Katana AIR SYSEX for Sneaky Amps
Started by alancarl, February 20, 2019, 10:31:24 PM
alancarl
Hi SYSEX experts,
    has anybody been successful in recalling the 'sneaky amps' with a Katana Air?
The Roland SYSEX product identifier number is 50 instead of 33 like the other Katanas I have messed with so I have been changing my MIDI Designer layout SYSEX strings to address the Katana Air's parameters but I have not been successful in find the Sneaky Amp codes...if they can be found at all in the Katana AIR?
I know Nobody really likes the AIR but I can see great potential with the Boss editor App and it's small size as a front end for a travel backline setup.
Any help would be greatly appreciated!
Thanks,
Al
As far as I'm aware, there is no BTS for Windows/Mac for the Katana air. The existing solutions for the Katana use the USB midi connection to communicate, but the AIR uses Bluetooth. So I am afraid the Bluetooth protocol will have to be hacked in order to communicate. That does not sound like an easy task.
I made a Katana AIR FxFloorboard editor a few weeks back,
because someone requested one, but they have not been back here since.
So I don't know if it works,
but if you enable "debug" mode in the Preferences > Midi/USB settings,
it should connect,
and allow you to try the sneaky amps, and see if they exist on the AIR.
Give it a go and let me know. If it throws an error on patch size incorrect, let me know the data so I can adjust the editor to suit the AIR.
A windows version here,
https://sourceforge.net/projects/fxfloorboard/files/experimental/Desktop-FxFloorBoard/AIR_FxFloorBoard_Windows-setup.exe/download
let me know if you need a mac or Linux version.
alancarl
Quote from: sixeight on February 21, 2019, 01:27:41 AM
I am using the Katana Air app on  my iPad along with MidiDesigner Pro and with the Midi Designer set to connect to bluetooth the SYSEX midi commands are merged on thru to the Katana.
So that's the route for the SYSEX messages. I find that custom control layouts work better for me to adjust certain parameters hence the MD Pro layouts that I have created.
Thanks,
AL
alancarl
Quote from: gumtown on February 21, 2019, 02:18:47 AM
it should connect,
Thanks Gummie.
I will let you know how I make out!
Al
Quote from: alancarl on February 21, 2019, 10:09:44 AM
Thanks,
AL
Is it possible you could share your Midi Designer Katana AIR templates?
With any luck  - the custom "Arduino (Teensy) USB MIDI foot controller for Katana amps" might also be adapted to work with Katana AIR
https://www.vguitarforums.com/smf/index.php?topic=25185.0
Quote from: admin on February 21, 2019, 10:32:39 AM
Yes, this project should be able to work with the AIR just by changing one little number in the code.
alancarl
Quote from: gumtown on February 21, 2019, 10:44:26 AM
Yes the model ID is 50 not 33 like the other Katanas!
FWIW Steve,
I really need to clean up my layouts before posting as I expect they will cause more questions than I could answer but I can send you one tonite or tomorrow.
Thanks,
Al
I bet this same wireless MIDI  connection to IPad (with MIDI Designer Pro) strategy you have discovered also works with Boss GT-1000
Both Katana AIR and GT-1000 employ same MIDI over Bluetooth hardware
and
I have confirmed what Gurbz has told us:
The Yamaha Bluetooth USB to Host MIDI adapter UD-BT01 does infact interface with the USB port on my Katana Head and it will send SYSEX commands to the Katana!
Of course- eventually lots of folks will want to know if this same strategy ) remote MIDI over Bluetooth Control using a UD-BT01 could also be achieved for  GT-1, GT-001, GP-10, MS-3, ME-80,  etc. or any other Roland/ Boss gear that lacks 5 pin MIDI ports
I understand the key is knowing the USB connected Roland/ Boss products complete MIDI implementation
vit3k
Quote from: alancarl on February 21, 2019, 10:56:07 AM
FWIW Steve,
Thanks,
Al
Alancarl, can you tell me more about communication between smartphone and Katana AIR? I as far as I know this a MIDI BLE device with standard characteristics. Is that correct? Does it use the same sysex commands as usb? What katana sends to the smartphone during initalization and what do you response with?
Regards
alancarl
#10
Quote from: vit3k on February 22, 2019, 05:49:47 AM
Regards
Hi Vt,
    i'm using an iPad and Midi Designer Pro 2. Yes the SYSEX commands are the same for MIDI over USB as they are for MIDI over Bluetooth L.
I am initially sending a BTS Edit Mode SYSEX command to the Katana Air then just sending the SYSEX strings that pertain to the parameters that I am looking to have a specific iPad screen control that suits my purpose.
