Boss gt100 4 cable method issues
Started by Jay123, January 15, 2017, 09:38:39 AM
Jay123
Hey Guys,
I'm using the gt100 with my 100highwatt amp 4 cable method. I can get the od wah compression etc to work pre s/r but I'm not getting the delays reverbs etc post s/r. Am I missing something obvious?
Any advice would be great thanks in advance
Is the GT-100 connected like..
guitar > GT-100 input
GT-100 S/R Send > hiwatt input
hiwatt FX Send > GT-100 S/R Return
GT-100 L/Mono out > hiwatt FX Return.
Do you have your 4CM patches setup so that the S/R loop is enabled using an Assign or pedal function, and the GT preamps disabled with an assign or pedal function, another way is to move the S/R loop into the GT-100 channel B chain and just flip channels on the GT.
Do you still hear something if you pull the plug from the GT-100 L/Mono output?
if so, your amp FX loop might be a parallel type instead of Serial.
Does the FX loop on the hiwatt have a mix control, this should be 100%
