OnSong Lyrics, Tabs, MIDI, Lighting Control
Started by Elantric, February 25, 2015, 11:52:59 AM
https://itunes.apple.com/us/app/onsong/id502344938?mt=8
http://onsongapp.com/
Description
With OnSong, you can manage huge collections of chord charts and lyrics sheets for your band or worship team on a simple, lightweight device. Quickly pull and reorder lists and flip from one song to the next with ease. Transpose and highlight chords or change font size with a brush of your finger! Playing music has never been more simple. This software is built for live performance musicians.
You can import songs directly from online sources such as Dropbox, or add your own songs with the built-in editor. Just type the song like you would expect and surround your chords in square brackets inline with your lyrics. It's that easy! OnSong automatically detects sections and titles for you when you end them with a colon.
You can also import your existing songs using iTunes file sharing or Dropbox. OnSong supports PDF, Word, Pages, JPG, PNG, TIFF, ChordPro and text file formats.
When you have your set just the way you want it, share it with your band member's iPad's wirelessly. Listen to the song you are playing directly from your iTunes music library, play a metronome or get the music iTunes with just one tap. This app is loaded with features that musicians demand.
Features:
• Simple song and chord entry
• Import, export and synchronize with Dropbox and others
• Pull and change songs for set lists fast
• Flip or tap through all the songs in your set
• Transpose and capo with the brush of a finger
• Highlight or bold chords for visibility
• Change font size and style
• Keep track of your past sets and archive
• Import songs from your online sources
• Play music from your iTunes music library
• Play a click track to a metronome for each song
• Share wirelessly with your band members over Bluetooth
• Send your list to your team via email
• Print your set wirelessly to an AirPrint printer
• Works with many foot pedals such as the AirTurn BT-105, Griffin Stompbox and iRig Blueboard
• Project lyrics or use a stage monitor with VGA, HDMI or AirPlay video support
OnSong Web SiteOnSong Support
What's New in Version 1.993
http://onsongapp.com/releases/1.993/
OnSong 1.993 was released on February 25, 2015. This release contains the following corrections, changes and new features:
REPLACEMENTS
Internet Search has been replaced with the new Add To OnSong Extension. Import From Internet has been legally and technically troublesome for a while and produces less than expected results. To protect OnSong moving forward and to begin to provide better content to end-users, it's been disabled by default. We are working with content providers to enable it on their websites. If you are a content provider and want to be included in OnSong, check out our developers page on ways to integrate with OnSong.
NEW
Scenes lets you control background graphics and lighting to engage your audience with systems from Philips Hue and LIFX. In-app purchase.
AirTurn PED is a new foot pedal from AirTurn. OnSong works with the new pedal and lets you configure up to three devices for six pedals of control.
Add To OnSong Extension in Safari let's you import chord charts from your favorite chord chart services.
Chromecast Streaming for projecting lyrics remotely using an inexpensive device.
iOS 8 Storage Provider Integration lets you import and export to any supported storage app like Google Drive, Box, Dropbox or iCloud. (iOS 8 only)
Multiple Library Support lets you manage multiple OnSong libraries on one device.
Music Library Management lets you import, manage and link custom audio files all within OnSong.
OnCue has been rewritten to use the modern wireless communications stack in iOS 7 and 8.
Overlays allow for complex background images to be created with color. Tap and hold the gradient button in the external video screen to choose a different overlay, color and opacity.
SongSelect Integration lets you searching and import of your favorite songs and then transpose them in the SongSelect format.
Timeline lets you record navigation actions to be played back instead of linear autoscroll.
User Manual has been completely rewritten and made available within the app.
ADDED
Added Half Page Scrolling options to the Foot Pedals Setup Settings menu.
Added a Remove Song option in the set list action menu.
Added the ability to configure the custom foot pedals from the foot pedal setup screen. Tap on the custom foot pedal graphic to choose the foot pedal and then select an action.
Added the ability to change the order of MIDI events when sending them.
Added a prompt if you have unsaved changes in Console and Follow is trying to load a new song.
Added an Audio Trigger in Settings » Navigation Settings » Triggers that can start autoscroll or metronome when the audio playback button is pressed.
Added the ability to import PNG and JPEG files into OnSong to be added to the user's media library. OnSong evaluates the image asset to determine if it is a chord chart or background graphic.
Added the ability to import video files in the standard import screen or externally to the app.
Added music file types to be able to be imported using the "Open In" function of iOS.
Added the Reset Settings option to the settings screen as well as the Tools menu.
Added the ability to determine which songs were already picked in sets that are marked on the same day as the current set.
Added support for push notifications in the order to inform users of important updates.
Added a setting option to wait a specified amount of time before sending MIDI or changing scenes. This allows sets to be navigated and once the delay is up, the change is made. This can be changed in Settings > Navigation Settings > Triggers > Song Load > MIDI or Scenes. Default is "Immediately".
Added the ability to remove individual songs from reports when using "By Usage" song tracking.
Added support for new AirTurn foot pedal frameworks.
Added the ability to submit Base64 encoded files to the onsong:// URL scheme with the following format - onsong://data/filename.ext?BASE64ENCODEDDATA
Added the "Fix Library" tool in the Utilities menu can detect and fix your OnSong library if it becomes corrupted.
Added the ability to change the "Footer Scale" in Settings > Live Settings > External Video > Lyrics Projection.
Added the ability to turn off "double tap to zoom" under Settings » Navigation Settings » Navigation Zones » Zoom » Double tap to zoom.
Added the ability to check if a RWTC song was already downloaded and show it as "greyed out". If the song is imported again, the user is prompted to update, duplicate or skip like other import methods.
Added the ability to import MIDI files into the OnSong audio library and play them.
Added the ability to import MIDI files into the audio media library.
Added the ability to playback linked MIDI files instead of audio tracks.
Added the ability to view stars/favorites from within the sets viewer.
Added an option to turn off OnCue all together in Settings » Menu Settings » Sharing » OnCue Version » Off.
UPDATES
Updated the way OnSong updates the user manual since the user manual content management system has been rewritten.
Updated icons, launch screens and image assets for Retina HD displays such as the iPhone 6 Plus.
Updated Czech and Norwegian language translations.
Updates the way line formatting is read to allow attributes to be written in any order.
FIXES
Fixed an issue where MIDI is not being triggered when autoscrolling to sections.
Fixed an issue where the fast and slow icons were swapped in Settings » Navigation Settings » Scrolling Behavior » Scroll Speed.
Fixed an issue where the English word "Chorus" was not triggering chorus sections when rendering to PDF.
Fixed an issue with MIDI commands being sent multiple times when OnSong is reopened.
Fixed an issue where you could no longer select a book to apply a style to.
Fixed an issue when editing an "Other Source" where the title of the window would display "New Source".
Fixed an issue where the Send Diagnostics screen would not permit scrolling when typing on an iPhone running iOS 8.
Fixed an issue where the Rockin' With The Cross login screen could not be dismissed in some cases when running iOS 8 on an iPhone.
Fixed an issue where the Settings button in the Custom Foot Pedal screen would not function.
Fixed an issue where choosing a different source type such as FTP would cause a crash under iOS 8.
Fixed a crash condition when importing certain files such as .pro5 from Planning Center.
Fixed possible MIDI message conflicts by serializing the sending of complex commands such as the program change with bank selects.
Fixed an issue where a program change (PC) cannot be added to the MIDI event list if another PC was already added on a different channel.
Fixed sorting issues with imported files that include gremlin characters.
Fixed capo issues in the Console caused by double rendering of the song content.
