio at all? Thought it was a CV kind of thing controlling DSP assignments? It will however cause static if the ground of the GK cable is bad. Been there. Resoldered the ground and it was gone.
My little Soundcloud corner
together
Thank you the part number,
Is there any problem opening the GK to replace the parts,
There is a couple of GK2s around with the same crackle volume pot problem.
Tony Raven
Maybe just my guess, but "crackle" implies analogue, & that generally means a pot's element hasn't been worked enough to keep it clean. (It's called a WIPER for a reason maybe, eh?)
It's at least irresponsible to encourage replacement for something that merely needs maintenance. ::) Next thing ya know, a new one goes in, & months later is mysteriously showing The Same Damn Problem.
Just a panel-mount mini linear anyway. If I get around to it, I'll look into mil-spec hermetics, but anyone with dialup can probably find one first. :o Not expensive, in any case.
together
Had a couple GK replaced with the same crackle problem.
Any recommendation of maintenance for the GK volume knob.
IF your guitar sits in a tight case, the lid pressure is probably compressing on the GK knob and loosening the centre wiper contact tension.
I recommend checking the case, . . . if that is the case  :P
The pot circuit is analog, where it dials in a control voltage between 0~5 volts.
