Latest on 13-Pin Cable Sources?
Started by carlb, March 16, 2009, 10:39:47 AM
vtgearhead
I'm very happy with a Primova Sound cable from Mr. Code Smart :-)
Quote-''so I  could plug my electric  guitar into an old Webcor tube phonograph ( my 1st guitar amplifier )''
unquote
same here. My 1st guitar amp was a tube phonograph amp. I grabbed it from my parents rather large tv,phonograph,and radio combo unit, and grabbed the speaker also.
mooncaine
As a snotty teenage punk who just wanted to blaze like Hendrix, I burned up a Macintosh power amp, my dad's pride and joy of his hi-fi kit. Oh, man, but it sounded great -- throughout the neighborhood!
mooncaine
I see praise for the Gittler cable, but it's useless to me because of the right-angle plug.
I use external GKs more than internal, and if I ever get around to installing my next internal GK, I'm still going to plan on siting the jack in a place that's friendly to straight plugs, because they're more common. *or so I believe, knowing only what I learn here*
I believe Primova's on War Department duty now, so I may have to go with another Best-Tronics cable. I recently bought some rubber self-sealing rubber splicing tape* for another purpose. Maybe I should wrap the B-T cable's plug end, near the 'strain relieve' section, to keep the plug housing from sliding down. That's my only prob with the cable: the housing is loose and slides away. Well, the pins also don't line up properly sometimes, now that I think about it, but I've only got one. Maybe not a representative sample.
Speaking of the Department, I have to mop the floors today, so I'll make one more post, have another cup o java, and break out the bucket.
*Ace Hardware part #30986
HecticArt
I like the cables with one one right angle plug.
I have one guitar with an external GK and another with an internal. With the internal GK I run the right angle into the guitar, with the external, I run the straight into the guitar.
The Gitlers that I bought are great, but not the least expensive. Code Smart's are supposed to be very good and less expensive. I'm planning on picking up a couple.
mooncaine
Sounds good... unless you use a VG-99. That right-angle plug's no good for me there.
HecticArt
Ahhhh. True story.
The cable doesn't care which direction it's running, but the 99 does.
CodeSmart
Hey, I have plenty of cheap but great 3 and 5 meter cables in stock.
Only straight-straight at the moment, but I'll be arranging new straight-angled 3 & 5 meters asap.
I use them myself all the time because all my Rolands (4 pcs 5m) ended up having severe issues after real world abuse, glitches and noice etc.
Not kidding, these are great. A little bit stiffer cable but it's not a problem.
Try me:
sound@primova.se
#109
Ugh.  Now I'm trying to find out who/where I should get a cable to replace the original cable that came with my VG-99 (2008! 9 years isn't bad is it?)  Everything works except the A string has slowly become less and less present (yes I've used the appropriate recommended pin cleaners discussed here and I think it's the cable internal wiring this time).
The right angle Gittler cable is a no-go since the guitar end on one of my guitars is a GK-3 the other is a Roland Ready Strat with a GK2A.
So both ends will probably have to be straight.  BTPA looks good.
I see a lot of "alleged Planet Waves" cables on amazon.com or ebay for $20 but that seems too good to be true right?
I wonder if this one isn't a Kenwood car stereo control cable rather than a GK cable:
https://www.amazon.com/CABLE-SYNTH-ROLAND-GKC-5-MOORE/dp/B00JMRH4X8/ref=sr_1_fkmr2_1?ie=UTF8&qid=1493001004&sr=8-1-fkmr2&keywords=roland+13-pin+cable
Lots of Roland cables for $40-90:
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=roland+13-pin+cable
This also seems suspiciously inexpensive:
https://www.bonanza.com/listings/20FT-13PIN-Midi-Cable-Roland-GR33-GR20-GR30-Gr-Vg-20-33-Planet-Waves/421253918?goog_pla=1&gpid=177431040781&keyword=&goog_pla=1&pos=2o4&ad_type=pla&gclid=CMrmpeCIvNMCFQGPaQodhKYHrg
Any other suggestions?
Quote from: CodeSmart on April 01, 2017, 02:09:22 PM
Try me:
sound@primova.se
I can say that I fully endorse Codesmart's GK 13 cables,
where I previously had problems with noisy connections and strings dropping out,
Now my tone is noise free and working 100%.
