Empress Echosystem
Started by Rhcole, April 20, 2017, 09:46:52 AM
Rhcole
Just got an email announcement. Looks like a pretty awesome echo.
https://empresseffects.com/products/echosystem
Very interesting
Unsurpassed Connectivity - The Universal Control Port allows you to connect an expression pedal, external tap switch, control voltage, external audio input and MIDI - all using a standard 1/4" jack!
Advanced Configuration Menu - The Advanced configuration menu lets you configure how your delay works. Select from true or buffered bypass, 0-35 presets, MIDI configuration, Control Port(expression pedal, external tap, control voltage and MIDI) as well as which style of preset system to use, input signal pad, output transformer enable and more!
mchad
Sounds sweet. Sophisticated. Complex. I wish it had at least an LCD for a preset number.