Fixed an issue in Console where minor chords would display as "mi" instead of "m".
Fixed issues with how menus were being displayed when compiled with iOS 8.
Fixed an issue with the song editor "bouncing" out of bounds in iOS 8.
Fixed an issue where the audio subsystem would not shut down when exiting the app causing battery drain and hissing.
Fixed an issue where piano chords only play in the chord inspector but not when tapped in the song viewer with "do as both" enabled.
Fixed issues with various buttons not opening modal views when another is already open under iOS 8.2.
Fixed an issue with live bar menus not being the correct size when compiled under iOS 8 version.
Fixed an issue with cross fade causing multiple audio streams to play and setting the volume high causing distortion.
Fixed issue with how lines were being wrapped to account for "adjust whitespace" preferences.
Fixed a performance issue and crash caused by improperly formatted ChordPro {define:} tags.
Fixed issues with how some modal view controller interfaces would not appear correctly on the iPhone 6 Plus.
Fixed an issue with how search bars appear in iOS 8.
Fixed an issue where the sign-in button would not work when accessing ChordVault.
Fixed an issue where the Console was not respecting print and export restrictions placed on songs.
Fixed an issue where Eb7/9 or other chord formats "over 9" are not recognized in chords over lyrics.
Fixed an issue where "over 9" chords would have the "/9" removed after transposition.
Fixed an issue when transposing to F#. where a chord should be C#/E# and not C#/F.
Fixed an issue with song reporting where daily reports based on usage would not show details.
Fixed an issue when restoring a library from backup where original files were retained.
Fixed an issue when playing back a song from the playback menu where pausing the song and then scrubbing to a different position and starting playback again will not start from the desired point in the song.
Fixed an issue in Console where sections containing only chords were not being displayed.
Fixed a crash issue when loading the user manual the first time due to recursive link loading.
Fixed a crash condition caused by changing settings while the metronome was playing.
Fixed an issue where the "next" song displayed on the stage monitor screen would scroll when the active song was scrolled.
Fixed an issue where syncing to Dropbox would cause an immediate crash cause by invalid song notes. This is now being trapped to prevent a crash.
Fixed a PDF generation issue where the song would print correctly but the exported PDF was scaling the fonts to be smaller.
Fixed an issue where autoscroll would not automatically resume after rotating the screen. It would instead return you to the top of the page.
Fixed threading issues with the OnSong Connect web services to allow simultaneously more connect clients to retrieve data concurrently.
Fixed an issue with track playback with crossfade that may correct volume distortion when playing tracks with crossfade from the All Songs list.
Fixed an issue with the editor bouncing in iOS 8.
Fixed an issue with fade in/out timing caused by thread priority discrepancies.
Fixed an issue when switching between stage monitor mode and lyrics projection mode when the screen orientation is not 0º where the lyrics projection would be incorrectly sized and then stage monitor would return to the incorrect orientation.
Fixed an issue where no Cancel button is available when using the All Songs » + » Export » Email screen.
Fixed an issue where the source type list was not appearing in low light mode.
Fixed an issue where a B# chord (yeah, I know.... like really?) would not be transposed and would instead appear with a single forward slash before it. This now removes the slash and transposes the chord as a C chord.
Fixed an issue where RWTC would crash if you searched for "Grace" and then for "Love" when searching by title.
Fixed an issue where the Console was not respecting the edit restriction and would still allow the user to edit content in the text editor or use editing tools.
Fixed an issue where playing a backing track and then the metronome with the sound settings set to Off would cause the music to stop.
Fixed an issue when printing a PDF when the original document had Nashville numbering that the chords would appear as alphabetic.
Fixed an issue with time signature to double time any X/8 signature and half time any X/2 signature. This logic was not correct before for calculate the time between beats.
Fixed an issue that would record program change with MSB/LSB would be acquired as three separate MIDI events.
Fixed a crash that was caused by non-alphanumeric characters comprising the song title.
Fixed an issue where the console was not adding new songs into the song list.
Fixed an issue where a song written in A and transposed to C would cause F to appear as E# due to enharmonic preferences.
Fixed an issue with the metadata editor on the iPhone would not apply any changes.
Fixed an issue where rotating the screen after audio playback was started and paused would cause the song to start playing again.
Fixed an issue where tapping and holding the ad-hoc networking icon in the live bar would cause it to open, close and open again.
Fixed an issue where backup to iTunes File Sharing was not sending the backup file to the proper destination.
Fixed an issue that was causing MIDI to send twice.
Fixed an issue where the search field in the All Songs list would require tapping twice to open the keyboard after clearing the first search.
Fixed an issue where playing back audio tracks using the Music app on the device would cause a 1/3 of a second delay, skipping crucial parts of a song.
Fixed an issue that would prevent the library from upgrading because the versions table could not be removed.
Fixed an issue where the OnSong Connect API call to delete a device from the whitelist was not functioning.
Fixed an issue where changing the shadow strength in the external video menu would not change the shadow on the screen.
Fixed an issue where black borders would appear around lyrics projection due to changes in how overscan compensation works on different versions of iOS.
Fixed a crash condition that was caused when performing text wrapping on invalid files.
CHANGES
Changed the Registration Screen to include the user's language preference for future, multi-lingual email newsletters.
Changed the Delete Song action to provide a user prompt to prevent accidental song deletion in the set action menu.
Changed the AirTurn Framework to the latest version.
Changed the way OnSong searches by lyrics to search indexed text-only version of the song. Songs are indexed by text-only when OnSong starts.
Changed the share options menu to check the Internet connect periodically and update the status of items in the list automatically as the network status changes.
Changed the add songs menu to check the Internet connect periodically and update the status of items in the list automatically as the network status changes.
Changed the iTunes Export Location name to iTunes File Sharing to be consistent.
Changed the Chords Palette in Console to change when capo or key are changed in the metadata.
Changed the way that OnSong remembers the last loaded song and set to prevent crash loops.
Changed the font size of chords and lyrics to remain independent.
Changed the screens that open from the Getting Started screen to be opened in "page sheet" mode for wider web page viewing.
Changed the default transition speed for lyrics projection to 2.0 seconds instead of 0.5 seconds.
Changed the way the stage monitor mode button works in the external video menu. This is now controlled separately from the other lyrics mode to allow Chromecast to project lyrics while AirPlay or an external screen controls stage monitors.
Changed the default footer scale to 1/3 the lyrics size instead of 1/2.
Changed the iPhone version so that main menu screens accessible from the song viewer have the same "Close" button and are presented over the song instead of using a navigation controller.
Changed the metronome to use a high priority thread for lesser lag on older devices.
Changed the volume of some metronome sounds to maximize output when played with other audio.
Changed the "Next Song" heads-up display to include the key of the next song.
Changed OnSong to always allow tap and hold to open the chord inspector.
Changed the menus in the song editor on the iPhone version to open as modal dialogs instead of in the navigation for a more consistent experience.
Changed the starred/favorite attribute to be assignable to the song, or to songs in individual sets.
Changed the way the new OnCue works where if the user navigates away from the OnCue song, then navigational events will not occur. Only returning to the original song or waiting for the song to switch back will return you to OnCue control.
Changed the song editor to remove the "Close" button in the book picker of the song editor when using it on an iPad.
Changed the way the recycle button in Share » Console » Servers works so it now clears the whitelist, requiring reauthorization.
RELEASE NOTES
OnSong 1.995 was released on March 27, 2015. This release contains the following corrections, changes and new features:
NEW
AirTurn Digit II lets vocalists and speakers control OnSong with a handheld controller. Configuration of an AirTurn Digit II is found in foot pedal settings to map all five buttons to actions.
