GP-10 - Harmonic Feedback Pedal
Started by Rhcole, February 25, 2017, 11:22:17 AM
Rhcole
This is a very tactile patch. It is a tamer version of the DistortFback patch. Works great for blues and rock soloing where you are picking key notes to emphasize. Keep the Exp pedal slightly above heel-down, as you can hear the Sustain section kick in otherwise. The amp is set with just a touch of crunch, which also gives you ringing chords at lower settings.
Rhcole
If the tone is a bit too fizzy for you turn down the high end on the EQ.
