Mac OS Status
Started by admin, June 05, 2017, 02:19:43 PM
Be prepared for a new version of Mac OS  "High Sierra"
https://www.yahoo.com/finance/news/apple-debuted-newest-version-macos-173557544.html
I expect new battles with working  Mac OS  "High Sierra" USB drivers for all your Audio gear
My advice dont consider upgrade to this OS until October 2017
Apple® has recently released macOS® 10.13 High Sierra, which has changed how some drivers are installed, including those from Line 6.
Regarding Line 6 installations, After you connect your device, please open the Security Control Panel and accept the Line 6 driver in order for your device to be recognized.
For more details on what to expect, please see our Knowledge Base article: macOS High Sierra 10.13 Driver Installation Change.
http://line6.com/support/page/kb/_/recording/computer-audio-set-up-and-troubleshooting/macos-high-sierra-1013-driver-installation-change-r879
macOS 10.13 has implemented an additional security layer for kernel extension drivers, such as the Line 6 audio drivers. After the Line 6 device is connected, the customer must open the Security Control Pane and accept the Line 6 driver in order for the device to be recognized.
Typically, you'll see this message when your driver gets blocked:
However, sometimes the driver gets blocked and the message won't appear. Your driver and hardware simply won't work. In either case, you'd need to approve the driver in System Preferences > Security & Privacy:
Additional information about this change can be found at
https://developer.apple.com/library/content/technotes/tn2459/_index.html#//apple_ref/doc/uid/DTS40017658
Must read for macOS High Sierra  10.13 Users
Might help for loading USB drivers for other gear too - not just Zoom Audio gear
https://www.zoom.co.jp/news/product-not-recognized-mac-os-high-sierra-1013
TROUBLESHOOTING: PRODUCT NOT RECOGNIZED ON MAC OS HIGH SIERRA (10.13)
macOS High Sierra 10.13 have introduced a new security feature that requires user approval when you install new driver software.
Products: Q2n, Q4n, Q8, L-12, TAC-2, TAC-2R, TAC-8, UAC-2, UAC-8, R16 and R24
If you do not approve, Mac does not recognize the product.
To enable the products on Mac, please follow these steps:
1. Please uninstall the driver if it is already installed on Mac.
2. Please reinstall the driver. Then, open "System Preferences" and click "Security & Privacy".
If  display "System Extension Blocked" in a popup window when you install the driver, please click "OK".
3. When the "Security & Privacy" opens, you will see a message below:
System software from developer "ZOOM CORPORATION" was blocked from loading.
4. Click the Allow button in the lower right corner.
© 2017 ZOOM Corporation. All Rights Reserved.