Audio Input Triggers allow you to perform actions in OnSong based on audio input from the device's microphone, line in or hardware. Supports up to two audio inputs with configurable level thresholds.
MIDI Clock and Playback Sync keeps external devices synchronized with the tempo you set in your songs. You can also tap on the audio live bar button to start, stop and continue MIDI playback. This is configured in the MIDI Settings Menu » Sync.
Large Backups of up to a couple gigabytes can now be created and restored.
Switch Sections allows you to go to specific sections of a song from MIDI events, foot pedals, hot corners or navigation zones.
Enhanced Add To OnSong Extension can now import from lyrics sites as well imported file such as PDF, Word HTML or audio tracks.
ADDED
Added the ability to use storage providers for importing files in all languages.
Added the Fix Library to the Tools menu for all languages.
Added Scenes to the Editors menu for all languages.
Added the ability to import URL files (.url) which can contain multiple sources to be imported.
Added the "Reset Settings" option back to the Tools menu.
Added the option to restore the old SongSelect import process if desired.
Added the ability to edit audio tracks in the audio media manager in iOS 7 and earlier by tapping and holding on the audio track row since the Edit button doesn't appear when swiping.
Added the ability to connect existing SongSelect PDF files to the new system to allow in-app transposition.
Added the ability to toggle flow on and off in the print preview settings menu.
Added the ability for multiple artists to be specified for a song by separating artist names with a semicolon. Commas are not used as separators to allow for "last, first".
Added the artist name to the song list when exported and emailing.
FIXES
Fixed an issue that causes settings to be reset when OnSong starts causing various issues like login or registration screens reappearing.
Fixed an issue where sending diagnostics causes a crash due to a naming conflict between iOS 8 and the Desk API.
Fixed a crash condition when backing up very large libraries including audio and video files. This was due to the ZIP archiving framework storing the resulting ZIP file in memory, causing a memory-related crash especially on older hardware. This has been replaced with a more memory-efficient framework.
Fixed a freezing issue when switching between OnSong libraries due to an infinite loop found in the FMDB framework when a database cannot be disconnected.
Fixed a crash condition when viewing the new SongSelect menu in iOS 5.
Fixed a crash condition when transposing and capoing SongSelect PDF files due memory consumption.
Fixed an issue when importing PDF files using the "Open In..." method that would cause files to not update even if requested by the user.
Fixed an issue that cause F to transpose as E# due to faulty key enharmonic preference detection.
Fixed an issue with the new SongSelect interface where the "No Songs Found" message would appear after the preview screen is opened.
Fixed an issue where lyrics cannot be searched if the lyrics indexing process hasn't completed.
Fixed an issue when exporting OpenSong files that cause them to not be opened due to improperly escaped character sequences.
Fixed an issue where importing songs using the Add To OnSong extension will overwrite songs in the library on certain websites when a unique song title could not be ascertained.
Fixed an issue when outputting PDF files or printing where the original key option was not being respected. This will now output in the original key of the song but if a capo is set, the capo will be applied to the song in its original key.
Fixed an issue where the Existing Song menu no longer opens if the import source list has been customized.
Fixed an issue where the autoscroll button does not toggle off when autoscrolling is complete.
Fixed an issue where AIFF files cannot be imported when using the three-character .aif file extension.
Fixed an issue where the user manual appearing blank when the app is opened due to the file not being downloaded before being viewed.
Fixed an issue where autoscrolling will cease to operate after changing screen orientation.
Fixed an issue where the audio media manager was not appearing correctly in low light mode.
Fixed a crash condition when using a Griffin Stompbox with sensitivity set to a non-zero value.
Fixed an issue when scroll behavior is set to "Jump To Page" that caused the scrolling to not align to the top of the page caused by the top margin of the page not being accounted for in calculations.
Fixed an issue where scrolling the song when using "Jump To Page" scrolling behavior does not recalibrate the current page and causes erratic scrolling behavior.
Fixed an issue where the timeline does not record audio playback notifications properly due to "flutter" in the built-in Music app.
Fixed an issue where saving timeline changes when using Separate Song/Set Styles causes a potential crash.
Fixed an issue when displaying preview screens in some import menus like RWTC.
Fixed an issue in the Dropbox import screen where previously imported files were not appearing as greyed out.
Fixed an issue where the song editor would jump inconsistently when placing the cursor for the first time.
Fixed an issue that caused the icon for AIFF audio to appear as a generic icon instead of an audio icon.
Fixed an issue that prevented audio files from being imported using FTP and other sources.
Fixed an issue where non-chord values such as [n.c.] or [(pause)] are not being fully outputted after a transposition.
Fixed an issue in the new OnCue implementation that caused degraded WiFi performance due to undocumented limitations in Apple's Multipeer Connectivity framework observed when continually browsing for peers on the network.
Fixed an issue where wireless sharing is automatically enabled upon returning to OnSong when it had been disabled by the user.
Fixed an issue with search bar scope buttons where the entire selected button would be teal due to changes in iOS 8 style attributes.
Fixed an issue where song reports were not being overwritten when exported.
Fixed an issue where the text in the search bar is not readable when switching to low light mode.
Fixed an issue when importing chord charts with text conversion to the OnSong file format where the Key: metadata tag was being converted to a chord.
Fixed an issue where using repeated asterisks or underscores would not appear due to line formatting changes.
Fixed an issue where autoscroll continually would skip ahead without scrolling down though a song first.
Fixed an where the metronome would stop playing when audio is played back when running iOS 7 or earlier.
Fixed some list-based menus to better handle font size changed in the Accessibility settings of iOS 7 and iOS 8.
Fixed an issue when changing the sort order of sets where the order was not reflected in the song viewer.
Fixed an issue where annotations would disappear after changing the key of a SongSelect PDF file.
Fixed an issue where libraries can not be created after being deleted.
Fixed a crash condition when using the "Next Song" heads-up display when the next or previous song does not have a title.
CHANGES
Changed the language of the "Import From Internet" screen to explain the new Add To OnSong extension better.
Changed the initial SongSelect screen to better explain the changes in the new version and lock out the search function until the user signs in.
Changed the new version of OnCue to turn off nearby peer browsing when not directly in use due to a bug in iOS that causes severely degraded WiFi performance on some wireless networks.
Changed the way the percentage-based progress indicators operate when importing from Dropbox, FTP and WebDAV to account for download status of each file.
Changed the way that line formatting is applied to allow multiple asterisks, underscores or other line formatting symbols to be repeated across the page without being removed.
Changed the way the Add Songs menu detects network connections to be more responsive.
Changed the way Add To OnSong Safari extension imports files so they are asynchronous.
This allows the user interface responsive when importing larger files.
Changed scrolling behavior to "Jump To Section" when a Chromecast for lyrics projection is connected.
Changed the way the last song and set are retained so that in the event of a crash, a crash loop is avoided by a default "Welcome to OnSong" song is avoided.
Changed the way song titles are extracted to remove line formatting syntax before saving.
Changed the duration picker to remove the border since it is now in a tab controller.
Changed the song viewer to open the chord inspector when tapping and holding on a chord.
Changed the Add To OnSong extension to be localized in all supported languages.
Changed the way the font used for exporting and emailing PDF files back to the old method that accounts for the current screen orientation.
Changed the way instructions are outputted to the screen when placed in the flow tag so that the instructions do not create another section by themselves, but are associated with the previous section.
Changed the default OnCue version back to iOS 5/6.