Highly recommended. !!   :)
Get 'em here
sound@primova.se
mooncaine
I have tried one of Primova's cables and I can recommend it. No noise, works, feels solid. Would definitely buy them again.
--moonie
mooncaine
Sorry, am I mixing people up? I meant Codesmart cable.
Coffee just not kicking in like it used to.
CodeSmart
Quote from: mooncaine on July 23, 2017, 10:45:02 AM
No you are not mixing people up.
My name is Robert and my alias here is "CodeSmart" and for the V-Guitar related things I sell here (made outside my normal work) it's done using the "Primova" company name.
The company pays all taxes (and VAT if applicable) properly and legally in the country of Sweden, member of EU.
http://www.primovasound.com/cables.html
http://www.primovasound.com/pdf/latest_prices.pdf
...and similarly, Peter, "gumbo", and "Synth-Linx" are all the same....
...some mornings even I get a bit confused, but most times after the tablets kick in, I'm OK ...   :o
jipegonzo
Try me:
sound@primova.se
Hi !
i've sent you an email
best
jp
arkieboy
Quote from: CodeSmart on July 23, 2017, 11:20:49 AM
Your domain name is showing as pending renewal, Robert!
(I could do with another GK cable, and I still need to pick up a piezo filter off you ...)
CodeSmart
Quote from: arkieboy on August 28, 2017, 10:39:44 AM
Yeah I saw it today. It's been reported. Thanks.
Shel
I've got the Ghost bridge with Hexpander module (works much better than the GK3 for my PRS).
I'm sick of the 13pin DIN's intermittent connections and am changing it to a D-sub 15HD connector similar to a VGA cable connector.  It has gold contacts and the pins are larger and more robust. Plus, it has two locking screws for securing it to the mating plug and I can service it myself without having to spend the money on a new cable.  You can't do a service repair on a 13-pin DIN.  I'm only doing this on the guitar end since it sees much more movement than the GR-55 end...
Quote from: Shel on February 19, 2018, 12:36:36 PM
others have used VGA HD15 cables too.
https://www.vguitarforums.com/smf/index.php?topic=13452.0
I completely understand your frustrations...
...that is why I developed the Synth-Linx Jack alternatives.
https://www.vguitarforums.com/smf/index.php?topic=8888.0
By all means PM for further information if you feel this may help you.
Kind regards,
Peter
Shel
thanks but the deal is, I'm trying to get away from the DIN13.. GraphTech is interested in my results.  I'm hoping they will allow the user the option of the standard 13DIN or the 15HD.  Mounting to the Hexpander board is almost a direct swap (connector mounting hole to bracket positions) but you can't use a right-angle PC mounted connector since it's a different footprint on the board and a new mounting plate is required.  I think it will all be worth the effort and I'm glad I'm not the only one who has thought of this and that the results have been positive.
hoaithang
Quote from: carlb on March 16, 2009, 10:39:47 AM
Hey guys, I'm looking to get a new 13-pin cable for my rig. Ten footer is fine, but I'd like:
- Better 'quality' than the Roland (it's just fine, but it just seems cheap).
- Right-angle out (I know, probably not available). When I play on the couch, the cable gets bent sharply on the couch, etc.
Any ideas now that Planet Waves no longer seems to be making these?
Thanks!
Has anyone buy this 13 pin cable from this seller on ebay, and how good is it
https://www.ebay.com/itm/ROLAND-GR-33-GK-CABLE-13-PIN-DIN-15FT-5M-METER-REPLACEMENT-GKC5/361940279059?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3D9a535f21402141178803741239c5657d%26pid%3D100290%26rk%3D1%26rkt%3D4%26sd%3D361940279059%26itm%3D361940279059&_trksid=p2060778.c100290.m3507
CodeSmart
Not answering your question but as an alternative, I have in stock today:
0.5m S-S 12USD
1.0m S-S 14USD
3.0m S-S 24USD
3.0m S-A 24USD
3.0m A-A 24USD
5.0m S-S 30USD
5.0m S-A 30USD
5.0m A-A 30USD
S=straight
A=right angled
All contacts are gold plated and right angled contacts (A) are stainless steel soldered to ground, to avoid crackling noise.
I'm in Europe, expect 10-20USD for shipping.
If you are in Europe, replace currency with EUR (25% VAT included), if EU and your company excerpt from tax, just let me know.
CodeSmart (email: sound@primova.se)
Shel
For those of us with Graph Tech hexpanders... a much better alternative..