So to recap all I have to do is:
1.connect to Katana-AIR MIDI from the Bluetooth MIDI devices I/O list within my MIDI control app(MDP2)
2. send a BTS Edit SYSEX command 00  F0 41 00 00 00 00 33 12  7F 00 00 01 01 7F F7
3. start sending the SYSEX strings that pertain to the parameters i wish to change Like Amp selection Deluxe Crunch 00  F0 41 00 00 00 00 33 12  60 00 00 51 0C 43 F7
Hope this helps a little
AL
Hope this helps
vit3k
Thanks. Is it possible for you to check what amp is sending to the app when you connect?
alancarl
Quote from: admin on February 21, 2019, 11:11:16 AM
I have tested the Yamaha UD-BT01 with a GT-1 and it does work!
I had problems initially perhaps because I am not sure if the SYSEX message to put the GT-1 into BTS Edit or Control Mode as Gumtown refers to it is the same as it is for the Katana Amps (7F 00 00 01 --> 01).
Maybe Colin  could shed some light on this or SnHirsch?
Thanks and good luck fellow knob twiddlers.
Al
alancarl
Quote from: vit3k on February 23, 2019, 10:14:13 PM
I am monitoring the MIDI SYSEX transmissions...not the low level USB data or the BLE data so I am pretty sure I don't see what you are looking for...sorry...I wish I could help but if I am mistaken please enlighten me:-)
Al
vit3k
Actually I'm asking about sysex messages that amp sends to the app on connection through Midi BLE. Can you see them?
alancarl
Quote from: vit3k on February 24, 2019, 04:03:54 AM
Ah I see... I have not been successful in getting any SYSEX data that originates at the amp coming back to the app.
So far the data stream is one way only...
Good luck vit3k!
Al
alancarl
Hi Vit3k,
     I did capture this when the Katana Air connected to my iPad...not sure if it contains what you are trying to learn but i figured it is worth a shot!
Welcome to MIDI Designer Pro 2 | Version 2.98.1 | Build 181210!
Message In: Length=15: F0 7E 00 06 02 41 50 00 00 00 00 00 00 00 F7
Message In: Length=15: F0 41 00 00 00 00 50 12 7F 00 00 00 00 01 F7
Message In: Length=15: F0 41 00 00 00 00 50 12 7F 00 00 03 00 7E F7
Message In: Length=30: F0 41 00 00 00 00 50 12 10 00 00 00 4B 41 54 41 4E 41 20 20 20 20 20 20 20 20 20 20 00 F7
Message In: Length=30: F0 41 00 00 00 00 50 12 10 01 00 00 42 6C 75 73 79 20 43 72 75 6E 63 68 20 20 20 20 5D F7
Message In: Length=30: F0 41 00 00 00 00 50 12 10 02 00 00 4B 41 54 41 4E 41 20 62 6C 75 65 73 20 41 6C 20 16 F7
Message In: Length=30: F0 41 00 00 00 00 50 12 10 03 00 00 42 6C 75 73 79 20 43 72 75 6E 63 68 20 70 68 61 02 F7
Message In: Length=30: F0 41 00 00 00 00 50 12 10 04 00 00 42 72 6F 77 6E 2B 53 44 45 33 30 30 30 20 20 20 3A F7
Message In: Length=30: F0 41 00 00 00 00 50 12 10 05 00 00 48 69 47 61 69 6E 20 4C 65 61 64 20 20 20 20 20 05 F7
Message In: Length=30: F0 41 00 00 00 00 50 12 10 06 00 00 41 6C 73 20 56 6F 78 20 31 20 20 20 20 20 20 20 3C F7
Message In: Length=15: F0 41 00 00 00 00 50 12 7F 00 00 02 00 7F F7
Message In: Length=16: F0 41 00 00 00 00 50 12 00 01 00 00 00 06 79 F7
Message In: Length=142: F0 41 00 00 00 00 50 12 00 00 00 00 08 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 03 00 00 00 00 00 00 00 00 05 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 78 13 32 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 32 32 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 14 14 14 10 01 14 14 32 00 01 00 00 00 00 00 00 F7
Message In: Length=142: F0 41 00 00 00 00 50 12 00 00 01 00 00 01 00 00 64 00 00 00 00 00 00 00 00 00 00 00 01 00 32 0A 32 32 32 00 32 00 01 00 32 01 01 01 05 64 00 00 32 32 05 05 32 32 32 07 0A 0A 02 00 01 00 32 0A 32 32 32 00 32 00 01 00 32 01 01 01 05 64 00 00 32 32 05 05 32 32 32 07 0A 0A 02 00 01 00 32 0A 32 32 32 00 32 00 01 00 32 01 01 01 05 64 00 00 32 32 05 05 32 32 32 07 0A 0A 02 00 01 00 32 0A 32 32 32 00 32 00 01 00 32 01 01 01 10 F7