Changed the names of OnCue versions to "Original" and "New" instead of using iOS version numbers.
Changed the registration screen to provide an activity indicator in the upper right corner.
https://onsong.desk.com/
iOS 8 CAUSING ONSONG TO FREEZE AND CLOSE RANDOMLY
All of us at OnSong have been working around the clock to handle a number of issues that users have reported over the past few weeks.  It's becoming clear now that all of these issues are caused by bugs in iOS 8.  These bugs appear to have been caused by compiling OnSong under the iOS 8.2 SDK and effect all versions of iOS 8.
We have submitted numerous bug reports to Apple regarding these issues. Despite requesting a status on these issues over the last few weeks, we have not had any firm assurances that they will be corrected in iOS 8.3.  We are working to resolve these issues on our own in the hopes to produce a performant version of OnSong for our users.
There are a growing number of websites and forums that detail these issues.
This webpage describes the most common problems that you may be experiencing in iOS 8 with regards to battery usage, Bluetooth connectivity and WiFi problems.
http://www.gottabemobile.com/2015/03/11/9-common-ios-8-2-problems-how-to-fix-them/
Because you trust us for answers, OnSong is continuing to invest in hardware and staff resources to try to troubleshoot and find solutions. The following is a synopsis of unresolved bugs to keep you informed:
Random Crash After Waking The Screen
So far, OnSong 1.995 crashes due to programming errors have been quite low. However iOS 8 is shutting down OnSong due to memory pressure.   This happens when so much memory is being used that other core services are in jeopardy. It's like being on a life boat that is sinking and picking the biggest person to take a swim.  However this memory bloat is not caused by OnSong. We have isolated this to GameKit, an Apple framework that OnSong uses to power the original OnCue and which is enabled by default in OnSong 1.995.
Let's say you have OnSong up and running and turn off your screen and then turn it back on. During that time, iOS pushes OnSong into the background and then brings it back to the foreground and active.  That process alone causes GameKit to begin to consume working memory very quickly and uncontrollably at a rate of about 10 MB per second.  Just having a GameKit session created for transmitting data over Bluetooth will cause this erratic behavior.
GameKit was deprecated in iOS 7, but OnSong continues to use it to support our original iPad users.  Until Apple can correct this, we are submitting a version of OnSong that defaults to the new version of OnCue on iOS 7 and higher. While the new Multipeer Connectivity framework is also buggy (see here and here), we need to use this until Apple can correct the issues with GameKit.
To prevent OnSong from crashing due to memory pressure, go into the Utilities menu (gear icon), choose Settings, and then Menu Settings, Sharing, OnCue Version and set that to "New".  We also strongly urge you to use OnSong Connect instead since it is not bound by Apple's frameworks and can support many devices and applications over standard WiFi communication protocols.
Freezes and Crashes After Waking The Screen
While we first thought that all reported crashes were related, we were able to pinpoint another crash caused by iOS 8.2.  In this case, sleeping the screen and turning it back on will cause OnSong to "hang".  This is caused by the AirTurn framework, used for foot pedal connectivity, asking iOS for a list of Bluetooth devices.  After resuming from the background, this request "stalls" for an unknown reason which is what causes OnSong to freeze.  If an app freezes when resuming for too long, iOS 8 then closes the app.
So yes, you've read that correctly.  iOS 8 is hanging on a simple request for Bluetooth devices which freezes OnSong which in turn results in iOS 8 shutting down the app.
We've contacted AirTurn about this issue and they have reported this as a bug to Apple. We have sent crash logs and other information to AirTurn and Apple to resolve this issue. AirTurn is in agreement that there are serious issues in the iOS 8.2 Bluetooth functionality.
Further tests show that this issue has been resolved in iOS 8.3 which is currently in beta. We have also found some Bluetooth performance improvements by going into the Settings app, choosing General, Reset and tapping on "Reset Network Settings". While this will remove all network passwords, and require you to pair with Bluetooth devices again, it has seemed to help improve Bluetooth performance.
Hard "Kernel Panic" Crash When Using Stage Monitor on Lightning Video Adapters
We have reported this particular issue to Apple late last year and have not yet found resolution.  We have made several videos documenting this and have proven that it happens only on iOS 8 devices when using a Lightning port video adapter, although we have begun to hear reports about users also experiencing this when streaming to an AppleTV with AirPlay under iOS 8.2.
Apple has responded to this bug and have reported that they could replicate the choppy animations, but were not able to replicate a crash.  We then sent another video with the latest version of iOS 8.3 beta with a fresh version of OnSong and were able to cause a crash within a minute.  We have not yet heard back from Apple whether this would be fixed in iOS 8.3 or regarding a workaround we could implement to prevent a crash.
Network Connectivity Issues
We have also been fielding a number of questions regarding WiFi networking performance within OnSong. We have run through a battery of tests with a number of routers and have determined that these issues reside in a particularly nasty class of iOS 8 bugs called WiFried. The general gist is that some operations using WiFi on iOS 8 cause severe network degradation. In fact, just uploading a large file to Dropbox from within OnSong or the Dropbox Storage Provider will cause Internet access for other devices on the same network to fail.
We've been in conversation with Dropbox regarding this issue, but have found that other services exhibit the same behavior under iOS 8. Earlier versions of iOS do not exhibit this behavior. Dropbox believes this is an issue with the iOS 8 networking stack and we are trying to determine ways to work around this issue.
The Solution
We are currently in a holding pattern until Apple can fix these issues permanently.  In the meantime, we are finalizing a new version of OnSong to temporarily work around these problems so that their impact is not as widely felt.  We will also continue to work with Apple to hopefully resolve these serious issues in iOS 8.3 since that appears to be the only way to find meaningful resolution.
What You Can Do
The first thing to remember is that apps automatically update in iOS unless you disable automatic app updates. Since OnSong is constantly being improved, we recommend that you turn off automatic app updates so you can control when to review and implement new features.
You can also help by making these issues heard by contacting Apple. We have a relatively small voice and Apple tends to move faster when it effect more users.  By making your voice heard, we hope to find resolution on these issues faster.
In the past we were able to sufficiently test OnSong with new iOS updates since there we not too many major changes with each release and they were relatively free of bugs that affected apps.  iOS 8 has had a much more aggressive timetable and we feel that the need to support more devices, including the Apple Watch, has resulted in an untested platform. Many of these issues have been serious with wider implications than previous versions and we have been spending an inordinate amount of time testing, documenting and reporting to Apple instead of focusing on our app.  We think Apple can and should be doing a better job of releasing stable platforms.
We recommend that if you are using OnSong in a live scenario that you do not update your version of iOS until you have time to practice and implement it in your performance. OnSong will do a better job of communicating issues that are found with iOS and try to head off any serious issues in the future. We also apologize for the delay in sending this message as we needed time to determine where the issues lie and how they can be addressed.
Conclusion
We don't want this message to sound like we are "passing the buck".  We have made mistakes in the last few builds and we take responsibility for those. Reviewing our release notes (1.993, 1.994, 1.995 and the upcoming 1.996)
http://onsongapp.com/releases/1.996/
should indicate our commitment to fixing any and all reported issues quickly, even if many are caused by changes in iOS  In this case we believe we needed to communicate that we are stuck until Apple moves to correct serious issues that are affecting all of us.
Thank you again for choosing OnSong. We look forward to continuing to serve you and to make the best app for musicians possible.
Jason and Jaime Kichline
OnSong 1.998 Now Available!
We are happy to announce that OnSong 1.998 is finally here with some great
new features and fixes based on your feedback. OnSong now includes a
new color picker features that allow you create and choose custom colors!
