Survey of USB Hubs
Started by Elantric, January 13, 2014, 08:01:52 AM
The goal of this thread is to develop a list of USB Hubs that our members use, and work well your needs , this could be any computer platform, any Operating system, which supports  any Audio /MIDI device - although for iPad Owners these will typically be USB Class compliant types.
https://www.vguitarforums.com/smf/index.php?topic=10323.msg75127#msg75127
Please add a few comments and details with your Recommended (or Not Recommend) USB Hub.
Since there are so many variables to obtain successful operation for modern guitarists and today's guitar applications please post your response in the format below:
Brand & Model:  (insert name of USB Hub here)
Status: (RECOMMENDED, or NOT RECOMMENDED)
Computer Type & OS : (Dell, HP, Apple, Sony, Asus, IPad, iPhone, Ipod Touch, etc.) ( IOS7.x.x, Win8.1, OSX, 10.9.x, etc)
Computer USB Port type Method/Speed: (USB 1.0, USB 2.0, USB 3.0, Apple USB Camera Connection, third party dock adapter , etc)
Powered Hub Power Supply Types used: (NONE if passive non powered used) generic 2.5Amp USB Supply, Battery, etc
Connected Devices: (Audio Interface, MIDI Interface, Fishman Tripleplay, KMI Softstep etc.
Comment: (insert your experience and thoughts here)
References:
http://gigaom.com/2010/08/11/secrets-of-the-camera-connection-kit/
These are typical Errors
datsunrobbie
Brand & Model: GE USB 2.0 rotating hub (4 port) 97847 Rev1
Status: RECOMMENDED
Computer Type & O/S: ASUS T100TA-C1-GR,  Windows 8.1
Computer USB Port type Method/Speed: Micro USB (USB 2.0) via Samsung EPL-AU10WEGXAR micro USB/USB Connector
Powered Hub Power Supply Types used: (NONE)
Connected Devices: GR-55
Comments: working with Gumtown's GR-55 Floorboard. This is a fairly small 4-port hub that I picked up on clearance at Target for $1. It can be externally powered, but I have used it to run Floorboard without external power and had no issues. Seems to be out of production, but I have seen them as recently as last month in the local Ocean State Job Lot closeout store.
I tried connecting the GR-55 to the USB 3.0 port on the ASUS T100 keyboard, and as expected it did NOT recognize the GR-55 when connected.
URL Link :
http://www.samsclub.com/sams/delete-ge-usb-hub-2-0-4-port-w-rotating-cubes-pink/173378.ip
http://www.amazon.com/USB-Highspeed-Port-Adapter-Silver/dp/B002FFZGCU/ref=sr_1_24?s=electronics&ie=UTF8&qid=1389627962&sr=1-24&keywords=USB+Powered+hubs
Brand & Model: SanoyXY 7 port powered USB .20 Hub
Status: NOT RECOMMENDED
Computer Type & OS: Apple iPad Air 128GB +4G (ATT)  Apple IOS 7.0.4
Computer USB Port type Method/Speed: Apple Lighting Camera Adapter (USB 2.0)
Powered Hub Power Supply Types used: generic 2.5Amp USB Supply,
Connected Devices: FocususRite Scarlett 2i4, Fishman Tripleplay
Comments: This hub used to work great with my old 30 pin iPad 2 with IOS 5-6, but now with IOS7, it does not work  - all I get are the typical Apple IOS :Warning pop message  messages that the connected "USB device uses too much power", and if I click OK - nothing happens, and the iPad must be rebooted before any other attempt at a USB connection can be established.
eForCity 7-Port USB Hub with Switches
http://www.amazon.com/eForCity-7-Port-USB-Switch-Black/dp/B007S642BW/ref=pd_sim_e_1
recommended for IOS devices for audio / MIDI devices  - not  recommended for MacBooks running OSX or use with Hard drives!
make /Model eForCity 7-Port Powered USB
Status: RECOMMENDED
The DC Power adapter cable uses a small coax DC connector and Center of the Coax tip is +5VDC Positive, and outer sleeve is Ground
Limeade L180X - 18000mAh External Lithium Battery Pack
http://www.amazon.com/External-Battery-Pack-Limeade-L180X/dp/B00C78YJQY/ref=pd_bxgy_cps_text_y
Comments:  Works great  - Read more details here:
https://www.vguitarforums.com/smf/index.php?topic=10323.0
This one might be my top favorite (at this hour) Powered USB Hub for iPad on IOS7,  it was a joy to have three Korg Nano Kontrollers, FTP, and Scarlett 2i4 all running at the same time on my iPad Air. The individual on/off switches for each port saves wear and tear on the USB Jacks, and helps big time while debugging IOS USB problems.
