GP-10 - Jet flange effect
Started by sorefinger, August 27, 2015, 11:29:09 AM
sorefinger
Has anyone got a deep 'Jet flange' patch that doesn't have trails when you stop playing?
I find that the resonance needs to be higher than 80 but this causes trails to continue in between chords and when you mute the strings.
I've never had this issue with any other flanger. The effect is good but spoiled by the trails.
Redvers
sorefinger
I have resolved this now
The problem was that the Flanger was in front of the Amp in the signal path and the high gain setting was boosting every little sound from the Flanger.
Putting the Flanger after the Amp has given me the result I want, I should have noticed that because I have always placed my Flanger after a distortion in my signal path, Doh!
Pity the modulation effects are in the same group as the drives and compressors, hope they can change this with an update.
Thanks for looking