We've also made a number of enhancements for those who use
lyrics projection, Console, editing, Scenes and more!
To see all of the updates, check out the OnSong 1.998 Release Notes
Join Us At The Swell Conference
Featuring Rita Springer, Doug Gould and more...
OnSong will be leading a conference and teaching workshops for musicians and artists in houses of worship.  At this two-day conference, you'll get
one-on-one support from OnSong staff and training from a great lineup of worship teachers. Best of all, its super-affordable to bring your whole team.
Join us August 14-15, 2015 in Middletown, PA and receive 10% off of your registration by using the promo code ONSONG10
Register Today!
New DUO and QUAD with BT-106
Price Drop: AirTurn BT-106 Foot Pedals
Now is the best time to go hands-free with OnSong
Just when we thought AirTurn had outdone themselves with the
AirTurn PED, they've completely overhauled their original line of
foot pedals with more functionality and a lower price point.
The revolutionary two-pedal BT-106 is now Just $99. They've redesigned the module to include a membrane switch that's easier
to use and can be detached for handheld use also.  You can even configure up to six actions starting in OnSong 1.998.
The new BT-106 DUO and QUAD work with all versions of
iPAD, iPhone, iPod Touch, Mac, PC and Android.
Buy AirTurn DUO for just $99  or   Buy AirTurn QUAD for just $149
OnSong Overview Video - UPDATED!
Getting started with OnSong
This new video will provide you with an overview of everything you will need to get started with OnSong.  From accessing your set lists, importing songs, using foot pedals and more, everything
you need is right here!
Check out the Updated OnSong Overview Video!
Whether you are an avid OnSong user or new to the OnSong Community, it's a great time to check out all of the tutorial videos
available on the OnSong website.
Control DMX Stage Lighting with Scenes
OnSong now supports DMX control over WiFi
Scenes in OnSong lets you alter lighting to match your music.
Until now it's been limited to smart bulbs like Philips hue and LIFX.
OnSong 1.998 brings the ability to control stage lighting over DMX
using the ArtNet protocol.  You get RGB control over every light and can even control other traits just as easily.
Check out the Video Tutorial
Let Us Know How We Are Doing!
We are working hard to make the best app possible
If you have any issues with OnSong, please let us know immediately
by contacting us at support@onsongapp.com. We will gladly get it fixed and put you on our beta team to help ensure absolute quality in what we do.
If you love OnSong, please give us 5-stars on the iTunes App Store!  It really helps us out and allows us to to refine the app
and continue to support our users free of charge.
Give Us Five Stars  or  Let Us Know Why You Can't
iOS 9 is Coming Soon. Be Prepared!
Apple is set to launch iOS 9 within the next few days and we at OnSong want to make sure you are prepared.  It can be unsettling to wonder "should I upgrade or not?"  To help reduce that anxiety, we want to let you know our plan and offer a few tips when considering an iOS upgrade.
If It Ain't Broke... Throughout this past year we've worked to update OnSong to workaround iOS 8 issues as Apple has released new versions. Please be aware that operating system upgrades can cause issues in the many apps you use.  Confirm that all of your critical apps are working as expected before making the leap.
Be prepared.  While you should never experience data loss when upgrading iOS or OnSong, there is always the potential for an unexpected problem.  We recommend that you always keep a backup of your OnSong Library and iOS device before you upgrade.
Allow plenty of time.  Never install an iOS upgrade or OnSong update prior to a show. Give yourself plenty of time to use the software and learn about new or changed features. OnSong provides full release notes and documentation to get up to speed.  This also gives us plenty of time to answer your questions or help to get you up and running. Be sure to disable automatic updates so you have control when updates get installed.
Be patient.  OnSong 1.999 will launch later in September after iOS 9 is released.
This is intended to address any last minute problems that might appear in the final version.
Follow us.  Facebook and Twitter are great ways for us to keep in touch. We will let you know important information about iOS 9, OnSong and other apps so you can make an informed decision on the best time to push the button.
While our team has been testing OnSong 1.999 on the beta versions of iOS 9 for the past few months, we can always use your help to ensure a seamless transition.  If you have a device you don't use in a live scenario, you can install and preview the iOS 9 beta today.
You can also join the OnSong beta team to help us make OnSong awesome.
Find out what devices are supported and new features you can expect. Learn more about iOS 9
iPad 1 and iOS 5.1.1
When the original iPad debuted in early 2010, it prompted us to ask, "could this replace paper and the binder?"  It inspired us to quit our day jobs and get busy.
More than five years later, that question has been answered with a definitive "yes". Nothing excites us more than what this humble device has achieved.
We've continued to support our original iPad users with new updates, bringing as much functionality as we could with each new build.  Unfortunately, OnSong 1.999 will be the last version with support for iOS 5.1.1 and the original iPad.
The reason is simple: It's no longer supported by Apple.
The development tools we use to make OnSong can no longer build to iPad 1 devices.
This makes it impossible to maintain a quality product while also providing support for t
he majority of our users and advancements in mobile technology.
The good news is that you'll still be able to use OnSong 1.999 when it is released and continue to download it from the App Store.  We will provide cross-version interoperability as long as we can.
Plan to upgrade to a newer device so we can provide you with future versions of OnSong and maintain support of many other apps that you use. With new models of iPads on the horizon,
now is a great time to buy.
OnSong 1.999 Coming Soon!
We are working hard to make OnSong 1.999 the best release ever.  We've worked hard on stability and compatibility
with iOS 9 and have added some great new features like:
Spotify Integration for backing tracks
Updated playback and countdown displays
Bluetooth over MIDI support
Section assignments that work with Flow
Export and import chord diagrams
...and much more!
This will be our last release for a while so we are giving it our best.
We have a lot of things in store for OnSong 2.0 so we thank you for
your patience as we build the next generation of live music performance tools.
OnSong 1.999 Release Notes
http://onsongapp.com/releases/1.999/
iOS 9 is Coming Tomorrow. Be Prepared!
Apple is set to launch iOS 9 tomorrow and we at OnSong want to make sure you are prepared.  It can be unsettling to wonder "should I upgrade or not?"  To help reduce that anxiety, we want to let you know our plan and offer a few tips when considering an iOS upgrade.
Follow us.
https://www.facebook.com/onsongapp?_rdr=p
http://www.apple.com/ios/whats-new/
http://onsongapp.com/releases/1.9994/
RELEASE NOTES
OnSong 1.9994 was released on March 28, 2016. This release fixing the following issues:
ADDED
Added the ability to set an action to switch to a specific song.
Added the ability to change the icon of songs by tapping on the icon in the songs and sets list. Icons are cycled as you tap.
Added a backup restoration progress screen instead of locking the user interface with no information.
Added the ability to toggle the input assistant bar when using the song editor in the song editor setting screen.
Added the ability for OnSong to prompt for updating or duplicating when beaming a set via OnCue or OnSong Connect.
Added the ability to tap in the menubar to hide the on-screen keyboard when editing sticky notes on the iPhone.
Added the ability to set up OnSong as a virtual MIDI destination.
Added the ability for OnSong to display if a MIDI connection is virtual.
Added the ability for the MIDI sources and destinations to update automatically when devices are plugged and unplugged.
Added a blur to the status bar so it matches the menubar.
CHANGES
Changed existing settings to disable timestamped backup files if automatic backup is enabled.
Changed the Apply Styles screen to apply the numbering system if selected.
Changed the default behavior of the keyboard in the song editor to include the input assistance bar.
