SY-300- Parameter dump
Started by cheskylow, October 30, 2017, 12:35:56 PM
cheskylow
Hi
is it possible to make a dump or print of all parameters of a patch?
Maybe in a text file or pdf something like that.
BR cheskylow
You can use an editor that supports JSON format and review Boss Tone Studio for SY-300 .tsl patches
the BTS  *.tsl patch files are CSV ( comma separated variable), and can be imported into Excel
On windows use an app called  Notepad++,
https://notepad-plus-plus.org/
to view files in the Boss Tone Studio assets  directory
C:\Program Files (x86)\BOSS TONE STUDIO for SY-300\_assets\data\
Boss GT-1 examples below:
cheskylow
Great, so I can create a tabel of all parameters of a patch in Excel.
Thanks for your fast answer
BR Ingo
SY-300 FloorBoard, a not quite finished editor, but can display a patch parameter list from the TOOLS menu.
https://sourceforge.net/projects/grfloorboard/files/SY-300/
Tue Oct 31 18:42:52 2017
Boss SY-300 Complete Patch Summary
a list of all parameters with-in this patch.
PATCH COMMON ***********
[Level : Level] = 100
[BPM : Tempo] = 7
[Return Level : Return Level] = 100
[Direct Level : Direct Level] = 0
[Return Phase : Return Phase] = Normal
[Sub Out Level : Sub Out Level] = 100
[OSC Assign : OSC Assign] = A1/B23
[OSC Mixer : Balance] = 0
[OSC Mixer : CH A Level] = 100
[OSC Mixer : CH A Pan] = 0
[OSC Mixer : CH B Level] = 100
[OSC Mixer : CH B Pan] = 0
[OUTPUT Mixer : Balance] = 50
[OUTPUT Mixer : Synth Level] = 50
[OUTPUT Mixer : Synth Pan] = 0
[OUTPUT Mixer : Return level] = 100
[OUTPUT Mixer : Return Pan] = 0
[PATCH Input : Sens] = System
[PATCH Input : Input Sens] = 0
[PATCH Input : Low Balance] = 0
[PATCH Input : High Balance] = 0
[PATCH Input : Bass Mode] = Off
[PATCH Input : Comp Switch] = On
[PATCH Input : Comp Attack] = 50
[PATCH Input : Comp Sustain] = 50
[PATCH Input : Comp Level] = 50
OSC COMMON***********
[ : OSC Sync 2] = OFF
[ : OSC Ring 2] = OFF
[ : OSC Sync 3] = OFF
[ : OSC Ring 3] = OFF
[ : OSC2 SEQ Link] = OFF
[ : OSC3 SEQ Link] = OFF
OSC 1 ***********
[OSC_1 : OSC Off/On] = On
[OSC_1 : Waveform] = SINE
[OSC_1 : OSC Pulse Width] = 50
[OSC_1 : PWM ENV Attack] = 0
[OSC_1 : PWM ENV Depth] = 0
[OSC_1 : PWM Detune] = 3
[OSC_1 : PWM Sharpness] = 50
[OSC_1 : Pitch Pitch] = 12
[OSC_1 : Pitch Fine] = 0
[OSC_1 : Pitch ENV Attack] = 0
[OSC_1 : Pitch ENV Depth] = 0