Message In: Length=142: F0 41 00 00 00 00 50 12 00 00 02 00 05 64 00 00 32 32 05 05 32 32 32 07 0A 0A 02 00 01 00 32 0A 32 32 32 00 32 00 01 00 32 01 01 01 05 64 00 00 32 32 05 05 32 32 32 07 0A 0A 02 00 01 00 32 0A 32 32 32 00 32 00 01 00 32 01 01 01 05 64 00 00 32 32 05 05 32 32 32 07 0A 0A 02 00 00 3A 00 0A 00 13 00 37 00 34 00 35 00 36 00 37 01 00 01 00 13 00 01 01 06 00 01 01 09 00 01 01 05 00 32 00 00 32 00 00 00 00 00 00 00 00 00 00 73 F7
Message In: Length=142: F0 41 00 00 00 00 50 12 00 00 03 00 00 01 0C 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 00 03 00 00 00 00 00 00 00 00 00 00 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 58 F7
Message In: Length=77: F0 41 00 00 00 00 50 12 00 00 04 00 01 00 32 32 00 00 00 00 00 00 00 00 00 00 00 00 01 01 01 04 04 01 00 00 00 00 00 00 00 00 00 00 04 32 64 00 41 49 3C 42 5B 40 00 00 00 00 00 00 01 01 00 00 14 0D 01 14 17 01 14 14 0B 14 01 36 F7
Message In: Length=190: F0 41 00 00 00 00 50 12 60 00 00 00 41 6C 73 20 56 6F 78 20 31 20 20 20 20 20 20 20 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 32 32 32 32 00 00 00 00 00 00 00 00 00 00 00 0C 6E 3C 4B 00 32 32 00 00 32 32 32 32 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 17 3C 0A 00 41 49 3C 64 00 01 00 32 00 01 01 05 64 00 00 32 32 05 05 32 32 32 07 0A 0A 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 32 0A 32 32 32 00 32 00 01 00 32 01 01 01 05 64 00 00 32 32 05 05 32 32 32 07 0A 0A 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 39 F7
Message In: Length=143: F0 41 00 00 00 00 50 12 60 00 01 30 00 05 14 0E 01 14 17 01 1A 14 0E 14 00 00 00 00 01 06 0B 32 32 32 00 32 32 00 00 00 01 01 32 23 23 00 32 00 01 23 32 32 3C 00 32 00 00 64 00 64 64 00 00 00 32 32 32 32 00 00 00 1E 0B 0A 1E 00 14 14 15 14 10 0E 14 13 11 11 14 00 00 14 0D 01 14 17 01 14 14 0E 14 00 00 32 32 32 32 00 00 32 32 32 32 00 2D 32 3C 00 32 32 46 00 32 64 00 00 00 28 1E 28 32 32 19 00 00 32 32 32 20 28 64 00 00 5C F7
Message In: Length=142: F0 41 00 00 00 00 50 12 60 00 02 31 00 3E 64 00 00 01 18 3C 00 00 46 01 18 28 00 00 46 00 64 00 01 0C 00 00 46 07 00 00 50 00 64 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 00 00 32 32 00 01 32 32 10 32 32 32 00 00 46 28 37 00 00 64 00 00 1F 28 52 32 00 00 3C 00 00 46 55 41 32 00 01 1E 55 00 00 3C 32 00 46 3C 64 00 00 32 00 28 64 32 00 00 32 32 32 00 00 50 2D 01 00 32 00 00 32 64 64 00 01 71 F7
Message In: Length=142: F0 41 00 00 00 00 50 12 60 00 03 31 00 02 32 50 64 32 64 00 04 2B 2E 03 4B 21 30 03 41 50 00 03 10 14 0E 32 64 32 00 01 04 0B 32 32 32 00 32 32 00 00 00 01 01 32 23 23 00 32 00 01 23 32 32 3C 00 32 00 00 64 00 64 64 00 00 00 32 32 32 32 00 02 0D 54 0D 0A 16 00 14 14 14 14 14 14 14 14 14 14 14 00 00 14 0D 01 14 17 01 14 14 0E 14 00 00 32 32 32 32 00 00 32 32 32 32 00 2D 32 3C 00 32 32 46 00 32 64 00 00 00 28 1E 28 32 32 F7
Message In: Length=142: F0 41 00 00 00 00 50 12 60 00 04 31 32 19 00 00 32 32 32 20 28 64 00 00 00 3E 64 00 00 01 18 3C 00 00 46 01 18 28 00 00 46 00 64 00 01 0C 00 00 46 07 00 00 50 00 64 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 00 00 32 32 00 01 32 32 10 32 32 32 00 00 46 28 37 00 00 64 00 00 1F 28 52 32 00 00 3C 00 00 46 55 41 32 00 01 1E 55 00 00 3C 32 00 46 3C 64 00 00 32 00 28 64 32 00 00 32 32 32 00 00 0D F7
