Anyone connecting GP-10 to FCB1010 via Raspberry Pi
Started by JoBoss, October 11, 2017, 08:33:20 AM
JoBoss
Anyone using the GP-10 connected to the FCB1010 via Raspberry Pi ..?
JoBoss
Thanks admsustainiac for the reply....I had earlier; however, gone through the relevant posts regarding the same before posing my question...
Does any one know if there is a preloaded Raspberry Pi available off the shelf that I can connect the GP-10 and FCB straightaway without much ado..just like the MIDX-10 or 20....?  In short a plug and play Raspberry Pi for the GP-10..if so where....?
I can build you one of these:
It has serial midi connections on the other side, so you can connect it straight to the FCB1010.
I will send you a pm with more information...
JoBoss
Redvers
Using the aconnect command it's very easy to connect the two, you just need to make it launch on startup. A preloaded image is great but I'm guessing if you plugged into the wrong USB port the port numbers would get mixed up.
Quote from: Redvers on October 12, 2017, 02:53:03 AM
You can also do aconnect by name. That way it will always connect correctly.
And I found the aconnect numbers are not related to a port, but related to the order in which you connect USB devices. Here is how I set things up for the VController RPI bridge (called VCbridge)
https://github.com/sixeight7/VCbridge/blob/master/RPi%20full%20install%20VCbridge.txt
#8
Quote from: JoBoss on October 12, 2017, 02:07:56 AM
Thanks sixeight...looking forward to your PM
PM sent...
