GR-55- Jean Luc Ponty Violin Patch For GR55
Started by jaysteeleglobal, February 28, 2017, 07:20:51 AM
jaysteeleglobal
Here is my youtube demonstration video:
Jean Luc Ponty:
(A).   TONE:   level 120
      PCM1    333 violin 1      100   port time 15 cut +15 attack vel.sens+21 atk sens+8
      PCM2   681 Wine Pad      25   port time 20
(B).   EFFECT:
      MFX:      17  3TAP PAN DELAY         30   left 500 ms  rt=1000 ms ctr=1500ms   feedback=+12 lt level=100, rt-70                           ctr-35
      REVERB: 04   HALL2         70   time=4.45 high cyt 4000hz
      EQ         18
(C).   MASTER:
      PDL GK CTL      CTL status = off      *Press Ctrl for that classic JLP Delay Sound...
            function= HOLD
            hold type = 1
      EXP FUNCTION      patch volume
How To Set The Volume Pedal To Raise Violin One Octave by depressing pedal:
(A).   MASTER:   PDL GK CTL      ctrl function "system"
            exp function =off
            expon= pitch bend
            depth=0
            pcm1&2 on
            expsw= status off
            function= mfxsw
(B).   ASSIGN:   #1=   switch      off
         target      pcm1 tone octave
         target min      plus 1
         target max      0
         source      exp
         source mode      moment
         act range low      65
         act range high      127
      #2=   switch      on
         target min      plus 1
         target max      0
         source      exp
         source mode      moment
         act range low      0
         act range high      64
      #3=   switch      on
         target      pcm1 tone switch
         target min      on
         target max      on
         source      wave pdl
         source mode      toggle
         act range low      0
         act range high      127
         wave rate      40
         wave form      sin
      #4=   switch      on
         target min      off
         target max      on
         source      ctl
         source mode      toggle
         act range low      0
         act range high      127
      #5-#8 same as #4.
   *   In "Sytem" - "Pdl/GK Ctl"   ='s
      ctl function      hold
      hold type       1
      switch mode      latch
      pcm tone 1 & 2 = on
      exp   "patch settings"
      exp on   "patch settings"
      expsw   "patch settings"
