GT-5 Express Pedal MOD
Started by hoaithang, June 15, 2016, 07:31:12 AM
hoaithang
Anyone have been done MOD the express pedal on GT-5 function as normal wah pedal, I meant when we press down to activate the wah effect instead of press the CTR then use the exp pedal ?
Try a factory reset and recalibrate the GT-5 Expression Pedal
Wah should engage using a strong toe down pressure on the Expression pedal
Read GT-5 Manual
hoaithang
I'll try to reset and recalibrate the Expression Pedal,
Avoid placing GT-5 on padded carpeting when you re-calibrate Expression pedal
Use solid concrete or  hardwood floor
