Wavemachine Labs - Auria DAW for the iPad
Started by rolandvg99, July 17, 2012, 11:53:18 PM
rolandvg99
A small sound card note: The new MOTU AVB series works great using the CCK.
My little Soundcloud corner
Same with the FocusRite 18i 20  +CCK
www.auriaapp.com/Support/auria-audio-interfaces
I was trying to hold off getting a new iPad till the new Pro comes out next year. But now need one ASAP . Is there any advantage/disadvantage between iPad Air and Air2. Help I need to do something today. Thanks Paul ???
Allmost pulled the trigger tonight,  on the iPad air I found, But not sure if I should get the Air2 for $50 more. Surely the iPad pro when it comes out will have ios8 or something newer. What to do ! What to do! ??? ??? ???
Whatever you do - avoid a 16GB ipad
Not much improvement in an Air2
And worth the wait for May 2015 for Ipad Pro 12 "
Id get a IPad Mini 2 Retina 32GB for $275 at Best Buy
Theres never a need to sell the old ipad  - and you will always use the old one
Yeah, thought about that but the smaller screen will not work with set list maker, for me. No, wouldn't touch the 16 , was thinkin the 64gb. But your right I've been able to live with out SLM up until a couple of months ago, It may just be wisw to wait,. I can also live with out Bias, Jamup ,tonestack, and Garage band for awhile.
With over two years in the making, we're really excited to finally give you a preview of the upcoming Auria Pro. Full MIDI capabilities, real-time audio warping, powerful audio bussing, two built-in synths and much more, Auria Pro raises the bar in mobile recording once again. Auria Pro will be on display at our booth at NAMM (Booth #6903).
Comprehensive MIDI capabilities including:
MIDI sequencing
Tempo and Time-signature tracks
Piano roll editor
Real-time MIDI parameters including quantize, velocity shift, velocity compression,
length compression, random, delay, legato and transpose
Groove template quantizing with built-in DNA grooves (additional grooves available for
purchase)
MIDI processing functions including Transpose, Fixed Length, Velocity Gain, Fixed
Velocity, Delete Notes, Delete Controller, Restrict Polyphony, Optimize Controller Data,
Humanize, Delete Overlaps, Crescendo, Reverse, Pedal to Length, Velocity Rescale,
Velocity Range, Velocity Curve and Compress/Limit
FabFilter Twin 2 Analog synth built in
WaveMachine Labs multi-format sampler built in
Other Features:
Powerful new audio routing with flexible busses
Real-time audio warping using Elastique Pro v3
Audio quantize feature
Transient slicing
Audio to MIDI conversion
Unlimited tracks
6 AUX sends
Project templates
Updated graphics and overall performance improvements
Auria Pro will be available Spring 2015 and will be priced at $49.99 USD, and existing Auria users will also be able to upgrade to Auria Pro for a reduced price. Pricing for the standard Auria version will be $24.99.
For more information and additional screenshot previews, check this post on our forum.
http://auriaapp.com/forum/viewtopic.php?f=19&t=12809
WaveMachine Labs
supernicd
QuoteWith over two years in the making, we're really excited to finally give you a preview of the upcoming Auria Pro. Full MIDI capabilities, real-time audio warping, powerful audio bussing, two built-in synths and much more, Auria Pro raises the bar in mobile recording once again. Auria Pro will be on display at our booth at NAMM (Booth #6903).
This is news I've been waiting for for a long, long time.  And it looks like the wait is going to be worth it.  If all this works as advertised (which WaveMachineLabs has a good track record of delivering on), this will be a game changer.  Again.
Strat w/ GK-3, Godin LGXT
VG-99, GR-55, GP-10
AURIA DAW for Ipad is 50% $24.99
http://www.auriaapp.com/
https://itunes.apple.com/us/app/auria/id524122834?mt=8&ign-mpt=uo%3D4
Currently 50% off!
Auria - the 48-track digital audio recording system for iPad.
A sneak peek at some of the new features coming in Auria Pro, including: MIDI sequencing, real-time audio warping, flexible routing, and a new graphic interface.
For more information check out our blog post on the upcoming version:
http://blog.auriaapp.com/sneak-preview-of-the-upcoming-auria-pro/
Or join the discussion on the Auria web forum:
AURIA PRO!
New Features:
- Comprehensive MIDI capabilities including:
- MIDI sequencing.
- Tempo and Time-signature tracks.
- Piano roll editor.
- Real-time MIDI parameters including quantize, velocity shift, velocity compression,
length compression, random, delay, legato and transpose.
- Groove template quantizing with built-in DNA grooves (additional grooves available for
purchase).
- MIDI processing functions including Transpose, Fixed Length, Velocity Gain, Fixed
Velocity Range, Velocity Curve and Compress/Limit.
- FabFilter Twin 2 Analog synth built in.
- WaveMachine Labs multi-format sampler built in.
- Powerful new audio routing with flexible busses.
- Real-time audio warping using Elastique Pro v3.
- Audio quantize feature.
- Transient slicing.
- Audio to MIDI conversion.
- Unlimited tracks.
- 6 AUX sends.
