IOS - Multiple USB Audio interfaces to iPad - Possible or not?
Started by Tim-MK, March 03, 2016, 11:15:16 AM
Tim-MK
Can I connect more than one USB Audio device to the iPad?
I have 3 USB audio interfaces, a Steinberg UR44. Sonic Port VX and just arrived is the Vox Amplug I/O
All three work fine on their own and of course are self-powered and recognized by the AUM app, also just installed - it's great  :)
http://kymatica.com/Software/AUM
I connect them using a powered USB hub, but AUM on the iPad Air 2 (latest iOS) only recognizes the last one plugged into the USB
My aim is to have the Vox Amplug I/O feed into an amp FX and preferably an iRig Pro Duo for two vocalists (all battery powered)
- am I attempting the impossible when connecting more than one USB device?
QuoteCan I connect more than one USB Audio device to the iPad?
Not possible  -  IOS only supports ONE external USB audio interface at a time
QuoteMy aim is to have the Vox Amplug I/O feed into an amp FX and preferably an iRig Pro Duo for two vocalists (all battery powered)
I use a Focusrite 18i20 +Apple Lightning USB Camera adapter with my iPad Air2
Most comprehensive list of IOS supported multi-channel interfaces is here
http://auriaapp.com/Support/auria-audio-interfaces
But IMHO - its asking a lot to use one iPad for real time Amp / cab Simulation + processes 2 vocalists  all at the same time.
If you need 100% battery power - For the same money a gently used Macbook running Apple Mainstage + Apple Logic with a Thunderbolt powered Audio interface might offer more value.
But read all about Battery powered IOS audio  / MIDI here
IOS: Connecting USB Class Compliant MIDI / Audio (Battery Power)
GuitarBuilder
Quote from: Tim-MK on March 03, 2016, 11:15:16 AM
Sounds complicated - why isn't the UR44 with 6 inputs not sufficient?
Tim-MK
Thanks for the quick and humble replies  :)
I may well have to stay with the UR44 and external battery pack, as we need to be on the street and highly portable.
I was also considering the iConnectAUDIO4 to which I can connect two iOS devices at once, to ease the processing? It also has more flexible output routing to provide personalised IEM for vocalists/musicians.
-which was one attraction of my original Vox and iRig Duo with my now imaginary multiple USBs  :'(
Too bad the iConnectAudio has a lot more noise and hiss compared to the competition
https://www.vguitarforums.com/smf/index.php?topic=10419.0
Quoteas we need to be on the street and highly portable.
For that scenario - I do recommend the
Roland Cube Street EX
https://www.vguitarforums.com/smf/index.php?topic=11600.0
Quotewhich was one attraction of my original Vox and iRig Duo
get separate ipads and a small mixer.
this is the smallest
Must Have Accessory List for Mobile Guitarists
https://www.vguitarforums.com/smf/index.php?topic=10968.0