Changed the way the automatic backup feature works with the timestamp. Turning on the automatic backup will automatically turn off the timestamp with no prompt. If they try to turn it on again, then it will prompt.
Changed the ArtNet DMX manager to reconnect when the app becomes active to allow changes in network to resolve.
Changed the label for MIDI chord playback to "Chord Playback".
FIXES
Fixed an issue where automatic backup files would consume too much storage space.
Fixed a crash condition when using the drawing tool on iOS 8 and earlier.
Fixed a crash condition when opening the Print Preview screen on iOS 5 and 6 due to how printing of annotations was implemented with newer framework methods.
Fixed a crash when attempting to open the Background Media Library from the Editors menu on iOS 5. Background media management is not supported on iOS 5.
Fixed an issue with the menubar overlapping the song content when rotating the screen.
Fixed an issue with the Rewrite Into Key process that wouldn't declare the key properly.
Fixed an issue where printing or exporting PDF files containing drawings would cause the first page of the printout to be blank aside from annotations.
Fixed layout issues with the date picker in the set editor that are caused by Apple fixing layout of that component in newer versions of iOS 9 which had been worked around.
Fixed an issue where OnSong fails to create or find a library.
Fixed an issue where inter-app audio was disabled in the build settings.
Fixed an issue with audio cutting out when the metronome is enabled.
Fixed a crash condition with the PageFlip FireFly on iOS 6.
Fixed an issue with custom-colored lyrics overlays not resizing.
Fixed a layout issue on the AirTurn Digit configure screen.
Fixed an issue where the Remove Capo output option had no effect on emailed documents.
Fixed an issue where tutorial videos would not play for configuring the AirTurn DUO and Digit II.
Fixed an issue when synchronizing transposed SongSelect songs which caused the transposed files to be imported creating duplicates.
Fixed an issue when transposing back into the standard key where the transposed root is not retained.
Fixed an issue with background operations with MIDI clock.
Fixed an issue with the naming of external MIDI devices.
Fixed an issue where the MIDI clock adjustment would not output correctly for 100%.
Fixed an issue with the MIDI driver being initialized twice.
Fixed an issue where the Chord Builder opens automatically on the iPhone and prevents editing.
Fixed an issue where deleting a song in the songs menu will scroll to the default song at the bottom.
Fixed an issue that would cause the ArtNet DMX manager to lose connection if a network has been changed.
Fixed an issue where invisible whitespace characters in a chord could cause transposition to not occur.
Fixed an issue with the Quick Pick screen that would cause the song viewer to redraw and move the current song to the top of the screen.
Fixed an issue with sticky notes where the border shadow would appear even when the opacity is dropped to a low number that is not zero. The shadow opacity is not keyed off of the opacity of the note color.
Fixed an issue in the color builder where you cannot create a fully transparent color.
Fixed an issue where the Editors menu would not be dismissed upon opening the Audio Media or Background Media Library on iOS 6 and earlier.
Fixed an issue where the songs in a set do not remove "The" when sorting alphabetically.
Fixed an issue where the Quick Pick screen does not work under iOS 5 and 6 due to the lack of a database function required for advanced sorting. This has been resolved by falling back to the original sorting method on those versions.
Fixed an issue with how the show/hide menubar is calculated that caused overlap onto the song caused by iOS 9 not returning the height of the status bar when hidden.
Fixed a token validation error that causes Spotify integration to crash.
Fixed an issue where chords are not showing in Console.
Fixed an issue where the action sheet appears under the keyboard when editing a note on a compact device like an iPhone.
Fixed an issue when assigning actions to sticky notes when using an iPhone.
Fixed an issue where using autoscroll and then tapping the scroll down pedal does not advance to the next song in the set but rather scrolls to the top until this is repeated.
Fixed an issue where the autoscroll forward pedal would continue to toggle autoscroll even if the page was already scrolled.
Fixed an issue when transposition with bracketed whitespace instances.
Fixed glitch with audio when moving to background.
Fixed an issue where chord lines settings were not being respected by Console.
Fixed a display issue when using mid-song transposition with the key tag.
Fixed a potential crash condition when the backup file is not created.
Fixed a potential crash condition that occurs if a byline cannot be determined in Internet-based importation.
Fixed a possible crash condition when attempting to move the lyrics projection preview.
REMOVALS
Removed the ability to use the lyrics projection preview widgets on iOS 5 and 6 due to implementation and performance issues.
Removed the ability to open the Background Media Library editor on iOS 5 since background media is not supported on that platform.
  Powered by Translate
Call me stupid and frustrated. I was gonna start a new topic ,but couldn't find where
Is anyone here using or have switched to Onsong, from Setlist Manager and If so why
QuoteCall me stupid and frustrated. I was gonna start a new topic ,but couldn't find where
I dabble with both - bands I get hired to sit in with use either Onsong or SetlistMaker, so i own both.
FreeTime
There are a LOT of fixes for OnSong and more to be addressed, like edited songs that don't take, the pre-edited version always shows up. A simple-to-use app that scrolls lyrics for you this is not. In its defense there seem to be fixes for some things, but it would be nice if it just worked as opposed to having to read manuals and trying different things, it cuts into my playing time.  About a month ago, mid-song the lyrics started randomly scrolling by very fast,restarting did nothing, turns out that the bassplayers iphone (which has onsong in it) must have been causing it; it stopped when he (and his phone) left. It seems that when the developers turned it into a software suite they inadvertently broke things elsewhere. Bottom line is, I would like an easy to use app that does away with the binder. I'm keeping the binder too, just in case.
I have been using Setlist Manager to scroll lyrics and send MIDI program change to my Kemper and GR55. It works pretty much most of the time. Now if I could just get the Bluetooth to work consistent
Has anyone tried the Yamaha MD-BT-01 bluetrooth-midi
QuoteI have been using Setlist Manager to scroll lyrics and send MIDI program change to my Kemper and GR55. It works pretty much most of the time. Now if I could just get the Bluetooth to work consistent
What Bluetooth / MIDI Interface are you currently using?
QuoteYamaha MD-BT-01 bluetrooth-midi
yes - its prone for breakage
https://www.vguitarforums.com/smf/index.php?topic=17148.msg122529#msg122529
and reports are it drops notes compared to other options (PUC+) (QuiccoSound mi.1)
utensil wrote>
QuoteFor anyone considering the new Yamaha UD-BT01 for use
http://usa.yamaha.com/news_events/pianos_keyboard/yamaha_ud-bt01_and_md-bt01/
I have tried it with the fishman triple play and compared to the new PUC+ which works perfectly(after a firmware update)
https://www.vguitarforums.com/smf/index.php?topic=15697.msg112015#msg112015
Yamaha UD-BT01 drops notes frequently. Any fast runs on the guitar result in many missing notes , other than that latency is acceptable and it connects fine 9 out of 10 times. Personally I will be using it for my kids piano.
mordecai
OnSong Console is now available as a native application on your Mac. It's a powerful tool that allows you to directly manage your library located on an iOS device running OnSong.
You get a real-time preview of your OnSong library to import songs and edit songs. You can even create and rearrange sets and books for your upcoming gig. When you're all done, one click saves the chord chart back to your library on your iPad, iPhone or iPod touch.
Features:
• Import charts and files directly from your computer.
• Edit chord charts with a realtime preview of how it will look.
• Convert PDF and Word documents to text-based chord charts.
• Build sets and books from a desktop interface.
• Print to any printer that works with Mac OS X.
• Use Palettes to transpose and capo songs.
• Style your chord charts with chord highlighting and colors.
