GR-55- PCM Octave error Pitch Change Reset
Started by HoosierMan, November 06, 2016, 05:40:44 PM
HoosierMan
Hi guys,
I am stumped.  I edited a Trumpet patch using the Floorboard editor and changed the "Octave" setting for the PCM tone 368 Trumpet 1 to "+1" and while in the editing mode the octave change took effect.  However, when I saved the patch to the GR-55 and played the same note it was sounding back down an octave even though the setting in the patch was still +1 octave.  When I edit the patch directly on the GR-55 the same behavior occurs:  It will sound the note up an octave while I am in the editing mode, but once I save the patch the octave setting reverts to "0".
Any suggestions?
Thanks!
bergenwoods
I'm having the same problem. Did you ever get any help for it?
Thanks!
Bergen
mmmmgtr
 Is the Octave setting in any of the assigns or the Pdl/Ctrl settings?   This is probably the most common reason when settings don't appear to have changed when you save them.  The assigned setting immediately overrided what you think you just changed.
