GP-10 - Using the Rotary FX with GP-10
Started by mccorp, August 16, 2017, 06:58:00 AM
mccorp
I am trying to use the Rotary Fx with Ctl1 and Ctl2 switches so that I can have access to the slow and fast rotary on the same patch. Can someone explain the settings for me? I just can't seem to get it to work.
Sometimes you have to let go of the melody and focus on the rhythm
Redvers
They're the same parameter, like an on/ off switch so you only need to assign it to one switch and alternate between 0 / 127. From what j remember.
For more FX programming and Control Assignment  details read
Learn to Program Roland/Boss MultiFX Processors
Cups
Use ctrl 1 to switch rotary on/off than use the assign to switch the fast/slow. You can use whatever switch you like. May I suggest using the gk1 switch. It frees up your stomps.
mccorp
Thanks to Redvers and Cups for the suggestions and as always to Admin for the link.  :)