• Adjust font sizes for added visibility.
Requirements:
• OnSong 1.9996 or higher running on an iPad, iPhone or iPod Touch.
• Local WiFi or wired network connection
• OS X 10.11 or higher
We've tested OnSong running on iOS 11 since mid-summer and have had nearly 250,000 user sessions running the current version of OnSong on the latest operating systems from Apple. We are pleased to announce that the current version of OnSong 1.99995 works well on iOS 11.
This doesn't mean that it's absolutely perfect. If you use external video for lyrics projection or stage monitor mode, you will need to know some workarounds.
We have a new version nearly ready to release.  We are waiting for our hardware and service vendors to update their frameworks to ensure future compatibility. In the meantime, you can take a look at what we are up to as we continue refining the upcoming release including Google Drive and Flic smart button integration.
This update is available for iOS 9 and higher.
Older iPads can still install and update to the last compatible version of OnSong.
OnSong 1.99996 was released on November 20. 2017. The following items have been added, changed or fixed:
ADDITIONS
New! Drag and Drop to manage your library and media in iOS 11 on iPad!
New! Google Drive support for importing and exporting songs, backing tracks, and background media!
New! Flic Smart Bluetooth button support for performing 40+ actions!
ADDITIONS
Added the ability to change your name and email address registrations using the settings screen.
Added the ability to step through timeline events as an assignable action.
Added the ability to control lighting fixtures, colors and dimmer using the master dimmer control.
Added the ability to set the color model of a DMX light to RGB, CMY or HSL.
Added the ability to duplicate steps in scenes.
Added the ability to reorder list items using drag and drop.
Added the ability to drag songs, sets and books out of the app.
Added the ability to automatically show/hide the song list independent from the menubar.
Added the ability to hide the menubar by swiping up on the bar.
Added the ability to swipe from the left and right edges to open the song list depending on menubar direction.
Added the ability to press a pedal or character sequence in the custom foot pedal screen to open the action picker.
Added support for pressing ENTER, ESCAPE, TAB or SPACE in the custom foot pedal screen.
Added the ability to rename an AirTurn device in BLE mode.
Added support to connect, configure and control multiple BLE AirTurns.
Added ability for OnSong to look for updates for AirTurn BLE devices when configuring them and redirect to the AirTurn Manager app.
Added the ability to open OnSong to a specific foot pedal screen for configuration.
Added the ability to search by song number.
Added the current capo setting in song lists through out the app next to the key.
Added the ability to know which song was last viewed.
Added the ability to see the source that a backing track was linked from.
Added the ability to delete multiply media items from the OnSong Media Library.
Added the ability to report errors when authenticating to SongSelect that can help troubleshoot common sign-in issues.
Added the ability to use numbers for higher fret values if using spaces between values.
Added the ability to create a new message when picking a message from the Action Picker interface.
Added the ability to delete messages when picking them from the action picker.
Added the ability to configure MIDI commands to be used when sending tempo.
Added the ability to have MIDI clock change the current tempo of the metronome without effecting the song tempo.
Added the ability to configure "Adjust" actions to use absolute numbers instead of relative values.
Added the ability for the MIDI trigger list to be reorderable.
Added the ability to view which message you're switching to in the MIDI Triggers list.
Added the ability to view which section you're switching to in the MIDI Triggers list.
Added the ability to view which song you're switching to in the MIDI Triggers list.
Added the ability to view which scene you're switching to in the MIDI Triggers list.
Added the ability to keep ortho mode selected when leaving the drawing bar.
Added the ability to change the size of the drawing tool from the drawing bar when running in compact mode except on very small screen sizes.
Added the ability to switch between local and shared storage locations in settings.
Added the ability to omit media files from the backup.
Added the ability to enable/disable volume indicator.
Added the ability to rate and review the app in iOS 10.3 and higher.
UPDATES
Updated to the latest version of the AirTurn framework for future compatibility and features.
Updated to the most current version of the Spotify SDK which may address authentication persistence.
Updated the user interface for improved accessibility throughout the app.
Updated the Flurry SDK to be iOS 11 compatible.
Updated the Parse framework to be iOS 11 compatible.
Updated all translations.
CHANGES
Changed the app to only support iOS 9 and higher.
Changed the code base to use automatic reference counting for more streamlined memory management.
Changed the web address displayed for Console to omit the port number and use the local hostname instead.
Changed the console screen to toggle between IP address and host URL when tapped.
Changed the web browser in OnSong to use the Safari view controller for memory efficiency and modernization.
Changed the song list export to include capo even when transposition is disabled.
Changed the way tab characters are handled in the song viewer to output based on a spaced grid instead of simple character replacement.
Changed the storage location of new OnSong libraries into a shared app group which allows access of the library and settings from other apps approved by OnSong.
Changed file exports to use the date that the song or set was last modified instead of the current date and time.
Changed the drawing tool to turn off ortho mode each time it is closed to avoid confusion.
Changed the offset in DMX fixture editors to channels that start at 1 instead of 0.
Changed the chord builder in the song editor to be accessed via a "+" button in the quick chord bar to avoid redundant features and fix an issue in iOS 11.
Changed the term "Set" to "Choose Set" when using multi-select "Add To..."
Changed the Storage Provider screen to be larger to accommodate for iOS 11's new Files interface.
Changed the print preview screen to be larger so more of the print preview is visible.
Changed the title of the Choose Custom Track menu to Choose Custom Track instead of Choose Track.
Changed the "Listen for Chords" settings in the MIDI Settings screen.
Changed the chord inspector so chords are played when tapped, not just when they are selected.
Changed the top border to zero on the iPhone if one has not been set.
Changed alerts when deleting songs, books and notes to show the delete button as destructive in red.
Changed the default borders of the song viewer to remove the statusbar height since it now works properly under iOS 11.
Changed the way multitasking split screen handles the keyboard when using foot pedals by implementing the latest AirTurn framework.
Changed the way sets are duplicated to update to the current date time and copying the name of the original set with the word "Copy" after it.
Changed MIDI settings to enable one-based index (1-128) in MIDI Settings by default.
Changed MIDI screens to implemented the one-based index throughout.
Changed the song media library to show an error if the song media file is missing and prevents it's selection.
Changed the console viewer to display transpose tags the same as the iOS app version.
Changed the settings system to refresh the screen almost instantly after tapping "Done".
FIXES
Fixed an issue when reordering songs within a set.
Fixed an issue where drawing and selecting a new color and then moving that to the front of the list makes the color disappear.
Fixed an issue with the save button disappearing when a very long song title is loaded in Console.
Fixed an issue when importing ZIP files with Word documents that contain special characters.
Fixed an issue where sticky notes that contain empty text can cause a crash when printing.
Fixed an issue where the duration of a set is calculated on the duration set on the master song and not on the duration of the song in a set when separate styles is enabled.
Fixed issues with connecting to insecure websites that would cause iOS to prevent access due to new security requirements.
Fixed an issue where the Transpose and Capo screen is not able to be closed when operating in compact mode in a split view.
Fixed an issue where the Mute Metronome action had no effect on the metronome.
Fixed an issue with chord detection using certain enharmonic symbols.
Fixed an issue with UI colors in the SongSelect search box.
Fixed an issue with the font selector in the Style Preferences menu where it would not display correctly under iOS 11.
Fixed an issue with the status bar color and behavior in iOS 11.
Fixed an issue with the MIDI assigned to the song not firing when a viewport is set.
Fixed an issue where button text does not wrap on the Getting Started screen when compiled to iOS 10/11.
