Correct way to wire toggle switch between 2 sets of Single coils?
Started by Hog Mouth, November 29, 2013, 06:29:31 PM
Hog Mouth
I'm using  two pairs of single coils to cover 20 strings or two 10 string necks.  I want to wire this toggle switch: http://www.acehardware.com/product/index.jsp?productId=29107996
so I can switch between necks (Neck1, Neck1+Neck2, Neck 2).
The outputs from the volume pots would combine at the output jack.
Parallel would be better for less output when the magnets overlap on the inner strings?
EDIT- I don't think that switch will work because it is on/off/on. That diagram is wrong. I think I need an on/on/on DPDT switch
Quote. That diagram is wrong. I think I need an on/on/on DPDT switch
Correct the above works as PU selector - but you must use a Double Pole on/on/on Switch
http://www.guitarelectronics.com/product/SWM23-17/Double-Pole-ONONON-Mini-Toggle-Switch-w-Bat-Handle-Chrome.html
Or Just use Gibson style PU switch & wiring
On  Gibson schematic
Neck Pu = neck#1
Bridge PU = Neck#2
http://www.stewmac.com/freeinfo/Electronics/Switches/i-1240.html
More resources:
Many excellent tutorials here.
http://www.gmarts.org/index.php?go=236
This another good resource of info.
http://www.guitarnuts.com/wiring/index.php
GuitarBuilder
