SY-300- Notes Sound Thinner on Thinner Strings
Started by funkyguitar, February 08, 2017, 07:24:58 PM
funkyguitar
I've been working on a song using the SY - 300.  When I play notes on the higher/thinner strings, the tone gets quieter, thinner, and not as resonant, compared to lower notes on the thicker strings.  I attached an .mp3 of the song, measure 14 has the high note I'm talking about.  Is this just an inherent limitation of the device?
Yes, happens here too
Some call that a SY-300 "feature"
Solution?
You will get more even response if you have polished frets and action not too low ,and strings not too light gauge as well.
Have you tried the compressor on the input settings ?
mooncaine
Yeah, higher action gives strings more room to swing.
funkyguitar
Brak(E)man, I will try messing with the compressor.  Thanks for the tip.
BROCKSTAR
Quote from: funkyguitar on February 08, 2017, 07:24:58 PM
I know it's a older post and not sure if you still use the sy-300 but I'll leave this here for you or someone else that's reading it.
Adjusting your pole pieces on your guitar [especially humbuckers with adjustable pole pieces] can even and balance out the signal.