[OSC_1 : Pitch Bend Depth] = -8
[OSC_1 : Pitch Bend Control] = 0
[OSC_1 : Filter Type] = LowPass
[OSC_1 : Filter Slope] = -12dB
[OSC_1 : Filter CutOff] = 76
[OSC_1 : Filter Resonance] = 70
[OSC_1 : Filter ENV Attack] = 0
[OSC_1 : Filter ENV Depth] = 0
[OSC_1 : AMP ENV Attack] = -10
[OSC_1 : AMP Level] = 100
[OSC_1 : AMP Pan] = 0
[OSC_1 : LFO 1 Off/On] = ON
[OSC_1 : LFO 1 Waveform] = SINE
[OSC_1 : LFO 1 Rate] = 15
[OSC_1 : LFO 1 Pitch Depth] = 0
[OSC_1 : LFO 1 Filter Depth] = 35
[OSC_1 : LFO 1 Amp Depth] = 0
[OSC_1 : LFO 1 PWM Depth] = 0
[OSC_1 : LFO 1 Dynamic Depth] = OFF
[OSC_1 : LFO 1 Fade Time] = 0
[OSC_1 : LFO 2 Off/On] = ON
[OSC_1 : LFO 2 Waveform] = SINE
[OSC_1 : LFO 2 Rate] = 50
[OSC_1 : LFO 2 Pitch Depth] = 0
[OSC_1 : LFO 2 Filter Depth] = 0
[OSC_1 : LFO 2 Amp Depth] = 0
[OSC_1 : LFO 2 PWM Depth] = 0
[OSC_1 : LFO 2 Dynamic Depth] = OFF
[OSC_1 : LFO 2 Fade Time] = 0
[OSC_1 : SEQ Off/On] = ON
[OSC_1 : SEQ Rate] = 73
[OSC_1 : SEQ Depth] = 100
[OSC_1 : SEQ Loop Length] = 16 Steps
[OSC_1 : SEQ Step 1] = 0
[OSC_1 : SEQ Step 2] = +1
[OSC_1 : SEQ Step 3] = +2
[OSC_1 : SEQ Step 4] = +3
[OSC_1 : SEQ Step 5] = +4
[OSC_1 : SEQ Step 6] = +5
[OSC_1 : SEQ Step 7] = +6
[OSC_1 : SEQ Step 8] = +7
[OSC_1 : SEQ Step 9] = +8
[OSC_1 : SEQ Step 10] = +7
[OSC_1 : SEQ Step 11] = +6
[OSC_1 : SEQ Step 12] = +5
[OSC_1 : SEQ Step 13] = +4
[OSC_1 : SEQ Step 14] = +3
[OSC_1 : SEQ Step 15] = +2
[OSC_1 : SEQ Step 16] = +1
[OSC_1 : Input Range Lower Fade] = 1
[OSC_1 : Input Range Lower] = A0
[OSC_1 : Input Range Upper] = E6
[OSC_1 : Input Range Upper Fade] = 1
OSC 2 ***********
[OSC_2 : OSC Off/On] = On
[OSC_2 : Waveform] = INPUT
[OSC_2 : OSC Pulse Width] = 50
[OSC_2 : PWM ENV Attack] = 0
[OSC_2 : PWM ENV Depth] = 0
[OSC_2 : Detune] = 3
[OSC_2 : Sharpness] = 50
[OSC_2 : Pitch Pitch] = 0
[OSC_2 : Pitch Fine] = 0
[OSC_2 : Pitch ENV Attack] = 0
[OSC_2 : Pitch ENV Depth] = 0
[OSC_2 : Pitch Bend Depth] = -8
[OSC_2 : Pitch Bend Control] = 0
[OSC_2 : Filter Type] = BYPASS
[OSC_2 : Filter Slope] = -12dB
[OSC_2 : Filter CutOff] = 50
[OSC_2 : Filter Resonance] = 20
[OSC_2 : Filter ENV Attack] = 0
[OSC_2 : Filter ENV Depth] = 0
[OSC_2 : AMP ENV Attack] = 0
[OSC_2 : AMP Level] = 100
[OSC_2 : AMP Pan] = 0
[OSC_2 : LFO 1 Off/On] = ON
[OSC_2 : LFO 1 Waveform] = SINE
[OSC_2 : LFO 1 Rate] = 50
[OSC_2 : LFO 1 Pitch Depth] = 0
[OSC_2 : LFO 1 Filter Depth] = 0