DC Coax plug to USB adapter cable to Power the eForcity 7 Port USB Hub
http://www.ebay.com/itm/USB-2-0-Male-to-3-5mm-Barrel-Connector-Jack-5V-DC-Power-Cable-15-inch-Black-US-/360658147811
7 port high speed USB 2.0 HUB
Data transfer rate: 1.5Mbps/12Mbps/up to 480Mbps
Bus-power limit current protection: 500mA
Interface: USB 2.0 Compatible with USB 1.1
Brand & Model:  eForCity 7-Port USB Hub with ON / OFF Switches
I like this USb Hub so much I ordered a spare in white (which I prefer on darkly lit stages) $6.28
http://www.amazon.com/gp/product/B00GQO23G8/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
Note from tomtheguitarguy  - Avoid the 4 port version of this Hub
https://www.vguitarforums.com/smf/index.php?topic=10323.msg74428#msg74428
QuoteI've got one of these hubs (the 4 hub version) and for some reason, it's not working with the FTP.  I plug the hub into the CCK or Lightning USB and it lights up, but the lights just continue to blink on the FTP and they don't pair.  Doesn't matter if I'm using the AC adapter or not...
http://www.dhgate.com/store/product/10pcs-usb2-0-card-reader-usb-hub-hy-619-e00131/162667419.html
Brand & Model:  USB2.0 Card Reader USB HUB HY-619 E00131-10
Status: RECOMMENDED
Powered Hub Power Supply Types used: generic 2.5Amp USB Supply, Limeade L180X - 18000mAh External Lithium Battery Pack
http://m.dckina.com/mobile.php?main_page=product_info&products_id=1555
Brand & Model:  5-in-1 Lightning Card Reader & USB Hub for iPad Air / iPad Mini
Computer USB Port type Method/Speed: Direct connection to iPad Air Lightning port
Comments: It actually worked - but eventually every  3 -5 minutes I would experience temporary USB data connection loss  - and random audio drop outs which took 5 seconds for the audio to make a new USB data connection again  - so its not recommended. Since this USB Hub Includes a non qualified Lightning port I suspect the culprit is the Apple mFI qualified External Hardware check routine in latest IOS 7. but this is only a  theory. The latest Apple mFI spec requires the third party vendors to use apple supplied mFI verification ICs in their hardware designs - and this Lightning 4 port HUB does not have one.
https://developer.apple.com/programs/mfi/
http://www.amazon.com/gp/product/B002AESNUI/ref=oh_details_o01_s00_i02?ie=UTF8&psc=1
Brand & Model:  Belkin F5U404PBLK USB 2.0 4-PORT Mobile Hub
Status:  RECOMMENDED
Computer Type & OS: Apple iPad Air 128GB +4G (ATT)  Apple IOS 7.0.4, Lenovo W520 Win7 64, iMac 27" OSX10.8.5
Computer USB Port type Method/Speed: Apple Lighting Camera Adapter (USB 2.0), USB 2.0 ports)
Powered Hub Power Supply Types used: Supplied 2.0Amp supply
Connected Devices: Fishman Tripleplay, Scarlet 18i6
Comments: Works well!
 Pluggable 4 port powered hub $20
  http://www.amazon.com/gp/product/B005P2BY5I/ref=oh_details_o09_s01_i00?ie=UTF8&psc=1
Brand & Model:  Pluggable 4 port powered hub
Status:  RECOMMENDED
Powered Hub Power Supply Types used: Supplied 2.5 Amp supply
Connected Devices: Fishman Tripleplay, Scarlet 2i4
This is a Powered USB 2.0 "Sharing Hub" with 7 ports.
