Question about order changers
Started by Redvers, August 30, 2017, 07:35:29 AM
Redvers
Does anybody know how commercial switchers achieve this? I mean, I know how I'd do it, using dpdt relays, but for 4+ loops that would be a lot of relays. Is there a chip or something they use nowadays?
Relays are the most transparent and have the least distortion, but can suffer "pops" on transitions.
A CPU  managed zero crossing detector circuit manages switching the relays with the least DC offset.
Google "Analog Mux IC, then review the images reveals the IC circuits available today
There used to be several ICs available from NJR (JRC) that provided many switching options  - but most have gone  EOL ( End of Life) not recommended for new designs
http://pdf1.alldatasheet.com/datasheet-pdf/view/7603/NJRC/NJU7313AL.html
or for government and Rad Hard ( = $$$)
http://html.alldatasheet.com/html-pdf/49684/AEROFLEX/ACT8505/647/2/ACT8505.html
http://www.njr.com/semicon/audio_video/index.html
http://www.njr.com/semicon/audio_video/audio_switch.php?cat=3400
Its appealing but be mindful  of the limited voltage swing of the signal being switched must within the range of the IC's power rails
Today many units (MS-3) employ A/D on every input and D/A on every output , and perform the switching "swizzle" re- rerouting within a DSP or FPGA
Redvers
Thanks for the reply! So is this the kind of thing the boss loop switchers would employ?
The ES-5, ES-8 use relays
The MS-3 uses A/D and DSP and D/A
Read the manuals as those block diagrams provide incite