[OSC_2 : LFO 1 Amp Depth] = 0
[OSC_2 : LFO 1 PWM Depth] = 0
[OSC_2 : LFO 1 Dynamic Depth] = OFF
[OSC_2 : LFO 1 Fade Time] = 0
[OSC_2 : LFO 2 Off/On] = ON
[OSC_2 : LFO 2 Waveform] = SINE
[OSC_2 : LFO 2 Rate] = 50
[OSC_2 : LFO 2 Pitch Depth] = 0
[OSC_2 : LFO 2 Filter Depth] = 0
[OSC_2 : LFO 2 Amp Depth] = 0
[OSC_2 : LFO 2 PWM Depth] = 0
[OSC_2 : LFO 2 Dynamic Depth] = OFF
[OSC_2 : LFO 2 Fade Time] = 0
[OSC_2 : SEQ Off/On] = OFF
[OSC_2 : SEQ Rate] = 4TH
[OSC_2 : SEQ Depth] = 0
[OSC_2 : SEQ Loop Length] = 16 Steps
[OSC_2 : SEQ Step 1] = 0
[OSC_2 : SEQ Step 2] = 0
[OSC_2 : SEQ Step 3] = 0
[OSC_2 : SEQ Step 4] = 0
[OSC_2 : SEQ Step 5] = 0
[OSC_2 : SEQ Step 6] = 0
[OSC_2 : SEQ Step 7] = 0
[OSC_2 : SEQ Step 8] = 0
[OSC_2 : SEQ Step 9] = 0
[OSC_2 : SEQ Step 10] = 0
[OSC_2 : SEQ Step 11] = 0
[OSC_2 : SEQ Step 12] = 0
[OSC_2 : SEQ Step 13] = 0
[OSC_2 : SEQ Step 14] = 0
[OSC_2 : SEQ Step 15] = 0
[OSC_2 : SEQ Step 16] = 0
[OSC_2 : Input Range Lower Fade] = 1
[OSC_2 : Input Range Lower] = A0
[OSC_2 : Input Range Upper] = E6
[OSC_2 : Input Range Upper Fade] = 1
OSC 3 ***********
[OSC_3 : OSC Off/On] = On
[OSC_3 : Waveform] = DETUNE SAW
[OSC_3 : OSC Pulse Width] = 50
[OSC_3 : PWM ENV Attack] = 0
[OSC_3 : PWM ENV Depth] = 0
[OSC_3 : Detune] = 3
[OSC_3 : Sharpness] = 50
[OSC_3 : Pitch Pitch] = -12
[OSC_3 : Pitch Fine] = 0
[OSC_3 : Pitch ENV Attack] = 25
[OSC_3 : Pitch ENV Depth] = 25
[OSC_3 : Pitch Bend Depth] = -8
[OSC_3 : Pitch Bend Control] = 0
[OSC_3 : Filter Type] = LowPass
[OSC_3 : Filter Slope] = -12dB
[OSC_3 : Filter CutOff] = 60
[OSC_3 : Filter Resonance] = 20
[OSC_3 : Filter ENV Attack] = 10
[OSC_3 : Filter ENV Depth] = 50
[OSC_3 : AMP ENV Attack] = 0
[OSC_3 : AMP Level] = 130
[OSC_3 : AMP Pan] = 0
[OSC_3 : LFO 1 Off/On] = ON
[OSC_3 : LFO 1 Waveform] = SINE
[OSC_3 : LFO 1 Rate] = 50
[OSC_3 : LFO 1 Pitch Depth] = 0
[OSC_3 : LFO 1 Filter Depth] = 0
[OSC_3 : LFO 1 Amp Depth] = 0
[OSC_3 : LFO 1 PWM Depth] = 0
[OSC_3 : LFO 1 Dynamic Depth] = OFF
[OSC_3 : LFO 1 Fade Time] = 0
[OSC_3 : LFO 2 Off/On] = ON
[OSC_3 : LFO 2 Waveform] = SINE
[OSC_3 : LFO 2 Rate] = 50
[OSC_3 : LFO 2 Pitch Depth] = 0
[OSC_3 : LFO 2 Filter Depth] = 0
[OSC_3 : LFO 2 Amp Depth] = 0
[OSC_3 : LFO 2 PWM Depth] = 0
[OSC_3 : LFO 2 Dynamic Depth] = OFF
[OSC_3 : LFO 2 Fade Time] = 0
[OSC_3 : SEQ Off/On] = OFF
[OSC_3 : SEQ Rate] = 4TH
[OSC_3 : SEQ Depth] = 0