VAKOSS USB 2.0 HUB P/N# TC-271-AA 7 Port High Speed Hub
These are getting rare and no longer in production - but there are a few left on Ebay
http://www.ebay.com/itm/USED-VAKOSS-USB-2-0-HUB-TC-271-AA-7-Port-High-Speed-Hub-USED-Great-Item-/190854801897?_trksid=p2054897.l4276
It is mentioned here:
http://www.simonclivehughes.com/Simon_C._Hughes_Photography/Simon_Sez/Entries/2013/4/16_Makin_Music_in_2013.html
And seems perfect for those sharing mulitple USB Class compliant Devices between iPad and a PC/Mac
cooltouch
Okay this is a cheapo 7-port hub I bought at MicroCenter last week. Cost me $15. There is no brand name on the hub, and I don't recall the brand name on the packaging, which is long-gone by now. Chances are it can be found under a variety of brand names anyway. I've tried it out with my Alesis iO2 only so far and it works just fine syncing the iO2 up with the iPad.
Here is a no-flash pic of the hub plugged into my iPad Air. Say, isn't Amplitube supposed to rotate? Mine won't. As you can see, the hub's blue LED is really bright. This doesn't have all the separate on-off switches like Elantric's, and in fact, two of the seven ports are stacked up at the top of the hub.
I used my camera's flash for this shot:
And here's a shot of the backside of the hub, showing the only text on the entire device.
Best,
Michael
QuoteHere is a no-flash pic of the hub plugged into my iPad Air. Say, isn't Amplitube supposed to rotate? Mine won't.
Thats because you installed the iPhone version of Amplitube on your iPad Air - see the small round (1X) view toggle on the lower right corner of the screen
The iPad version is here: (sold separately)
https://itunes.apple.com/us/app/amplitube-for-ipad/id373750924?mt=8
But I do not recommend IK Multimedia IOS Amplitube for users of External USB Class Compliant Audio Interfaces - Amplitube does not work for me with any of my USB Audio interfaces when used with powered Hub and Apple CCK.
Use Positive Grid Bias instead.
https://www.vguitarforums.com/smf/index.php?topic=9903.0
cooltouch
#11
Actually, I didn't install that copy of amplitube. The iCloud transferred over all my ikm stuff. It's all the free ikm stuff, anyway. I got a special activated copy of amplitube and sample tank with my 2014 upgrade of Band in a Box, so I don't need to be Paying for an iPad copy. Besides the iPod version that's there now doesn't sound half bad. I've owned amps that sounded much worse.
I suppose one good thing about using the iPod/iPhone version is it does work with an audio interface, powered USB hub, apple cck, and iPad, no problem.
That grid one in the link sounds like an awesome emulator. Looks pretty interesting with all the controls and settings too.
Best,
Michael
BackDAWman
Quote from: Elantric on January 13, 2014, 10:44:19 AM
Status: RECOMMENDED
System requirement: Windows: XP, ME, 2000, 98SE, 98, Vista, 7 Macintosh: Mac OS x 10.2 Linus 2.4 later version
Does anyone know the polarity of the power supply needed for this hub. I'm guessing it would 5V but not sure of the polarity.
BackDAWman
Thanks for that Steve! I actually found a USB to DC power connector lead and plugged it into a USB charger type wall wart. I lucked out on the polarity and it worked! It saves the drain on the iPad's power. :D
Terry50
#14
Hi
I bought three eForCity 7-Port USB Hus with the on/off switches.
And I got three DC Coax plug to USB adapter cables to Power the eForcity 7 Port USB Hubs.
I plug them direct into my Mac Pro.  The blue on/off lights turn on but that's the extent of them working.  I can't get my mouse or external HD to work in them.   Do you know what the problem is??    :o
Thank you.
Terry
QuoteHi
Thank you.
Terry
Because the EforCity Powered USB Hubs are USB 2.0 and only recommended for IOS devices for audio / MIDI devices  - not  recommended for MacBooks running OSX or use with Hard drives!
