FTP plus GK install
Started by Headless68, September 06, 2014, 05:09:16 AM
Headless68
Managed to get quite a nice fit by taking the original kahler front mounting screws out and putting a couple of pan head screws at the side - this gave the perfect size to slot it in behind the GK I already had installed
I ended up also using some GK shims under the fishman pickup holder to get optimum string height
Vade
https://soundcloud.com/vadie
Vaultnaemsae
Why did you choose to put the FTP pickup in the rear position rather than the GK? I just came across this...a guitarist named Mark Wingfield's axe, probably a member on this forum!
Thinking about how to mount both currently...not sure what will work yet
Vaultnaemsae's SoundCloud:
Pin
Does this "duo system" actually work ok?
Especially for the nearest to neck hex pickup whichever one it is? Or is it definitely better to put the FTP rearwards (why?)?