[OSC_3 : SEQ Loop Length] = 16 Steps
[OSC_3 : SEQ Step 1] = 0
[OSC_3 : SEQ Step 2] = 0
[OSC_3 : SEQ Step 3] = 0
[OSC_3 : SEQ Step 4] = 0
[OSC_3 : SEQ Step 5] = 0
[OSC_3 : SEQ Step 6] = 0
[OSC_3 : SEQ Step 7] = 0
[OSC_3 : SEQ Step 8] = 0
[OSC_3 : SEQ Step 9] = 0
[OSC_3 : SEQ Step 10] = 0
[OSC_3 : SEQ Step 11] = 0
[OSC_3 : SEQ Step 12] = 0
[OSC_3 : SEQ Step 13] = 0
[OSC_3 : SEQ Step 14] = 0
[OSC_3 : SEQ Step 15] = 0
[OSC_3 : SEQ Step 16] = 0
[OSC_3 : Input Range Lower Fade] = 1
[OSC_3 : Input Range Lower] = A0
[OSC_3 : Input Range Upper] = B2
[OSC_3 : Input Range Upper Fade] = 15
CTL 1 ASSIGN ***********
[CTL 1 Assign : Switch 1] = On
[CTL 1 Assign : Switch 2] = Off
[CTL 1 Assign : Switch 3] = Off
[CTL 1 Assign : Switch 4] = Off
[CTL 1 Assign : Switch 5] = Off
[CTL 1 Assign : Switch 6] = Off
[CTL 1 Assign : Preset 1] = Manual
[CTL 1 Assign : Preset 2] = Preset
[CTL 1 Assign : Preset 3] = Preset
[CTL 1 Assign : Preset 4] = Preset
[CTL 1 Assign : Preset 5] = Preset
[CTL 1 Assign : Preset 6] = Preset
[CTL 1 Assign : Target 1] = Off/On
[CTL 1 Assign : Target 2] = Off/On
[CTL 1 Assign : Target 3] = Off/On
[CTL 1 Assign : Target 4] = Off/On
[CTL 1 Assign : Target 5] = Off/On
[CTL 1 Assign : Target 6] = Off/On
[CTL 1 Assign : Min 1] =
[CTL 1 Assign : Min 2] =
[CTL 1 Assign : Min 3] =
[CTL 1 Assign : Min 4] =
[CTL 1 Assign : Min 5] =
[CTL 1 Assign : Min 6] =
[CTL 1 Assign : Max 1] =
[CTL 1 Assign : Max 2] =
[CTL 1 Assign : Max 3] =
[CTL 1 Assign : Max 4] =
[CTL 1 Assign : Max 5] =
[CTL 1 Assign : Max 6] =
[CTL 1 Assign : Source Mode 1 ] = Toggle
[CTL 1 Assign : Source Mode 2 ] = Toggle
[CTL 1 Assign : Source Mode 3 ] = Toggle
[CTL 1 Assign : Source Mode 4 ] = Toggle
[CTL 1 Assign : Source Mode 5 ] = Toggle
[CTL 1 Assign : Source Mode 6 ] = Toggle
[CTL 1 Assign : Source Range Min 1] =
[CTL 1 Assign : Source Range Min 2] =
[CTL 1 Assign : Source Range Min 3] =
[CTL 1 Assign : Source Range Min 4] =
[CTL 1 Assign : Source Range Min 5] =
[CTL 1 Assign : Source Range Min 6] =
[CTL 1 Assign : Source Range Max 1] =
[CTL 1 Assign : Source Range Max 2] =
[CTL 1 Assign : Source Range Max 3] =
[CTL 1 Assign : Source Range Max 4] =
[CTL 1 Assign : Source Range Max 5] =
[CTL 1 Assign : Source Range Max 6] =
[CTL 1 Assign : Legato Rise Time 1] = 0
[CTL 1 Assign : Legato Rise Time 2] = 0
[CTL 1 Assign : Legato Rise Time 3] = 0
[CTL 1 Assign : Legato Rise Time 4] = 0
