How to Connect a Thunderbolt Interface with only One Port + a Monitor
Started by scratch17, August 27, 2015, 02:09:27 PM
scratch17
For a long time, I avoided any Thunderbolt interfaces with only one port. I didn't want to give up my ability to use a monitor on the same buss. So I didn't even consider the UA Apollo Twin interface.
Then I realized that with my Cal Digit TB hub, I could connect the monitor via the HDMI port on the hub. Since the hub has two ports, I can add any device at the end of the TB buss with a single port. Problem solved.
This trick should work with any TB hub that has an HDMI port. Note that only one non-TB monitor will work on a buss. You need a pair TB monitors  (Apple or LG) to connect two monitors on a single TB buss. I've only tried this on a Mac.
VG-99, FC-300, RMC Fanout
RJM Mastermind GT10
Kemper Profiling Amp
Radial JDV Mk3, X-Amp
Mesa Recto Pre + 20/20
68 Fender Bandmaster (AB763)
Marshal AS80R