- Project templates.
- Updated graphics and overall performance improvements.
QuoteI'm still confused as to why you need the camera adapter in between the 24 bit interface and the iPad
Its true many Lightning cable equipped Audio interfaces also charge the connected iPad during use,  but there is no need to purchase a special "Apple mFI Approved" 24bit Audio interface with the Apple Lightning  cable support just to get excellent audio into your iPad /iPhone.
For the best iPad Audio interface, to record a full band with clean 24bit audio, Review the dozens of Auria Daw approved  USB Class Compliant Audio  / MIDI interfaces
http://auriaapp.com/Support/auria-audio-interfaces
(Many support 24 channels! - "CCK" = "Camera Connection Kit" a.k.a. "USB Camera Adapter"))
This is covered in more detail here:
How to Use the iPad for Music Control: Cables, Wireless, MIDI, OSC
and
How to configure iPad to use USB Audio / USB MIDI + TriplePlay on Battery power
https://www.vguitarforums.com/smf/index.php?topic=10323.0
and
Record directly to your iPad with a USB microphone or audio interface
http://www.theusbsoundcard.com/record-directly-to-your-ipad/
I am proud to announce that both Auria Pro and the 2.0 update to the standard Auria will be launching today! Our web site has been updated with all the new info:
http://www.auriaapp.com/Products/auria
Video:
Existing Auria users will be able to upgrade to Auria Pro for a discounted price of $39.99
Rim
Introducing Auria Pro. The first Digital Audio Workstation designed from the ground up for iPad. With professional-level features like comprehensive MIDI sequencing, built-in sample player and analog synths, real-time audio warping, AAF import/export, powerful busing, and optional third-party plug-in support from names like PSP, FabFilter, Overloud and Drumagog, Auria Pro clearly sets a new standard for mobile music production.
For the full list of new features: http://www.auriaapp.com
Auria PRO DAW for the iPad
We're proud to announce the availability of Auria Pro! Three years in the making, this massive upgrade to an award-winning DAW sets the bar for mobile music production. If you already own Auria, you can now purchase an upgrade to Auria Pro for a discounted price of $39.99 USD.
New Features:
Comprehensive MIDI sequencing
Unlimited audio and MIDI tracks
Lyra multi-format sample player with a free downloadable 4GB sample library. Lyra is a true disk streaming sampler, capable of playing multi-GB sample instruments. Supports SFZ, EXS and SF2 sample formats
Fabfilter Twin2 and One synthesizers included
Real-time Audio warping using élastique Pro v3, allows audio tracks to be stretched in real time
Powerful audio busing system allows flexible routing of audio between tracks, subgroups and auxes
Piano Roll editor
Tempo and time signature tracks
Real-time MIDI parameters allow immediate control over MIDI tracks including quantize, transpose, velocity shift, compression and randomize
Comprehensive MIDI processing including: Crescendo, Delete Controller, Delete Notes, Fixed Length, Fixed Velocity, Humanize, Legato, Optimize Controllers, Pedal to Length, Quantize, Groove Quantize, Restrict Polyphony, Reverse, Transpose, Velocity Compression/Gain/Limiter/Range and Rescale
Groove Quantizing, includes a free set of DNA grooves from Numerical Sound (additional grooves available for purchase)
Custom groove extraction from MIDI and audio tracks
Audio quantizing
Audio transient to MIDI conversion
Transient slicing
Project templates
Support for external iOS-compatible hard drives for project backup
6 aux sends
Time stretching using ZTX technology and élastique Pro v3
Bounce Track in Place
To purchase an upgrade to Auria Pro, you first need to upgrade your current Auria version to 2.0. The Auria Pro upgrade will appear in the built-in Auria Store.
More info visit the Auria Pro website
External Hard Drive Support
iOS Hard Drives
Auria Pro introduces support for iOS-compatible external hard drives. Using Auria Pro's new Save Project to other App feature allows you to backup and restore your Auria projects to external media with just a few taps.
