GR-55 - Delay(s)
Started by the-destructor, June 03, 2013, 08:33:02 AM
the-destructor
Am I correct in understanding that you can only achieve ONE delay setting for the TWO PCM paths???
Or, yet again, am I missing something?
TIA ;)
mbenigni
No, there is a delay in the MOD block, and a couple of delays in the MFX block, and you can route PCM 1 and 2 independently to each of these.  Of course doing so will use up the MOD block which you might otherwise have wanted to use for your guitar signal.
You can also send varying amounts of PCM 1 and 2 to the post-effect DLY block.
