Add decay effect on chord line
Started by Mauri60, November 15, 2015, 03:53:48 PM
Mauri60
Hi everybody,
this w.e. my band mates ask me to add a decay effect at the end of a song.
in this song i play some chords, two PCM tones strings ensemble, and the last one chord after son end, may decay gradually to zero in a certain time.
ehm... i'm lost ... i try assign a control but no decent results.
may someone help me? with my old gr1 this was quite easy, i stop cords and strings sound decay.
with my GR55 when i stop cords , sound end with no queue.
i point to add a CTRL assign or i may look at ADSR controls?
thanks in advance. mauri
Nothing is impossible,if someone else will do for you.
Mrchevy
No need for assigns for this. Just use the EXP pedal (if set for patch volume). Hold the last chord on your guitar and volume fade it with the pedal. If that patch is using the EXP pedal for something else, use the EXP pedal switch to switch over to volume control at the end of the song and then volume fade. You can also do the same volume fade with the GK3 volume control. There are several ways to do it with the GR55 but it depends on what controls are available to use in that particular patch
Gibson Les Paul Custom
Epi Les Paul Standard
Gibson SG 50's prototype
Squire classic vibe 60's
Epi LP Modern
Epi SG Custom
Martin acoustic
Princeton chorus 210
GT100
GR-55
Helix LT
Waza Air Headphones
Boomerang III
Mauri60
Hi Mrchevy! thanks for suggestion.
not sure this may works, i have just a couple of seconds before next song/ patch switch, if i'm lucky and fast i'm on.
Try soon and saw what i can get.
thanks again! Mauri