[CTL 1 Assign : Legato Rise Time 5] = 0
[CTL 1 Assign : Legato Rise Time 6] = 0
[CTL 1 Assign : Legato Fall Time 1] = 0
[CTL 1 Assign : Legato Fall Time 2] = 0
[CTL 1 Assign : Legato Fall Time 3] = 0
[CTL 1 Assign : Legato Fall Time 4] = 0
[CTL 1 Assign : Legato Fall Time 5] = 0
[CTL 1 Assign : Legato Fall Time 6] = 0
[CTL 1 Assign : Legato Rise Curve 1] = Linear
[CTL 1 Assign : Legato Rise Curve 2] = Linear
[CTL 1 Assign : Legato Rise Curve 3] = Linear
[CTL 1 Assign : Legato Rise Curve 4] = Linear
[CTL 1 Assign : Legato Rise Curve 5] = Linear
[CTL 1 Assign : Legato Rise Curve 6] = Linear
[CTL 1 Assign : Legato Fall Curve 1] = Linear
[CTL 1 Assign : Legato Fall Curve 2] = Linear
[CTL 1 Assign : Legato Fall Curve 3] = Linear
[CTL 1 Assign : Legato Fall Curve 4] = Linear
[CTL 1 Assign : Legato Fall Curve 5] = Linear
[CTL 1 Assign : Legato Fall Curve 6] = Linear
[CTL 1 Patch : Patch Select 1] = U:01
[CTL 1 Assign : Patch Select 2] = U:01
[CTL 1 Assign : Patch Select 3] = U:01
[CTL 1 Assign : Patch Select 4] = U:01
[CTL 1 Assign : Patch Select 5] = U:01
[CTL 1 Assign : Patch Select 6] = U:01
CTL 2 ASSIGN ***********
[CTL 2 Assign : Switch 1] = Off
[CTL 2 Assign : Switch 2] = Off
[CTL 2 Assign : Switch 3] = Off
[CTL 2 Assign : Switch 4] = Off
[CTL 2 Assign : Switch 5] = Off
[CTL 2 Assign : Switch 6] = Off
[CTL 2 Assign : Preset 1] = Preset
[CTL 2 Assign : Preset 2] = Preset
[CTL 2 Assign : Preset 3] = Preset
[CTL 2 Assign : Preset 4] = Preset
[CTL 2 Assign : Preset 5] = Preset
[CTL 2 Assign : Preset 6] = Preset
[CTL 2 Assign : Target 1] = Off/On
[CTL 2 Assign : Target 2] = Off/On
[CTL 2 Assign : Target 3] = Off/On
[CTL 2 Assign : Target 4] = Off/On
[CTL 2 Assign : Target 5] = Off/On
[CTL 2 Assign : Target 6] = Off/On
[CTL 2 Assign : Min 1] =
[CTL 2 Assign : Min 2] =
[CTL 2 Assign : Min 3] =
[CTL 2 Assign : Min 4] =
[CTL 2 Assign : Min 5] =
[CTL 2 Assign : Min 6] =
[CTL 2 Assign : Max 1] =
[CTL 2 Assign : Max 2] =
[CTL 2 Assign : Max 3] =
[CTL 2 Assign : Max 4] =
[CTL 2 Assign : Max 5] =
[CTL 2 Assign : Max 6] =
[CTL 2 Assign : Source Mode 1 ] = Toggle
[CTL 2 Assign : Source Mode 2 ] = Toggle
[CTL 2 Assign : Source Mode 3 ] = Toggle
[CTL 2 Assign : Source Mode 4 ] = Toggle
[CTL 2 Assign : Source Mode 5 ] = Toggle
[CTL 2 Assign : Source Mode 6 ] = Toggle
[CTL 2 Assign : Source Range Min 1] =
[CTL 2 Assign : Source Range Min 2] =