Full Auria Pro Feature List
Recording and Playback:
Sample rates of 44.1KHz, 48KHz and 96KHz
24-bit recording
Unlimited tracks
Up to 24 tracks of simultaneous recording when used with compatible audio interfaces
Full delay compensation on all tracks, subgroups, buses and aux sends
Auto-punch recording mode
Adjustable metering modes, including pre or post fader, RMS and peak
AAF import and export allows transferring audio sessions between popular DAWs like Logic, Pro Tools, Nuendo, Samplitude and more
MIDI and audio editing:
Comprehensive MIDI sequencer
FabFilter One and Twin 2 synths included
WaveMachine Labs' Lyra, a multi-format sample player, included
Real-time audio warping using élastique Pro v3
Piano roll editor
Audio quantizing with warp and slicing modes
Transient slicing
Audio transient-to-MIDI conversion
Real-time MIDI parameter control including quantize, velocity shift, velocity compression, length compression, random, delay, legato and transpose
MIDI processing functions including Crescendo, Delete Controllers/Notes, Fixed Length, Fixed Velocity, Humanize, Legato, Optimize Controller Data, Pedal to Length, Restrict Polyphony, Reverse, Transpose, Velocity Compress/Limit, Velocity Gain, Velocity Range, and Velocity Rescale
Groove template quantizing with built-in DNA grooves from Numerical Sound (additional grooves available for purchase)
MIDI Sync support with MIDI Time Code, MIDI Clock and MMC
MIDI Remote Control (Mackie MCU and HUI protocol)
Touch-based waveform editor with cut, copy, paste, split, join, crossfade, duplicate, separate, gain, normalize, DC offset, reverse, and more
Timeline ruler options include Minutes:Seconds, Bars:Beats, Samples and SMPTE time
Ripple-edit mode
Real-time audio scrubbing
Built-in metronome
Flexible snapping tools allow snapping to events, cursor, bars, beats, fractional beats, markers, locators, transients and SMPTE frames
Mixing, processing and effects:
64-bit double-precision floating point mixing engine
8 assignable subgroups and 6 aux sends
Powerful internal bus routing with up to 32 buses and support for multiple destinations
Full automation support on all controls with graphical editing
Vintage-inspired ChannelStrip by PSPaudioware on every channel includes Gate, Expander, Multi-band EQ and Compressor
MasterStrip on all subgroup and master channels featuring PSPaudioware BussPressor, EQ and Mastering Limiter
Convolution reverb plug-in with bundled IR library included
ClassicVerb reverb plug-in included
PSPaudioware Stereo Delay plug-in included
PSPaudioware Stereo Chorus plug-in included
Third party effect plugin support available via in-app purchase by companies including FabFilter, FXpansion, Overloud, BIAS and more
Tempo sync and side chain support for plug-ins
Track freeze and bounce-in-place for minimizing CPU usage
True 100mm faders when used in Portrait Mode
Adjustable pan laws
And more:
External hard drive support
Project template support
Project snapshots
Automatic sample rate conversion
Audiobus, DropBox, SoundCloud, AudioShare, and Audio Copy/Paste support
Optional video import feature allows sample accurate sync of video to an Auria project. Adjustable offset times and video export capability
WIST support for wireless syncing of other compatible music apps
http://auriaapp.com/forum/viewtopic.php?f=19&t=13553
mbenigni
#39
Woah.   :o
(And this is actually the first time I've seen an iOS hard drive.  Interesting...)
Quote(And this is actually the first time I've seen an iOS hard drive.  Interesting...)
http://www.leefco.com/ibridge
https://www.sandisk.com/home/mobile-device-storage/ixpand
Wired magazine -  Test of IOS  external drives
http://www.wired.com/2015/04/ios-flash-drives/
I'm just playing around with the IPad Pro and Auria Pro nothing serious. It runs like butter I love this screen. I don't have the apple pencil yet but a cheap dollar stylus works so great.
AH! You broke down and got an iPAD Pro. I knew you would like it
QuoteAH! You broke down and got an iPAD Pro. I knew you would like it
Not here yet - Had to wait for the right deal
https://www.vguitarforums.com/smf/index.php?topic=3207.msg130231#msg130231
Well jump on the bandwagon 8)
I saw that post earlier. I'm thinkin of grabbing another one as a backup
updated manuals
http://auriaapp.com/Support/auria-support
https://s3.amazonaws.com/auria.store/docs/Auria+Pro+User+Guide.pdf
https://s3.amazonaws.com/auria.store/docs/Optional+Plugins.pdf
Frequently Asked Questions
What are the differences between iPad models in terms of Auria performance?
1st Generation iPad
2nd Generation iPad
3rd Generation iPad
Track Count
24
48
48
Subgroups
4
8
8
Aux Delay Compensation
No
Yes
Yes
Sample Rates Supported
44.1/48 kHz
44.1/48/96 kHz
44.1/48/96 kHz
What kind of audio interfaces work with Auria?
Auria supports two main categories of audio hardware, the iPad's built-in internal I/O (Speaker, Mic, and 3.5mm headphone mini-jack), and external audio interfaces connected through the 30-pin MFi port (either directly or through the Camera Connection Kit, which enables USB devices).
What are the iPad's built-in options?
Speaker
Microphone
3.5mm mini-jack – Includes both mono input plus stereo out.
What kinds of external devices can be used?
Auria supports external audio interfaces through the 30-pin dock connector (or MFi).  There are two types of devices which can be connected through this port:
MFi - These interfaces connect directly to the 30-pin MFi connector. One popular example is the Apogee Jam.
USB Class 2 Compliant interfaces - These require an Apple Camera Connection Kit connected between the iPad and interface. Examples include the RME Fireface UCX, Presonus AudioBox 1818VSL, and the Focusrite Scarlett series interfaces. See our Interfaces page for more information.
Auria is not recording any incoming audio with iOS 7.
iOS 7 can block all audio inputs (from both the microphone and from interfaces) to an app unless it is specifically allowed. When first opening an app under iOS7 a pop-up asks, "Auria would like to access the microphone." If "Don't Allow" is selected then all audio input to Auria is blocked. To fix this open iPad Settings, go to General, then Privacy, then Microphone. Find Auria in the list and enable access by tapping the slider so it is green.
