24 pin to13 pin Conversion
Started by nixonix, December 15, 2012, 12:36:03 PM
nixonix
Hi all,
I'm doing a 24pin to 13 pin conversion-splitter box to use my Ibanez IMG2010 to drive my Roland GM-70 and VG-99 at the same time. This way, I'm gonna send MIDI messages to the VG-99 and still use the virtual whammy bar of the IMG2010 guitar and other available extra controls.
I have some questions for the tech in you :
  • What is the signal coming out of the hexaphonic pickup like ? Is it a plain signal like any other magnetic pickup ?
    The pin #9 (24pin) should be wired to pin #8 (13pin) to transfer the SYnthesizer volume control. Do someone know what max VOLTAGE should the VG-99 receive on pin 8 ? I'm measuring 11.5 V as maximum output for this on the GM-70 ?
    Someone have ever though doing something like this ?
    Any other observation ?
Thanx all
Nicolas
drjoness2001
You might want to check out this website:
http://www.joness.com/gr300/
This accessory does just about exactly what you want:
http://www.joness.com/gr300/GX-13.htm
There are videos of a Roland VG-99 and GM-70 being played at the same time with a vintage 24-pi guitar.
Good luck!
DanVG
QuoteDo someone know what max VOLTAGE should the VG-99 receive on pin 8 ?
5V for max vol, 0 for 0 vol.
paults
It may be a good plan to check with Wayne to see if he was the parts to put a discontinued item together :)
I have an old Roland BC-13, and an equivalent box that Wayne made for me works just as well, and has the bonus of doing more than the BC-13 does.
parmak
From where can we buy these discontinued units?
QuoteFrom where can we buy these discontinued units?
Contact Wayne Joness for current status today on these 13pin to 24pin conversion boxes.
He is also a member here too. Shoot a Personal message to "drjoness2001"
I understand the availability is always dependent on locating more 24 pin jacks, which ceased production back in 1988.
But clever Dr Joness seems to always locate more, and then makes a limited production run.
I understand this version is currently available today. RC-1324 "Red" - allows you to use any GK13 pin guitar with older 24pin Roland GR-100 /GR-300 / GR-700
http://www.joness.com/gr300/RC13.htm
drjoness2001
Here is info on the current model, the BX-13-VC:
http://www.joness.com/gr300/BX13.htm