[CTL 2 Assign : Source Range Min 3] =
[CTL 2 Assign : Source Range Min 4] =
[CTL 2 Assign : Source Range Min 5] =
[CTL 2 Assign : Source Range Min 6] =
[CTL 2 Assign : Source Range Max 1] =
[CTL 2 Assign : Source Range Max 2] =
[CTL 2 Assign : Source Range Max 3] =
[CTL 2 Assign : Source Range Max 4] =
[CTL 2 Assign : Source Range Max 5] =
[CTL 2 Assign : Source Range Max 6] =
[CTL 2 Assign : Legato Rise Time 1] = 0
[CTL 2 Assign : Legato Rise Time 2] = 0
[CTL 2 Assign : Legato Rise Time 3] = 0
[CTL 2 Assign : Legato Rise Time 4] = 0
[CTL 2 Assign : Legato Rise Time 5] = 0
[CTL 2 Assign : Legato Rise Time 6] = 0
[CTL 2 Assign : Legato Fall Time 1] = 0
[CTL 2 Assign : Legato Fall Time 2] = 0
[CTL 2 Assign : Legato Fall Time 3] = 0
[CTL 2 Assign : Legato Fall Time 4] = 0
[CTL 2 Assign : Legato Fall Time 5] = 0
[CTL 2 Assign : Legato Fall Time 6] = 0
[CTL 2 Assign : Legato Rise Curve 1] = Linear
[CTL 2 Assign : Legato Rise Curve 2] = Linear
[CTL 2 Assign : Legato Rise Curve 3] = Linear
[CTL 2 Assign : Legato Rise Curve 4] = Linear
[CTL 2 Assign : Legato Rise Curve 5] = Linear
[CTL 2 Assign : Legato Rise Curve 6] = Linear
[CTL 2 Assign : Legato Fall Curve 1] = Linear
[CTL 2 Assign : Legato Fall Curve 2] = Linear
[CTL 2 Assign : Legato Fall Curve 3] = Linear
[CTL 2 Assign : Legato Fall Curve 4] = Linear
[CTL 2 Assign : Legato Fall Curve 5] = Linear
[CTL 2 Assign : Legato Fall Curve 6] = Linear
[CTL 2 Assign : Patch Select 1] = U:01
[CTL 2 Assign : Patch Select 2] = U:01
[CTL 2 Assign : Patch Select 3] = U:01
[CTL 2 Assign : Patch Select 4] = U:01
[CTL 2 Assign : Patch Select 5] = U:01
[CTL 2 Assign : Patch Select 6] = U:01
CTL 3 ASSIGN ***********
[CTL 3 Assign : Switch 1] = Off
[CTL 3 Assign : Switch 2] = Off
[CTL 3 Assign : Switch 3] = Off
[CTL 3 Assign : Switch 4] = Off
[CTL 3 Assign : Switch 5] = Off
[CTL 3 Assign : Switch 6] = Off
[CTL 3 Assign : Preset 1] = Preset
[CTL 3 Assign : Preset 2] = Preset
[CTL 3 Assign : Preset 3] = Preset
[CTL 3 Assign : Preset 4] = Preset
[CTL 3 Assign : Preset 5] = Preset
[CTL 3 Assign : Preset 6] = Preset
[CTL 3 Assign : Target 1] = Off/On
[CTL 3 Assign : Target 2] = Off/On
[CTL 3 Assign : Target 3] = Off/On
[CTL 3 Assign : Target 4] = Off/On
[CTL 3 Assign : Target 5] = Off/On
[CTL 3 Assign : Target 6] = Off/On
[CTL 3 Assign : Min 1] =
[CTL 3 Assign : Min 2] =
