Electro-Harmonix 720-Stereo Looper
Started by Elantric, January 13, 2016, 07:49:23 PM
http://info.shimamura.co.jp/guitar/news/electro-harmonix-720-stereo-looper/?ref=sinftn
http://www.ehx.com/products/720-stereo-looper
Quick Specs
- Extra-long 12 minutes of stereo recording time
- 10 independent loops
- Undo-Redo, Reverse and ½ Speed Effects at the touch of a button
- High-quality, uncompressed audio, 24-bit A/D/A converters plus 44.1kHz sample rate
- Stereo in/out for enhanced usability... record two instruments at once
- Foot controller input provides a way to use popular 3-button foot controllers to change a bank up or down, and gives access to instant Undo-Redo
- Silent footswitches
- Loop fadeout (trails) mode
- Includes EHX9.6DC power supply
- Works on 9V battery and provides extended battery life
- Dimensions in inches: 4.0 (w) x 4.75 (l) x 2.25 (h)
- Dimensions in mm: 102 (w) x 121 (l) x 89 (h)
electro harmonix 720 looper how long can one loop be ?
All 720 sec ?
Answer from ehx
12 minutes total.
You can have one 12 min loop or break down over 9 loops
After a loop is recorded, the length is subtracted from the total loop recording time. For example, if a 20-second loop is recorded on Loop 9, there are 700 seconds still available for Loops 0-8. Overdubbing on top of any given loop does not subtract from total loop recording time.
Is it possible to record or overdub in loop fade out mode.
I guess not but there's nothing in the manual.
Anyone ?
How difficult would it be to modify the external foot switch internally to control play/record/overdub and stop/fade , reverse or halfspeed ?
As is , it controls bank up/down , undo/redo
