Play multi-track (WAV) to ASIO device?
Started by vtgearhead, June 17, 2017, 03:27:21 PM
vtgearhead
I must be missing something when forming search terms, but I'm unable to find an application that can simply play (for example) 8 tracks of WAV files to 8 channels of an ASIO output interface on Windows.  Currently trying to practice using a Behringer X18 for live FOH mix and thought it would be useful to play a multitrack of my band through Ch 1-8 and play around with that while listening to CUE out on the Behringer through phones.
Could not figure out anyway to do this sort of routing on my Presonus Studio One 2 DAW, but figured there must be a simple Windows app somewhere.  I tried Google on "play multi-track recording to ASIO output" and came up with nothing that seemed on point.
maglich
I'm not aware of any stand alone app but my suggestion would be to try Mixbus, it does have 8 busses that can be routed to any phisical output. (Plus, of course, the master out L/R). It costs 79$ but the demo should do the trick.
http://www.waves.com/mixers-racks/tracks-live#presenting-tracks-live
Waves  - Tracks Live is available for free download. You may also purchase Tracks Live Premium Service for $99 and receive:
Phone and email tech supportPriority updates and bug fixes
Created with and for live sound engineers, Tracks Live is a multitrack recording software solution designed to capture live performances of any kind, from the smallest gig to the largest production.
Tracks Live enables easy switching between stereo out and multi out modes, allowing you to toggle back and forth between recording and virtual soundcheck with the click of a button. The automatic multichannel re-routing engine also adapts to any changes you make on the fly, making it easier than ever to set up big shows with hundreds of tracks.
Designed with close attention to every detail to ensure superior user experience, Tracks Live will make your live recording process faster, easier and absolutely reliable.
Read MoreASIO/Core Audio-compatible and works with virtually any audio interfacePC- and Mac-compatibleRecord and play back hundreds of tracksSupported sample rate of up to 192 kHzFile formats compatible with all popular DAWsAutomatic track routing configurationFast switching between recording and virtual soundcheckMeter bridge view for easy monitoringSave session templatesLTC sync optionSystem lock (to protect against accidental key pressing)
http://www.waves.com/downloads/tracks-live
vtgearhead
Thanks for the replies and suggestions!  After banging a flat-spot in my head most of the day, I finally discovered that the rather oddball "Tracktion T6" DAW (free license came with Behringer X18) was able to route tracks directly out the ASIO interface.  The less said about the T6 UI, the better.  Totally counter-intuitive and carefully designed to make the simplest things extremely difficult.  But, take my comments with a grain of salt because I tend to think all UIs are wretched.