You need a Powered USB 3.0 Hub - I have good results with Pluggable and Ankar USB 3.0 Hubs
http://www.amazon.com/Anker%C2%AE-Charging-Adapter-VL812-B2-Chipset/dp/B005NGQWL2/ref=sr_1_2?ie=UTF8&qid=1418578798&sr=8-2&keywords=usb+3+hub+anker
Anker® USB Hub with 9 USB 3.0 Data Ports + 1 Smart Charging Port (5V / 2.1A)with 12V 5A Power Adapter [VIA VL812-B2 Chipset]
Plugable USB 3.0 SuperSpeed 10-Port Hub with Two Flip-Up Ports and 48W Power Adapter (VIA VL812 Rev B2 Chipset with v9081/9084 firmware. Windows, Mac OS X, and Linux support. Full USB 2.0 backwards compatibility)
http://www.amazon.com/gp/product/B00JEPIOOQ/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
This USB Hub works well with iPhone/iPad and includes the 5VDC to USB adapter cable - I use a separate external 5VDC Battery pack to power this and all my USB Audio  / MIDI Peripherals connected to iPad ( FTP, Arturia Beastep, Focusrite 2i4)
http://www.amazon.com/gp/product/B00PFEMTGY/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
The only 7-port bus-powered USB hub on the market with a 3.3 ft long USB cable, so you can place your hub wherever you want;
The only hub on the market that is both bus-powered and self-powered. Comes with a DC 5V power cable so you don't have to worry about unstable connections and your hub not having enough power. A perfect combination of convenience and performance;
Fast data transfer speeds, with a USB 2.0 transfer speeds of up to 480 Mbps (much faster than USB 1.0,the actual rate will depend on the capability of your device)
Widely compatible and super safe Compatible with USB 1.1 and 1.0, with no drivers required for Windows XP/Vista/7/8 and Mac OS X 10.2 and above.
EasyAcc also provides a 12-month warranty and free lifetime technical support.
Numark Production Hub | Data Transfer & Surge-Protection Power Strip with 6 AC Outs & 5 Ports (1 2.1A + 4 USB 3.0)
https://www.amazon.com/Numark-Production-Hub-Transfer-Surge-Protection/dp/B01LEZMQRY/ref=sr_1_63?ie=UTF8&qid=1541982550&sr=8-63&keywords=can+bus+controller
Numark's Production Hub is the power strip you need to handle all of your equipment—old and new.
First, it protects your delicate electronics with a high-voltage surge and transient suppressor, plus a radio frequency interference (RFI) and electromagnetic interference (EMI) filter.
Need to get lots of data onto your computer from different sources? Production Hub provides full-speed data communications over USB 3.0, with a 4-port USB 3.0 hub that offers computer/peripheral data connectivity and device charging. A fifth USB port is a dedicated 5V 2.1A charging port, for even greater convenience.
Altogether, you can power 11 pieces of equipment at the same time, with six AC outlets and five USB ports.
Finally, the six-foot cord means it'll always be in reach when you need it.
Connections
(6) Outlets: Connect your AC devices here to provide power to them.
(4) USB 3.0 Data/Charging Ports: Connect your devices here to charge them. Alternatively, use this as a hub to connect your devices to a computer
(1) USB 2.1A Charging Port: Connect devices such as smartphones, tablets, media players, etc. here to charge them.
(1) USB 3.0 to PC: Use a USB cable to connect this port to your computer. When connected, any devices connected to the USB 3.0 Data/Charging Ports are connected to your computer. Port is backwards compatible with USB 2.0 devices.
Technical Specs
Maximum Output Current: 15 amps
Line Cord: 6 ft., captive, 14 AWG, with 3-conductor Edison plug
Operating Voltage: 120 VAC, 60 Hz
Spike Protection Mode: Line to neutral
Spike Clamping Voltage: 185 VAC peak @ 3000 amps
Energy Dissipation: 1800 joules
Maximum Surge Current: 6000 amps
Maximum Continuous Operating Voltage: 130 VAC RMS
Response Time: 1 nanosecond
Noise Attenuation: 10 dB @ 10 kHz; 40 db @ 100 kHz; 50 dB @ 500 kHz
USB Charger: 5 V, 2.1 A
Dimensions (width x depth x height): 11.81" x 3.54" x 1.61"
Weight: 2.6 lbs
Box Contents
Production Hub
Quickstart Guide
Safety & Warranty Information
https://www.vguitarforums.com/smf/index.php?topic=24895.msg180594#msg180594
JIMMYJ WROTE>
I would like to report that the Wavlink USB TYPE C  4 port hub https://www.amazon.com/gp/product/B017N3KNP8/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 works on my Dell Thunderbolt 3 port. So far the Focusrite 6i6, Axon Ax50, Roland Gi20, Liquid Foot Pro 24 and Keith Mcmillen 12 step all work through this hub. I did buy a power supply for this hub before I tried any of the interfaces. The only thing that doesn't work so far is the Midisport 2x2 anniversary edition interface. The Focusrite 6i6 seems to be as fast on this hub loaded down as plugged straight into the laptop but I need to do more testing on this to be sure . The Anker 7 port usb 3.0 A7505112 hub recommended in another post by admin also works for most of these interfaces except the Midisport if your using the usb 3.0 port on your computer.
