Good source for quality 13 pin parts?
Started by Rhcole, June 03, 2014, 10:14:47 AM
Rhcole
If I wanted to custom-build a 13 pin box, where might you recommend I find high-quality parts, particularly jacks that mount to a case?
Quotewhere might you recommend I find high-quality parts, particularly jacks that mount to a case?
I would only use this type myself - solves most the Cable Noise problems due to cable movement at live gig issue for most - due to the 360 degree circular full Ground connection with the Roland Gk-13 DIN Plug's Shell:
Forum member Gumbo sells these great Female 13 pin DIN Jacks that accept the Roland Locking Male DIN plug on GK Cables.
https://www.vguitarforums.com/smf/index.php?topic=8888.0
DIN13 Male plugs are here
http://www.iec-usa.com/Browse05/MPartMiniDIN.html
http://www.iec-usa.com/dn13ms-l.html
Part Number: DN13MS-L
Product Description:
Din - 13 Pin Male Solder Connector with Latch
http://www.coolnovelties.co.uk/stores/en/connectors/72-13-pin-din-male-plug-connector-.html
FreeTime
I bought some PC mount stuff from Digi-Key to replace a flaky socket on a Godin Guitar, but the RMC ones have a different pinout than these:
Part #           Mfg Part #
CP-2313-ND   SDD-130J
CP-3313-ND   SDF-130J
CP-1013-ND   SD-130
Coleslaw
Godin XTSA, Burny RLC 85S with GK3, 1990 MIJ Strat with internal GK3, Boss GP-10, Roland GI-20, Lots of rack gear, Several computers, Several bits of Line6 gear, FCB 1010, Roland PK-5 Pedals, Patience and a slight lean to the left when i tango. ;)
