Boss BR-80 "Legends of Rock - Sounds of the Heroes" patches from Roland Germany
Started by Elantric, November 02, 2011, 12:07:57 PM
http://www.soundsderhelden.de/soundsderhelden.html#br-80
Here is the English translation to how to load and use the patches..
Installing the "Sounds of Heroes" for the BR-80
BEFORE THE TRANSFER the SDH please BR80 necessarily a COMPLETE BACKUP of the SD card of the BR-80
! make All data from the SD card must be cleared for the transmission of sounds-the-hero first
be! This requires that the BR-80 in USB mode is STORAGE.
Just select [MENU] button, select FUNCTION, USB, and then select STORAGE.
A. BACKUP OF DATA
First BR-80 with the enclosed USB cable to the computer. The display shows the BR-80: "Idling ...".
Second Drive on the computer "BR-80 eBand" open.
Third COMPLETE the ROLAND folder on your computer.
4th After the copy of the ROLAND ROLAND folder, delete the folder on the "BR-80 eBand" drive.
B. SDH data transfer
5th Now copy the ROLAND folder that you received from the "SDHBR80.zip" file on the "BR-80
EBand "drive.
6th After the file copying process, the "BR-80 eBand" unsubscribe drive to your computer ("hardware
safely remove ";" eject drive ").
7th Remove the USB cable from the BR-80. The display briefly shows: "Keep power on! Checking card ... "
C. Use of SDH data
8th Select the MTR mode, the BR-80.
It is now only one song (name: SDH) is available, which is already selected. This song contains the
Sounds-of-heroes as a songwriter patches.
9th [COSM] key.
10th Select with [Arrow <] and the CATEGGORY the dial the CATEGORY "SONG PATCH".
11th Go back to [> arrow] to the list of patches.
You will now see the 30 sounds-the-hero patches.
12th Simply select a patch and try it immediately.
D. SDH data in user memory of the secure BR-80
13th [ENTER] key.
14th "WRITE / NAME" and confirm with [ENTER].
15th If necessary, change the name of the patch or so left and press [ENTER].
16th Select with [Arrow <] the memory area "U".
17th Select with [arrow>] the desired space.
18th 2x [ENTER] key to make the save.
Then the device is in the USER CATEGORY PATCH.
To test further SDH patches and secure in the user memory, just steps C-10 to D-18
. repeat
Are all the required patches in the SDH-backed user memory, the original data of the BR-80
be transferred back to the SD card.
E. retransmission of their own data
Third COMPLETE the ROLAND folder with the SDH data on the "BR-80 eBand" Delete Volume.
4th Copy the backed up in Step A-3 ROLAND folder on the "BR-80 eBand" drive.
5th After the file copying process, the "BR-80 eBand" unsubscribe drive to your computer ("hardware
6th Remove the USB cable from the BR-80. The display briefly shows: "Keep power on! Checking card ... "
The BR-80 show is now ready for use again with the original data and has brought to you by
Sounds-of-heroes saved in user memory, the song you are available across.
BR-80 SOUNDS OF HEROES
