GR-55 Bass - PCM1 vs PCM2 test patch
Started by Gastric, February 15, 2011, 12:08:08 PM
Gastric
Patch I setup to test PCM1 vs PCM2 voicing. By default the patch is setup as follows:
* PCM1 with filtering disabled
* PCM2 with filtering enabled
* Toggle between PCM1 and PCM2 with CTRL pedal
Quick way to compare the raw PCM voice sound to the sound using the "tone" filter voice. Also good for illustrating how the filter is really the key to heavily shaping synth tones.