Message In: Length=178: F0 41 00 00 00 00 50 12 60 00 05 31 50 2D 01 00 32 00 00 32 64 64 00 01 00 02 32 50 64 32 64 00 04 2B 2E 03 4B 21 30 03 41 50 00 03 10 14 0E 32 64 32 00 00 00 00 00 00 00 00 00 00 08 02 77 16 0A 51 64 32 00 64 16 0A 32 03 10 16 0A 32 28 37 00 00 00 00 00 00 00 00 00 00 00 00 01 28 32 08 00 0E 64 64 00 00 00 00 00 00 00 01 01 0C 00 0A 0D 08 05 4B 64 05 00 00 00 00 00 00 18 24 00 64 00 00 64 00 64 64 00 00 00 00 00 02 00 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 32 00 09 00 32 00 09 00 00 00 00 00 00 00 00 00 00 00 07 F7
Message In: Length=185: F0 41 00 00 00 00 50 12 60 00 06 55 01 00 32 32 00 00 00 00 00 00 00 00 00 00 01 3C 50 00 00 00 05 32 00 00 00 00 00 02 04 32 05 32 32 32 05 46 32 05 64 32 32 64 32 05 64 32 05 00 32 46 55 32 1E 55 08 00 00 00 0D 64 14 10 01 14 14 00 78 00 13 00 00 00 00 00 00 11 0F 05 04 02 0D 0C 01 07 06 08 09 0E 12 00 03 0B 0A 13 10 00 00 00 00 00 00 00 00 00 00 00 00 0E 0F 0A 0B 10 11 00 01 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 13 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 06 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 55 F7
Message In: Length=158: F0 41 00 00 00 00 50 12 60 00 08 00 09 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 05 00 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 01 05 01 00 7F 08 1E 00 14 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 01 05 01 00 7F 08 1E 00 14 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 01 05 01 00 7F 08 1E 00 14 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F F7
Message In: Length=190: F0 41 00 00 00 00 50 12 60 00 09 10 00 00 06 00 00 00 01 05 01 00 7F 08 1E 00 14 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 01 05 01 00 7F 08 1E 00 14 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 01 05 01 00 7F 08 1E 00 14 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 01 05 01 00 7F 08 1E 00 14 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 01 05 01 00 7F 08 1E 00 14 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 72 F7
Message In: Length=206: F0 41 00 00 00 00 50 12 60 00 0A 40 04 32 64 00 41 49 3C 42 5B 40 00 00 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 19 F7
Message In: Length=142: F0 41 00 00 00 00 50 12 60 00 0C 00 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 14 F7
Message In: Length=142: F0 41 00 00 00 00 50 12 60 00 0D 00 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 F7
Message In: Length=142: F0 41 00 00 00 00 50 12 60 00 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 F7
Message In: Length=158: F0 41 00 00 00 00 50 12 60 00 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11 F7
Message In: Length=254: F0 41 00 00 00 00 50 12 60 00 10 10 32 32 32 00 32 00 32 01 32 32 32 32 32 32 00 32 32 32 00 32 00 32 01 32 32 32 32 32 32 00 00 01 32 32 32 32 64 00 00 32 32 64 64 64 00 01 32 2D 32 32 50 01 32 2D 32 32 50 01 00 00 00 00 00 00 03 10 16 0A 32 64 32 00 64 16 0A 32 03 10 16 0A 32 28 37 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 F7
Message In: Length=45: F0 41 00 00 00 00 50 12 60 00 12 00 01 0C 0B 0E 06 14 13 08 07 00 04 00 0E 01 05 03 00 00 00 00 00 01 01 00 00 00 07 08 02 02 02 7A F7
Good Luck
AL
vit3k
Thanks, this is exactly what I'm looking for.
alancarl
Great!
These amps are so exceptional!
We are getting so close to nailing multiple routes to actually fine tune them....and for me the small adjustments make for signicant tone enhancements!!
Rock on!
Al
alancarl
it should connect,
Hey Colin I a m not able to get the midi from my MBP into the Katana Air... so no go on the Air Floorboard so far..
I can connect my iPad via BT within Midi Designer Pro but nada with my Yosemite MBP:-0
Al
Quote from: alancarl on February 24, 2019, 03:05:22 PMHi Vit3k,
Good Luck
AL
Thanks for the data capture, very valuable information to me, Cheers  ;)
