VG-99 - Metallica - Orion
Started by A2theT, November 01, 2009, 08:11:16 PM
A2theT
Ok, this patch was inspired by Brent Flash's B3 Organ Patch.  This is basically an organ run through a marshall with some rotary and reverb.  Similar to the original sound used in the song but it needs a little work still as the Rotary mix seems a liitle over the top.  The rhythm guitars use my previously posted Plaster of Muppets patch and the lead is my Sanitarium lead patch.  The drums on this one are Superior Drummer 2 Metal Foundry (Master of Justice kit). No bass.  Just put it together quick so you could hear the intro organ.  EXP2 controls the mix level of both channels simultaneously so you can fade in the organ like Metallica did.
(edit) I just realized I've never posted Plaster of Muppets.  So here it is. (/edit)
HEAVY on the METAL
