Double checking before pulling the trigger on a an FTP ......
Started by mdortona, April 22, 2017, 08:52:55 AM
mdortona
After hours of reading all the FTP posts and TTK, if I want a computerless, IPad based FTP rig for live use, to replace my GR-55, I will need:
1. An Ipad with CCC and FTP (duh), and use Sampletank or some other iOS synth app. Audio is handled by the Ipad headphone out (e.g. into a Rolls DB24) or a dedicated audio interface (e.g. Roland DuoEX, Scarlett) with a powered USB hub (but I'll need a USB Y cable?)
2. If I want to change patches too, I'll need the powered USB hub and a class compliant USB FS (e.g. Line6 FBV EXpress II, a FCB1010, a Keith M FS). Does anyone know if an Irig BlueBoard will for work for simple patch changes?
3. To use FTP with hardware synths, I'll need a Kenton or Iconnect box.
4. The Fishman Footswitch only work if you're using a computer set-up.
Did I miss anything?
Thanks for the help guys! After a while, it all starts to become a blur..... :P
Matt
alexmcginness
alexmcginness
I plan on using the triple play in my studio. So, does it have to be run on battery power exclusively, or can it be plugged into an adapter?