[CTL 3 Assign : Min 3] =
[CTL 3 Assign : Min 4] =
[CTL 3 Assign : Min 5] =
[CTL 3 Assign : Min 6] =
[CTL 3 Assign : Max 1] =
[CTL 3 Assign : Max 2] =
[CTL 3 Assign : Max 3] =
[CTL 3 Assign : Max 4] =
[CTL 3 Assign : Max 5] =
[CTL 3 Assign : Max 6] =
[CTL 3 Assign : Source Mode 1 ] = Toggle
[CTL 3 Assign : Source Mode 2 ] = Toggle
[CTL 3 Assign : Source Mode 3 ] = Toggle
[CTL 3 Assign : Source Mode 4 ] = Toggle
[CTL 3 Assign : Source Mode 5 ] = Toggle
[CTL 3 Assign : Source Mode 6 ] = Toggle
[CTL 3 Assign : Source Range Min 1] =
[CTL 3 Assign : Source Range Min 2] =
[CTL 3 Assign : Source Range Min 3] =
[CTL 3 Assign : Source Range Min 4] =
[CTL 3 Assign : Source Range Min 5] =
[CTL 3 Assign : Source Range Min 6] =
[CTL 3 Assign : Source Range Max 1] =
[CTL 3 Assign : Source Range Max 2] =
[CTL 3 Assign : Source Range Max 3] =
[CTL 3 Assign : Source Range Max 4] =
[CTL 3 Assign : Source Range Max 5] =
[CTL 3 Assign : Source Range Max 6] =
[CTL 3 Assign : Legato Rise Time 1] = 0
[CTL 3 Assign : Legato Rise Time 2] = 0
[CTL 3 Assign : Legato Rise Time 3] = 0
[CTL 3 Assign : Legato Rise Time 4] = 0
[CTL 3 Assign : Legato Rise Time 5] = 0
[CTL 3 Assign : Legato Rise Time 6] = 0
[CTL 3 Assign : Legato Fall Time 1] = 0
[CTL 3 Assign : Legato Fall Time 2] = 0
[CTL 3 Assign : Legato Fall Time 3] = 0
[CTL 3 Assign : Legato Fall Time 4] = 0
[CTL 3 Assign : Legato Fall Time 5] = 0
[CTL 3 Assign : Legato Fall Time 6] = 0
[CTL 3 Assign : Legato Rise Curve 1] = Linear
[CTL 3 Assign : Legato Rise Curve 2] = Linear
[CTL 3 Assign : Legato Rise Curve 3] = Linear
[CTL 3 Assign : Legato Rise Curve 4] = Linear
[CTL 3 Assign : Legato Rise Curve 5] = Linear
[CTL 3 Assign : Legato Rise Curve 6] = Linear
[CTL 3 Assign : Legato Fall Curve 1] = Linear
[CTL 3 Assign : Legato Fall Curve 2] = Linear
[CTL 3 Assign : Legato Fall Curve 3] = Linear
[CTL 3 Assign : Legato Fall Curve 4] = Linear
[CTL 3 Assign : Legato Fall Curve 5] = Linear
[CTL 3 Assign : Legato Fall Curve 6] = Linear
[CTL 3 Assign : Patch Select 1] = U:01
[CTL 3 Assign : Patch Select 2] = U:01
[CTL 3 Assign : Patch Select 3] = U:01
[CTL 3 Assign : Patch Select 4] = U:01
[CTL 3 Assign : Patch Select 5] = U:01
[CTL 3 Assign : Patch Select 6] = U:01
CTL 4 ASSIGN ***********
[CTL 4 Assign : Switch 1] = Off
[CTL 4 Assign : Switch 2] = Off
[CTL 4 Assign : Switch 3] = Off
[CTL 4 Assign : Switch 4] = Off
