Mainstage Unexpected latency
Started by guitarnstuff, November 24, 2015, 09:29:22 PM
guitarnstuff
I have MS 3.2 on a new i5 macbook with Yosemite.  I get unexpected latency of about 1 sec. It occurs randomly and infrequent.  It occurs with wifi off. Any ideas for trouble shooting?  Requires a restart of mainstage or reseting buffer size. I have this occur on a variety of buffer settings. Would upgrade to El Capitan help? I am using Boss GP10 as audio interface.
GuitarBuilder
A quick check would be to see if you get the same problems with Garageband, using a plugin similar to what you're using in Mainstage.
You did install the GP-10 driver, I assume?
Another possibility is that of an A/D clock mismatch - did you set up the GP-10 as an Audio Device in Audio MIDI Setup?