Fixed an issue where the Reset Song action does not reset the switch section logic.
Fixed an issue where using an "H" in a flow repeats the header instead of using a section labeled as "Hook".
Fixed an issue where switching from Nashville numbers to letters and then back again the Nashville will not reload without leaving the song and coming back to it.
Fixed an issue where renaming a library can cause it to not be able to read the database file until after a restart.
Fixed an issue where motion backgrounds would not start automatically when using AirPlay.
Fixed an issue where zero-width space characters would prevent chord detection.
Fixed an issue with switching back to the standard font from a monospaced font when using sot/eot tags in a PDF export.
Fixed a crash condition when importing text files.
Fixed an issue with very long "copy" file names which is causing files to not be viewable.
Fixed issues with certain web services that use insecure SSL no longer functioning once compiled in the latest versions of iOS.
Fixed an issue where you couldn't change versions in worshipplanning.com.
Fixed an issue that can make the drawing toolbar unresponsive in iOS 11.
Fixed spacing issues in toolbars when compiled in and due to a bug iOS 11.
Fixed an issue when creating a custom message where choosing a custom color will cause any message text to be cleared.
Fixed an issue that would causes the song viewer to cease scrolling once a sticky note was moved.
Fixed an issue with typing multiple hyphens in the song editor caused by iOS 11 smart punctuation.
Fixed an issue with how font sizes are calculated for lyrics projection on iOS 11.
Fixed an issue with the Fix Library alert that appears that causes user interface issues on iPhone.
Fixed an issue where the song viewer would be blank instead of showing the default song after deleting a library.
Fixed an issue with typing in search bars where the keyboard would disappear, requiring additional taps.
Fixed an issue when exporting PDF files containing drawings that have been erased.
Fixed an issue that could cause songs to appear in other books without user interaction.
Fixed an issue with extra space characters being appended to lines when exports as a text file.
Fixed an issue where loading a set from setting would not automatically update the set in the song list.
Fixed an issue where integrity checking would fail on the database, but cannot be fixed which causes a repeated error to appear.
Fixed an issue where adding songs to a set via multi-select would not reload the set in the song viewer.
Fixed issues where a login prompt would not permit the login screen from appearing.
Fixed an issue when reordering import sources.
Fixed an issue where you can't undo spaces in the song editor.
Fixed an issue with calling redo in the song editor.
Fixed an issue with content insets in the song editor since we've updated to use the navigation bar instead of a toolbar.
Fixed an issue with compact mode and the menubar.
Fixed an issue with sorting items correctly when reordered in a table.
Fixed an issue where added timeline events would not properly update the timeline timecode.
Fixed an issue where song change MIDI commands would not send.
Fixed an issue where ratio of the preview widget does not update from settings when a screen is not connected.
Fixed issues with the menubar not displaying properly on iOS 11.
Fixed an issue where the menubar would not show on the song editor with the import sources list had been modified.
Fixed a crash condition when unticking OnSong in the MIDI/sources/devices/virtual menu.
Fixed background color of a search bar when viewed on iOS 11.
Fixed issues with the keyboard appearing in the foot pedal setup screen.
Fixed a toolbar alignment issue in the timeline menu due to iOS 11.
Fixed an issue when adding songs to a set using multiselect.
Fixed a crash condition when rotating imported documents.
Fixed an incorrect German translation when attributing a song to artist in an email.
Fixed an issue with song details user interface in the audio library manager.
Fixed an issue where MIDI files are not playing in the audio media editor.
Fixed an issue when searching a song in all songs, words with apostrophes aren't recognized.
Fixed an issue when a MIDI event is added to the MIDI Trigger list, it appears at the bottom of the list, but the next time it appears elsewhere.
Fixed an issue where large libraries that need to be fixed cannot be fixed.
Fixed an issue where changing split screen size redraws the set and goes to the first song in the set.
Fixed an issue with loading the improper set/song when opening the app.
Fixed an issue where when you've viewed a set and switched to the songs tab, and you leave the app and come back, the set tab is selected.
Fixed an issue with how up/down arrows were handled in the "Custom" foot pedal driver.
Fixed an issue with deleting books and song where it didn't prompt for deleting first.
Fixed an issue where you can't close the chord inspector when in compact mode.
Fixed an issue when reordering lists of sets caused by drag and drop.
Fixed an issue where restoring a library on an iPhone causes corruption due to the database being accessed before it's ready.
Fixed an issue drawing misalignment after drawings are applied.
Fixed a crash loop on iPad 2 when changing saving settings.
Fixed a content inset in the song editor on compact devices.
Fixed an issue where no Done button appears on an iPad when running in compact mode during multitasking split screen.
Fixed an issue where a trailing space at the end of the keyword is limiting the search results.
Fixed issues with undo/redo process in the song editor.
Fixed a crash in the timeline menu if you clear all items and record again.
Fixed alignment issues with the search bar in the SongSelect screen when running in compact mode on iPad.
Fixed an issue with iOS 11 running on very small screens where the last toolbar item is made unusably tiny by removing the send message tool in those cases.
Fixed an issue with how chords are resolved when display chord diagrams inline.
Fixed an issue with picking colors for drawing on an iPad Pro when in split screen compact mode.
Fixed an issue with how the search bar displays in SongSelect as it is not aligned properly.
Fixed an issue when in 1/3 or 1/2 split screen where the keyboard would overlap the Flow text field in the Song Playback menu.
Fixed issue where adding metadata to change key like Transpose: 2 or Key: A ends up showing in lyrics projection and shouldn't.
Fixed an issue where the default language would not be able to be restored to default.
Fixed an issue where messages are not selected when changing the message to send from an action.
Fixed an issue with the size of the velocity slider in the MIDI Settings menu.
Fixed an issue with the "Could Not Authenticate" screen causing the menubar to stop functioning due to a bug in iOS 11.
Fixed an issue where importing images from the camera roll were flipping the image upside down.
Fixed an issue where using MIDI index would retrieve previously deleted or loaned songs not found in the user's library.
Fixed an issue where where flow elements containing a colon would cause flow to render the song incorrectly in Console.
Fixed an issue where the console would not transpose when using the transpose tag.
Fixed a crash condition in the timeline editor.
Fixed a crash condition after restoring a library with a song that has a timeline loaded.
Fixed an issue when using transpose: in a flow definition can cause lyrics projection sections to be offset.
Fixed an issue with how live bar buttons align in iPhone X.
Fixed an issue where the color in the description of a DMX step does not update.
Fixed an issue where Chromecast is not showing footers.
Fixed a possible crash condition when reordering import sources.
QuoteScenes lets you control background graphics and lighting to engage your audience with systems from Philips Hue and LIFX. In-app purchase.
https://www.businessinsider.com/philips-hue-amazon-echo-vulnerability-hacks-how-to-prevent-update-2020-2?utm_source=yahoo.com&utm_medium=referral
A vulnerability lets hackers gain entry to people's computers using Philips Hue smart bulbs. Here's how to protect against it.
Don't Immediately Update to iOS/iPadOS 14.3
Apple is soon releasing their iOS/iPadOS 14.3 update. OnSong recommends NOT immediately updating. Apple has made some changes in this update that may affect backing track playback and more. We also recommend always backing up your OnSong library before ever updating.[/i]
Been using OnSong Pro with new band during rehearsals ( learn 45 new songs requires a cheat sheet
Really enjoy the remote "Console" mode, where I use my 23" Windows PC monitor to add/Edit all songs
There are Android equivalents now
SONGbook Pro. and the German  "S.martChord Pro".