[CTL 4 Assign : Switch 5] = Off
[CTL 4 Assign : Switch 6] = Off
[CTL 4 Assign : Preset 1] = Preset
[CTL 4 Assign : Preset 2] = Preset
[CTL 4 Assign : Preset 3] = Preset
[CTL 4 Assign : Preset 4] = Preset
[CTL 4 Assign : Preset 5] = Preset
[CTL 4 Assign : Preset 6] = Preset
[CTL 4 Assign : Target 1] = Off/On
[CTL 4 Assign : Target 2] = Off/On
[CTL 4 Assign : Target 3] = Off/On
[CTL 4 Assign : Target 4] = Off/On
[CTL 4 Assign : Target 5] = Off/On
[CTL 4 Assign : Target 6] = Off/On
[CTL 4 Assign : Min 1] =
[CTL 4 Assign : Min 2] =
[CTL 4 Assign : Min 3] =
[CTL 4 Assign : Min 4] =
[CTL 4 Assign : Min 5] =
[CTL 4 Assign : Min 6] =
[CTL 4 Assign : Max 1] =
[CTL 4 Assign : Max 2] =
[CTL 4 Assign : Max 3] =
[CTL 4 Assign : Max 4] =
[CTL 4 Assign : Max 5] =
[CTL 4 Assign : Max 6] =
[CTL 4 Assign : Source Mode 1 ] = Toggle
[CTL 4 Assign : Source Mode 2 ] = Toggle
[CTL 4 Assign : Source Mode 3 ] = Toggle
[CTL 4 Assign : Source Mode 4 ] = Toggle
[CTL 4 Assign : Source Mode 5 ] = Toggle
[CTL 4 Assign : Source Mode 6 ] = Toggle
[CTL 4 Assign : Source Range Min 1] =
[CTL 4 Assign : Source Range Min 2] =
[CTL 4 Assign : Source Range Min 3] =
[CTL 4 Assign : Source Range Min 4] =
[CTL 4 Assign : Source Range Min 5] =
[CTL 4 Assign : Source Range Min 6] =
[CTL 4 Assign : Source Range Max 1] =
[CTL 4 Assign : Source Range Max 2] =
[CTL 4 Assign : Source Range Max 3] =
[CTL 4 Assign : Source Range Max 4] =
[CTL 4 Assign : Source Range Max 5] =
[CTL 4 Assign : Source Range Max 6] =
[CTL 4 Assign : Legato Rise Time 1] = 0
[CTL 4 Assign : Legato Rise Time 2] = 0
[CTL 4 Assign : Legato Rise Time 3] = 0
[CTL 4 Assign : Legato Rise Time 4] = 0
[CTL 4 Assign : Legato Rise Time 5] = 0
[CTL 4 Assign : Legato Rise Time 6] = 0
[CTL 4 Assign : Legato Fall Time 1] = 0
[CTL 4 Assign : Legato Fall Time 2] = 0
[CTL 4 Assign : Legato Fall Time 3] = 0
[CTL 4 Assign : Legato Fall Time 4] = 0
[CTL 4 Assign : Legato Fall Time 5] = 0
[CTL 4 Assign : Legato Fall Time 6] = 0
[CTL 4 Assign : Legato Rise Curve 1] = Linear
cheskylow
Wow, this is a very usefull prog. Better overview that the original Editor.
Thanx
Quote from: cheskylow on October 30, 2017, 01:53:09 PM
BR Ingo
Only curious
Why do you want to do that ?
cheskylow
#6
I will study the parameters and looking for an opportunity to import some moog patches.
Or is there still an easy way to do that?
