GR-55 - asigning effect level to expression pedal
Started by philjynx, May 24, 2017, 01:35:44 PM
philjynx
Problem with the MOD flanger is there is no wet/dry mix, the level controls the total level.
the only option there is effect off/on (abrupt bypass or effect)
Can you use the MFX flanger and assign the wet/dry mix to the EXP pedal.?
